Question about Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 5 Hp, 230 Volt 1 Phase, Model - 2340L5
Starting problems How can you check if the capacitors are good in te starting circuit of the motor? I have Ingersoll rand compressor model 2340. 30T. It trips the breaker when it try's to start. If i can get the breaker to hold past the start it runs just fine. So I think the problem is in the start capacitors. my question is how do you check them, and if they are bad where can I get replacements?
    Scholar:
  • 89 Answers
IF YOUR PRETTY SURE DRAW A CAPACITOR WIRING DIAGRAM AND THEN TAKE YOUR CAPACITORS TO ANY MOTOR SHOP OR SUPPLY HOUSE LIKE WW GRAINGER. THEY CAN CHECK THE MICROFARRADS OR UNIFARRADS OF YOUR CAPACITORS. YOUR START CAPACITORS HAVE THE LARGER MF OR UF RATING AND ARE TYPICALLY LARGER IN SIZE. YOUR P.O.S. INGERSOL RAND MAY EVEN BE A 3500 RPM MOTOR AND COULD HAVE UP TO 5 CAPACITORS. 3 OF WHICH ARE START. IS YOUR WIRE LARGE ENOUGH? IS YOUR BREAKER LARGE ENOUGH? IS YOUR COMPRESSOR UNLOADING THE HEAD PRESSURE WHEN IT CUTS OFF? IS IT OUTSIDE AND TOO COLD IN THE MORNINGS? MAKE SURE YOUR WIRING IS LARGE ENOUGH BECAUSE THAT IS USUALLY THE PROBLEM. YOU HAVE SINGLE PHASE BUT IS YOUR VOLTAGE CORRECT 208V OR 230 V. ALL WIRING AND GAUGING CHARTS ARE BASED ON 100 FT OF WIRE . MOST COMPRESSORS PULL 3 TIMES THE AMP RATING ON INITIAL STARTUP THEN COM DOWN TO AMPS LISTED ON THE MOTOR.
Posted on Jan 27, 2009
  • 33 Answers
Its probably far too late now but for anyone else that has this problem try this, it work very well for me
Posted on Oct 06, 2012
A couple of months ago my compressor would trip the breaker...It would whine a bit and then trip. My buddy is an electrician and checked it out; he couldn't tell if it was the cap or not but sent me to Graingers to buy one; they are only around $8 or so... to me it was a cheap fix to try...it worked!
Posted on Sep 01, 2009
VSD fault 7 Problem with Ingersoll Rand Air & Gas Compressors nirvana n37 37kw
plz any one help us vsd 7 fault and the compressor does not start and the fault appears
Mar 21, 2014 | Ingersoll Rand Air Tools & Compressors
3 Phase 7.5 HP air compressor overheat, runs on and off, we found it has no capacitor, what is the correct capacitor needed.
There could be several reasons why your unit is "overheating". Is the motor tripping the circuit breaker ? Is it the motor or the compressor that is overheating? I need more description of the problem. 3 phase motors do not have capacitors. Is the compressor turning the correct direction? Is the supply voltage correct? Is the power cable the correct size? Do you have the correct type and quantity of oil in the compressor?
Jan 24, 2012 | Ingersoll Rand - Rand Type - 30...
I have a Ingersoll Rand en6f75 compressor. Does it have to run in a particular direction as I cannot see any direction arrows on it.
We provide tech manuals for all of our products at www.irtechpubs.com. We also supply technical information on our website www.ingersollrandproducts.com. Hope this is helpful.
Ingersoll Rand Employee
May 13, 2011 | Ingersoll Rand - Rand Type - 30...
My compressor bogs out to the point it will stall the motor and blow a fuse. it happens on the third cycle at about 110 to 125 psi
change the run capacitor on the motor,its getting weak,there may also be another capacitor for the start circuit,replace them both
Mar 05, 2011 | Ingersoll Rand SS5L5 Ir Electric...
Trying to rewire my ingersoll rand air compressor motor, psi switch motor starter, need some kind of diagram, it has a 5hp single phase 220
Please check out the Web Site Below. It is a Quick Start manual for IR Compressors.
It should have everything you need. It DOES NOT Show you any wiring connections AT the motor.
Hope this helps....Jim
http://www.irtechpubs.com/ir_pdfs/Compressed%20Air/Air%20Compressors/Reciprocating%20Compressor/80445703.PDF
Feb 18, 2011 | Ingersoll Rand - Rand Type - 30...
IR 2475E Wont start up 220 everywhere No LOP switch
did you check for a motor reset button on the motor??
Feb 20, 2010 | Ingersoll Rand - Rand Type - 30...
Older t 30 won't start
I believe your capacitor or capacitors are going out. Or one of the three phases has popped a fuse.
If there is a fuse box for the unit, shut off the breakers on the wall to the unit and do a continuity test across each fuse.
If nothing is found, remove all motor capacitors and bring them into you local electric motor repair shop. Usually they will check capacitors for free.
This should do it.
Mar 31, 2009 | Ingersoll Rand Type 30 Reciprocating Air...
Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 5 Hp, 230 Volt 1 Phase, Model - 2340L5 Logo
1,056 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
