Sony KDF-E50A12U 50" LCD HDTV Logo
Lee Johnston Posted on Dec 23, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kdf-e50a12u audio No sound from speakers?
Anonymous
Level 3:
Top Expert:
  • Sony Master 14,553 Answers
  • Posted on Dec 23, 2012
Anonymous
Sony Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2716288
Points
48227
Check speakers in main menus are not switched off or to external.
check to see if have sound when something (DVD etc) connected to a rear audio/video input.
5 Related Answers
Anonymous
  • 668 Answers
  • Posted on Jul 21, 2009
SOURCE: dull dark picture on kdf-e50a12u rear projection
Depending how long you have owned it and if a Lamp was ever replaced, it probably needs to be replaced. You can check with SONY at
1800-222-SONY and see if they could sell and send you one.
Hope this helps,
Skyassoc
Anonymous
  • 4 Answers
  • Posted on May 18, 2010
SOURCE: is it an easy fix to replace the bulb on a Sony
Indeed it is easy to replace the bulb, unplug the TV first, simply remove the outer cover door, then you need to remove the protective inner door, simply place your finger in the ring pull and lift gentley up and pull, when you have the replacement bulb you need to remove the 2x screws on each side holding the fixing brackets then remove the screw that is located at the bottom where the bulb wires are, once removed then you can remove the casing, undo the retainer bracket screws for the bulb and also disconnect the wires from the bulb, DO NOT touch the new bulb with bare hands you must use rubber inspection gloves as your skin oil will damage the lamp, fit new lamp and re assemble housing and re-fit making sure you rerplace the inner door correctly.
Anonymous
  • 10594 Answers
  • Posted on Jun 28, 2011
SOURCE: kDF-E50A12U MY TV KEEPS TURNING ITS
When did you replaced lamp last time in tv?
If lamp has not been replaced in last 2-3 years then it seems time to get it replaced to solve the tv problem OR let me know does red standby light blinks when tv shuts off?
Thanks.
Anonymous
  • 14553 Answers
  • Posted on Apr 18, 2012
SOURCE: reset the lamp hours on KDF-E50A12U rear projection HD
A quick call to Sony customer service with the model number will answer this and I looked but it is not in the owner manual for this set.
Anonymous
  • 14553 Answers
  • Posted on Nov 04, 2012
SOURCE: sony kdf e50a12u New bulb but until tv has warmed up (10 min.) it intermittenly loses sound but not picture
The lamp of course will or should not affect the sound---next time it is cold try it on a rear input---a DVD player etc to see if same issue--this could narrow down where the problem is.
Audio out level low
Is there a "audio out fixed/variable" in sound menu? If there is, this would output 'line level audio' vs. variable level by TV volume control.
Remove screen sony KDF E50A12U
This is a DLP and the screen unit may only be sold with all of the screens(it will have up to three). Not in most cases a do it yourself task, most of these the entire screen unit needs to be removed, screens are attached from the inside of the frame unit there.
You may be able to Google the model number for a service manual which if found would have a exploded view showing the best way to do this.
Sony kdf e50a12u New bulb but until tv has warmed up (10 min.) it intermittenly loses sound but not picture
SONY KDF-E50A12U TURNS ITSELF OFF AND FLASHES POWER LIGHT RED 4 TIMES HELP PLEASE
the 4 blinks on that model are indicating the set isnt starting due to a problem with the fan,
I have a sony kdf-e50a12u tv and the picture is dark. i have tried to adjust the settings but its still dark what could the problem be
Hello hmt86,
Welcome and thank you for using FixYa!
This is the backlight bulbs or the inverter board that powers them. Both will need tested, hopefully only the inverter board will need replaced.
Have a great evening!
2helpful
Sony bravia KDF-E50A12U rear projecion tv wont turn on
Hi it sounds like it could be an issue with board that powers the lamp ,it's called the ballast.When you put a new lamp in the ballast has to provide more power ,when it starts to go weak it will not light up.Sometimes you can put your old lamp in and will work fine.Try partstore.com they might have it right there.Hvae a blessed one!
2helpful
Dull dark picture on kdf-e50a12u rear projection
Hope this helps,
Skyassoc
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
