Question about JVC AV-60D501 60" Rear Projection Television
JVC AV-60D501 I belive it is a 60" full screen projection tv for the last few months the picture has been flickering, Flickering like a VHS with bad tracking. It does this in all imputs, from cable imput to rca, to composit. it started out at 5 inches from the top, now is about the 1st 10 inches from the top and sometimes full screen. It seams to do it more when there is bright blue on the screen but my wife says when im at work it does it with no blue all the time. I have turned the Brightness to IRES and color temp to med witch seams to help a small bit but now the screen is to dim for daylight hours. Please help me
  • randy White Jun 18, 2007
    Forgot to mention, That this problome comes and goes. Its dosnt do it all the time, sometimes days apart,and it can do it from a cuple minuts to hours on and off.
  • h_stein2002 Sep 21, 2008
    My JVC will not turn on. The timer light will not stay on.
  • 934 Answers
From what you're describing your focus block is probably failing JVC p/n#129P059050. It's probably also very vibration sensitive. They're about $80.00 dollars and they are also interchangeable with the Mitsubishi focus pack p/n#920p016010. Not a difficult repair - we do about 5-6 a month. Real easy in-home repair. Hope this helps. Bill
Posted on Jun 20, 2007
SOURCE:
JVC AV48WP30 Projection TV..Half picture distorted and flickering
Ur convergence is dead.Must replaced the 2 convergence ICS and all it resistors.The shop will cost U $300 for parts and parts.
Feb 10, 2010 | JVC AV-48WP30 48" Rear Projection...
JVC AV 60D501 H hold ?
What do you mean jumping, or does the picture look like it is in 3-D?
Aug 10, 2007 | JVC AV-60D501 60" Rear Projection...
TV SHUTS OFF AFTER A FEW MINUTES
Very likely to be a heat issue, the first thing to do would be to clean the ventilation slots in the back.
Feb 28, 2009 | JVC AV-60D501 60" Rear Projection...
JVC AV-60D501 will not power on.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
Mar 24, 2017 | JVC AV-60D501 60" Rear Projection...
JVC NV-50D500 Flickering
convergence board problems u will nedd replacment soon
plz do rate this post
Nov 30, 2008 | JVC AV-48WP30 48" Rear Projection...
AV-60D501
There is a 5, 9 & 12 volt dc regulator on the chassis that could be causing this. Three legged transistors on small heat sinks. I f you look at the chassis from the rear of tv, is two boards.The one on the left has these reg. transistors. Usually the 9v regulator is bad and a 35ufd @ 50v capacitor near it is bad. From the tuner as ground check the third leg on the regulator for less than 9v dc.
Jun 18, 2007 | JVC AV-60D501 60" Rear Projection...
Television Won't Power On
Could be an open internal fuse or power supply failure
Oct 08, 2017 | JVC AV-60D501 60" Rear Projection...
JVC AV-60D501 60" Rear Projection Television Logo
337 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
