Question about Canon PIXMA MP160 All-In-One InkJet Printer
My printer wont load paper so i can print - Canon PIXMA MP160 All-In-One InkJet Printer
  • Anonymous Jan 18, 2009
    I have had the same problem after only 6 months. I have tried everything to get it to feed. always jams and kinks to the right side. I am not happy at all!
  • 3 Answers
My Canon started doing the exact same thing. I tried several mods but no luck. Seemed like it would **** hard when starting to print thus mis-aligning the paper. What I found that did worked and solved my problem was putting the printer into 'quiet' mode. In this mode it doesn't **** the paper in as fast and thus doesn't jam. I don't think it has jammed since the change and there's no really noticeable slow down in the output.
Pull up the properties dialog for the printer and go to the maintenance tab.Select 'quiet mode' button and then set it to always use quiet mode. Worked for me. Hope it works for you!
Posted on Jan 20, 2009
Kyocera 2020d WONT PRINT Load Mp Tray
load a4 paper in bypass or the mp tray as it is also called
Jun 08, 2017 | Kyocera FS-2020D ECOSYS Monochrome Laser -...
I have a Dell 3000cn printer it is saying load paper but the paper is loaded but wont print
check whether the cartage is fix well or the paper is far from the area from where the printer starts printing.
Jan 27, 2011 | Dell 3000cn Laser Printer
My printer says load paper then press start, I have paper in there and it wont print.
Dont know what you have already tried but first off verify that you are loading paper to the correct tray. Now this tray is going to have a switch located toward the feeder that tells the printer paper is loaded make sure the paper is back far enough but not to the point where you are forcing the paper into the feeder. If all this still doesnt work try reseting the printer and printing a test page. Hope this helps.
Mar 10, 2010 | Dell 924 All-in-One InkJet Printer
Printer wont print. It keeps saying PC Load Legal. The printer has paper in it.
Well the printer is telling you to load "Legal Size paper, which is 8.5" X 14" paper.
More than likely, the application you are using is telling the printer to print the page on legal sized paper.
If you want the document to print on "Letter sized paper (8.5" X 11") then in the application, go to the File drop down and select "Page Setup". From within page setup's window, change the paper size to letter and then re-print the job.
Dec 16, 2009 | HP LaserJet 4 plus Printer
Printer says paper jam, now scanner wont work
you will need to open it to remove this piece of paper.
Aug 14, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Flashing yellow light not allowing me to print
just put in new cartridges in paper full,no jams
Jul 13, 2009 | HP Deskjet D4160 InkJet Photo Printer
Canon Mx300 wont recognize my paper. says:load paper
I cant light under alarm keeps flashing...please help...patricia
Jun 04, 2009 | Canon MX300 Office All-In-One Printer
Paper won't load. and Stops printing before it can start.
Try turning the paper around. Some times the corners of the paper get slightly bent and the paper wont load.If turning the paper around does not work, switch your paper. Hope this helps.
Feb 03, 2009 | Canon PIXMA iP1600 Printer
Thick paper wont print
Per the user manual you should try using manual feed, loading one piece of paper at a time into the try and then following the on screen directions(whould be press the stop button once after paper loaded), find attached a image showing how to set up the manual feed0c16087.jpg
Oct 21, 2008 | Samsung CLP 300 Laser Printer
Dell 926 All-In-One InkJet Printer
printer wont print anything. computer says no print documents pending even though ive clicked print a few times and on different programs and internet pages as well. printer will print only if i copy something press print test page from the printer itself but it doesnt print anything from the computer
Oct 15, 2008 | Dell 926 All-In-One InkJet Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
138 people viewed this question
old marine
old marine
