HP w1907 Monitor...I get a notice that an update is ready to install but it will not install. I see many people have had problems when searching the internet for an answer. Can you hlep me?
Ok so i was searching around the internet and found a similar problemwith another monitor so for giggles i tried there method. This is thewebsite where i found it : http://social.technet.microsoft.com/forums/en-US/itprovistahardware/thread/d7c0e5bd-2fcf-48ff-a79b-c157014fc821/#page:3
The Second entry has a download.Download it then extract the files to the desktop. Dont worry if youget errors when the program runs it will fix them, if they come up justpress enter to keep going. Once the program completes install thedriver again and it should work as it did for me.
If you cant get to that website heres the post from it:
"Ok, once again i checked updates for HP My Display/Drivers, and found this:
http://www.portrait.com/dtune/hpw/enu/support_help.html
Here is a direct link to fix for "Access Denied" issue (HP LCD Monitors & Vista):
http://download.portrait.com/DRVFix.zip
Download DRVFix.zip. The fix contains 3 files including this readme. All must be in to the same folder.
To perform the fix do the following:
If you find this helpful, please let me know.
I fixed this issue manually (from registry), about month ago.
But gladly i found this help file, by mistake.
Regards
Vesa"
There you Go, KD0BGA
Basically, the two replies I did get had no solution to the problem and they experienced the same thing. I find it appalling that, and if you check on the internet there are many, many facing the same issue, no one is willing to step forward with a fix, WITHOUT HAVING TO PAY FOR IT!!!. Why should we pay for something that was overlooked which gives me the feeling that "They have my money and don't care. Be warmed and be filled. Go away and don't bother me with your trivial requests.
I finally selected to HIDE the update so I won't see it popping up every day or week.
I guess some things never change. Money is everything.
I am having the same problem. Each time I turn on the computer I get a pop up that I need to install the driver, but then it always says it failed. I have tried all the advice, but still not having any luck.
I have the same problem but there doesn't seem to be a fix for it. I finally added the update to the "Hide Update" list in Windows Update just so it would quit nagging me.
The software for my monitor will not install. It tells me that there is an error.
