Question about Dell XPS 400 PC Desktop
I have fixed the memory problem so far...I did what the dell site asked and troubleshot it. I removed the memory and reinserted it and then powered back up and it work... However, My question now is what got me to this problem. I had recently installed a new piece of hardware and software. The blue screen was half cut off and all I could make out was that a recently added driver might have been corupt. So after all this I went in and uninstalled the new program. Should I also do a system restore as well to be on the safe side? My CPU has been operating fine longer than before. Would it be wise to try and attempt to reinstall the program and hardware it was purchased legit and is licensed. Thanks for all your help...
  • Dell Master
  • 998 Answers
Do you have any CD’s that came with your computer? If so, look for one that has “Diagnostics and utilities” listed under the “Contents”. You will have to boot from that CD disk. To do this, power on your laptop and tap the <F12> key to bring you to the “One time boot menu”. Insert the CD and then select CD/DVD drive and hit <Enter> key. Select the “Run the 32 Bit Dell Diagnostics”. Next select the “Express Test” and see if any errors are detected. If all tests pass, you can try installing the new hardware and software again.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Jan 16, 2009
My laptop DELL Inspiron 6000 on which I am running Windows XP. Its hanging very frequintly
Hello.
Typically, the problem is with the operating system or memory.
First, boot your system and press F8 repeatedly. Access Safe Mode and login. Choose System Restore and select a date before your system started to freeze. Note that your system updates will go back to that date.
If still a problem, disconnect all cables. Remove the battery. Remove the memory cover. Remove and reinsert the memory modules (they are removed and reinserted on a slant). If multiple modules, test one at a time.
Hope this helps.
Apr 12, 2011 | Dell Inspiron 6000 Notebook
Memory write/read failure at 000510784, read EA05E805 expecting EA05E805 . To resolve try to reseat memory.
Hello.
To reseat the memory modules, disconnect all cables and remove the battery. Flip the laptop and remove the memory cover (has one screw). Remove the module(s) on a slant. Reinsert in place. Replace the memory cover. Insert the battery. Connect the a/c adapter and power on.
If you receive the same error, replace the memory. Can be found on the Dell site.
Hope this helps.
Feb 27, 2011 | Dell Inspiron 1525 Notebook
Dell Optiplex GX520 has flashing amber power light. Ordered another power supply & replaced, still flashing. No fans going. I disconnected USB cables and all other connections to MOB & removed...
MAIN BOARD is deffective .....approach service engineer to check whether mainboard can be repaired or not ......iam service engineer (computers, laptops, printers, etc...) - bangalore - domlur- 09986222774 - sathyavijayasarathibabu@ymail.com
Feb 15, 2011 | Dell OptiPlex GX520 PC Desktop
Dell E521 blinks on and stays powered up but does not start start up sequence can't F12 or anything as it does not get that far
Just had similar problem with optiplex 755. Solved problem by resetting bios. Remove power cord. remove bios reset jumper. (check owners manual or dell website for the location) Dell says to remove for 5 seconds and replace to reset bios. I find this to be incorrect. I had to unplug cord remove jumper, plug cord in, restart, shut down, unplug cord replace jumper, reinsert power cord and restart. Had to change a few configs in bios based on computer configuration after restart. Hope it works for you. Seen same problem on optiplex 750 and 755 in last week.
Jan 21, 2010 | Dell Dimension E521 PC Desktop
My Dell Inspiron 1520 will not load anything past the first Dell screen. It loads Dell then goes black with a flashing cursor in the top corner, I have tried pressing F8 to do a system restore but it never...
Hello, Beth.
The most common reason is memory. Try reseating (remove and reinsert) the memory, first.
Power off the computer and disconnect all cables. Flip the laptop to the back. Remove the battery. The memory cover has 8 screws. Remove the memory modules at a 25 degree angle and reinsert them by pushing them down firmly by the ends.
If reseating the memory doesn't solve your problem, one module may be bad. So, remove and test each module one at a time.
Hope this helps.
Nov 23, 2009 | Dell Inspiron 1525 Notebook
Booting
Try removing the memory and the reinserting the memory. The problem sounds like you might have a bad motherboard, but I would try and remove the memory and fix it that way. Or you can get into bios F1 and see if it is recognizing your HD, or stick the installation disk in the computer and see if you can get anything to boot that way. If the computer boots from the CD replace the hard drive
Feb 10, 2009 | Dell Dimension 2400 PC Desktop
Possible to increase RAM on Dell PR03S?
Your best bet on upgrading the RAM in your laptop yourself is to contact a dell representative and ask for advice on this. If i am correct you can buy laptop RAM from any computer hardware shop/website. I hope I helped.
iSpearz.
Jan 19, 2009 | Dell Latitude X200 Notebook
Unlock Memory Card
take the card to a mobile center and ahve them removed the code for you
Jul 08, 2008 | Nokia 6233 Cellular Phone
Dell D620 Won't POST
If two of the three leds are flashing (the one on the left stays solid and the two other blink) then this is a no memory error and its likely the memory is not seated properly.
Remove the memory from under the keyboard and try one DIMM at a time in the slot on the back of the computer. Once the PC is booting again reintroduce the DIMM under the keyboard. Like the previous poster indicated the memory needs to be well seated.
Worked for me...
May 15, 2008 | Dell Latitude D620 Notebook
Memory location Dell inspiron 2200
The memory inside is fixed but there is an open slot . Just open the access panel on the back and the slot is there. You can add up to 1GB
May 02, 2008 | Dell Inspiron 2200 Notebook
Computers & Internet Logo
54 people viewed this question
Alun Cox
