Question about Whirlpool RF365 Electric Kitchen Range
Whirlpool RF368LXMQ Overheats; Displays F3E2
First saw F3E2 a couple of weeks ago, but did not initially notice any operational impact. Just tonight, oven beeped in alarm and quickly overheated burning the food. Is there a way to trouble shoot to determine if the problem is temp sensor, control board, etc. without just blindly replacing parts hoping to fix it?
  • ejzero1 Jan 16, 2009
    Thanks for the quick response, Diane!
    Always best to start with the easiest and cheapest, I guess. Can you tell me exactly how to test the sensor? Pretty handy around the house, but this is my first go 'round with an oven.
    Thanks again!
    EJ
  • 126 Answers
I'd start with testing the oven sensor that if that is bad it wont be horrible because you'll have no problem replacing it yourself less than $100. That is where I'd start let me know if it works. Good Luck.
Diane
Posted on Jan 16, 2009
How do I determine and fix what is wrong with 2008 model whirlpool frig that the freezer I noticed first all food unfrozen then a couple days later refrigerator not cooling can hear running but contin
I ned more information to answer your question. What model do you have? This is very important to give you the correct information you seek. Thanks
Sep 16, 2014 | Whirlpool Refrigerators
Error "LE" on the display after initial water load
just perform the tub cleaning operation as advised. nothing else. getting soiled
Mar 18, 2010 | Washing Machines
Screen displays error code f3e2
This code means "BAKE/BROIL range over temperature"
Problem is in either temperature sensor or the control board. Check the temp sensor and wiring from it to the control board first (connector #3, contacts 8 and 10, violet wires) . At room temperature the temp sensor resistance should be around 1080 Ohms. Also check temp sensor for short to ground. If no problems found with the sensor - replace control board.
OBTW - for the broil problem - check the fuse inline with the broil element (continuity between Conn #2, wire 1, blue and conn #4, wire 3, red). It should read several ohms. Good luck!
Oct 12, 2009 | Whirlpool RF462LXSB Electric Range
Flash will not fire on Canon SD780 IS Elph
The flash circuit is defective. As it's only a couple weeks old, recommend just exchanging it for another from your place of purchase. You shouldn't be attempting repair while its under warranty.
Jul 04, 2009 | Canon PowerShot SD700 IS Digital ELPH /...
Drain/Spin won't work unless lid is lifted up
Curdy, it almost sounds like your lid switch is loose or fractured and the lid actuator is not making the switch. Check this out first and post back...Catriver.
Oct 19, 2006 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool RF365 Electric Kitchen Range Logo
976 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
