Question about NetGear DG834G Router
Netgear router dg834gt
Hi! i have recently changed my BT broadband router to netgear router DG834GT,i have used netgear router before on my 2 computers,it was working fine and functioning to the best broadband speed.but today i swap router and i found that the netgear is not functioning as it should be,really slow connections.so how can i amend it to get my min speed at 3mb or 4mb. i had a speed test and it is way below 1mb or 2mb.
  • damian sung Jun 18, 2007
    hi there!
    thx for ur reply. i have checked the MTU and alter to 1493 as u said.it was on 1453 before. and the downstream connection speed is on 416kbps...and upstream connectionn speed is on 448 kbps.
    so is that fast enough?? is it like what i should get under 2or 3MB speeds??
    cos when i sign up with BT broadband it said i will get up to 8MB...depends where i live or near the exchange...i want to make sure that i am getting a least 3MB speed. so am i getting that??
  • Anonymous Aug 19, 2008
    hi i recently got a netgear router dg834gt and everything seems to be fine apart from that i cant sign on aol anymore it wont let me connect to the internet
    any advice
    President:
  • 2,961 Answers
Have look in the router settings for the actual internet connection speeds, as these are a more true reading than the speed check as the speeds can vary at different times of the day and 2 or 3 speed checks can bring different results. your actual connection speed that is showing in the routers settings is the connection you are getting from your ISP. If you are with BT they usually recommend using their latest routers, why i'm not sure, as the only thing i have noted is that the MTU is set at 1500 (Maximum Transmition Units)and in other routers the MTU is automatically set at 1493, so look for the MTU setting and up it if necassary, but not above 1500, also double check all the settings, even put the bt router back in and see if speeds improve, if, you know the BT router is set up purposly for faster connection speeds. Also try checking your speed at a speed test site at a quieter time of day, you will also see different speed check sites give you different speed results.
Posted on Jun 18, 2007
SOURCE:
HOW DO YOU CONNECT A BLACKBERRY PLAYBOOK TOA NETGEAR DG834GT ROUTER?
Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jun 15, 2012 | Computers & Internet
Instructins for netgear DG834GT
Use the following link to download documentation and firmware updates for this product.
http://kb.netgear.com/app/products/model/a_id/2328
Dec 06, 2010 | Computers & Internet
Does the netgear dg834g work with sky broadband
Thats an ADSL modem/router, so would be used via the telephone line In fact this is the standard router often supplied by SKY DG834GT
theres a number of answers here on the sky site for setting up a router http://www.sky.com/portal/site/skycom/skyhelpcentre/producthelp?nodeId=25126ec2-287b-4e70-9014-967423a8dbf1
sky users tutorial for setting up a router http://www.skyuser.co.uk/forum/view-router.html
Mar 19, 2010 | NetGear DG834G Router
How do I disable my DG834GT router firewall?
The router firewall only blocks connections coming from the internet.
Basically it only lets an outside IP connect to your network if you establish the connectoin FIRST.
The most common cause of not being able to see another PC on the LAN is not having the same workgroup name.
Go to Start > My Computer , right click > Properties > Computer name. Make sure all PCs have the same workgroup name.
Mar 05, 2009 | NetGear DG834G 802.11G Wireless ADSL...
How do I install a netgear adsl modem router dg834gt
no you can't use the belkin usb 10/100 ethernet adapter CD to install the netgear adsl modem.
click here to download the installation manual for the netgear device
Sep 09, 2008 | NetGear DG834G Router
Connect netgear DG834GT to laptop - says limited connectivity
how do i connect the netgear dg834gt to my computer please help
Jun 29, 2008 | NetGear DG834G Router
Netgear ADSL super G wireless router
I hope this will help you to solve the problem...
http://www.jjclements.co.uk/index.php/2007/09/30/sky-router-dg834gt-unlock/
Apr 27, 2008 | Computers & Internet
NetGear DG834G Router Logo
383 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
