Question about Video Game Consoles & Games
How to login to router?to change mtu settings
  • Charles Hicks May 11, 2010
    Hello, Could you please send us the type of router you are using, We look forward to hereing back from you, Thanks
  • 51 Answers
Consult the routers manual. It will give you a default IP address of the router which you can type into your internet browser. Then, search through the pages until you reach the page to configure your settings. This applies for 90% of new routers.
Posted on Jan 16, 2009
How do i change my MTU settings
To change MTU settings you have to login to the router's web interface and make the required changes under WAN settings:
1.Open your web browser and type in the IP address of the router (192.168.0.1 by default).
2. Enter the username (admin) and password (blank by default), and then click Ok or Log In .
USERGUIDE D-LINK DGL-4500
Official Support Page
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 20, 2011 | D-Link DGL-4500 Wireless Router
How can I change my mtu on my wireless router to be able to play xbox?
Xbox LIVE requires a minimum MTU setting of 1364. Usually, you can change your MTU setting from your router configuration web page, which is supplied by your router manufacturer.
Learn how to find and use your router configuration page
Look for the MTU setting on the router configuration page. When you find it, set it to Auto or 1364 (or higher), save your settings, and then try to connect to Xbox LIVE again on your console.
Nov 21, 2009 | Zhone (6218-I2-200) Router
MTU settings
So your first problem is to learn how to login to your router. Please see your documentation. You can usually find the documentation for any router/homegateway at the vendors website.
If you still can't logon you may have to do a "hard reset" of the router/gateway to force it back to the default logon/password.
Now having solved that you need to understand that the largest MTU setting that you can use to increase your internet performance must be equal to or smaller than the smallest MTU setting between you and your internet target. If you make the MTU larger than that it will slow down your connection because it will now have to use 2 frames transmit and recieve what it used to only use one for.
While there are tools that can help you with that, the simplest solution is to find out what your ISP says the MTU should be.
Tom
Aug 21, 2009 | Toshiba WRC-1000 Router (PA3227C1ETC)
I cant connect to xbox live cause of my mtu setting
you have to log on to the router and under the WAN mode, you should have the option of changing the MTU. IF you have not made changes to the router settings, type http://192.168.0.1 in your browser . In the page that comes up, type in username as admin and no password.
This should take you to the browser login page.
Hope this helps
Thanks Ranjit ranjit@supportminds.com
Jun 16, 2009 | D-Link DI 514 Wireless Router (DI-514)
Mtu setting
In some cases, MTU is not necessary to adjust. Its always automatic and defaulted to 1500. The router model that you have doesn't have MTU settings. You can download the User's Manual HERE. You must do port forwarding and open the xbox live port so you can play xbox live. If it keeps on telling you about MTU, you must set static IP address on your xbox's settings and power cycle your devices.
Jun 02, 2009 | Zhone (6218-I2-200) Router
Cant figure out mtu settings
You must set your MTU in your modem/router just login to it and search for it in the configuration menu.
Usually you have to set it to 1492 though so if you should have set the MTU to 1364 already and it didnt work try this one as well.
For cable and DSL modems you should set it to 1492 in general as well for a proper connection.
How to set it varies for each modem, take a look at the manual of your modem/router or just sign in to the control panel and search for the option usually you can do that for example using this link:
http://192.168.1.1
The MTU is the maximum size that an IP-packet that is transfered across the internet may have just for general information.
I hope this helps.
Kind regards,
Wilhelm@Xboxexperts.com
Feb 26, 2009 | Microsoft Xbox 360 Console
Can't coonect my Xbox 360
Hope your still there... what its telling you is that you need to change the settings on your router go to internet explorer type in 192.168.1.1 and login go to "WAN SETUP link on the LEFT" change the MTU value to 1500 hit apply or save and that's it Good Luck ;]
Jan 31, 2009 | NetGear WGR614 Wireless Router
My mtu settings are not good i need to change them , i cant connect to xbox live
I hope this helps.
Kind regards,
Dec 22, 2008 | Microsoft Xbox 360 Console
MTU con connecting. How to fix ?
What does MTU do on Xbox Live?
The MTU of your router or gateway must be greater than or equal to 1365. If it is less than 1365, you won’t be able to connect to Xbox Live.
To change the MTu login to your admin router panel:
  1. Go to start>Run>cmd>type ipconfig
  2. look for "default gateway" then type that address into your router login, usally the login is admin/admin if not look in your manual or call your router maker.
  3. Now login locate the area to adjust the MTU if you cant find it, contact the router maker, or look in your manual.
More info:
http://www.xbox.com/en-US/support/connecttolive/xbox/connectionmethods/diagnosingconnections.htm
Cam
Oct 21, 2007 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
