Question about Jabra BT350 Bluetooth Headset Headset
I have a Jabra set, but my Motorola Krazer can not find it
No Blue tooth seems to be working on this phone
  • spasongs Jan 16, 2009
    Thank you very much Chris!! I really appreciate it. So does my Wife!
    Cheers
    Jeff
  • 827 Answers
Follow the steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for around 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Jabra device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the phone
Hope this helps
Chris (ziraffa)
Posted on Jan 16, 2009
  • chris grams
    chris grams Jan 16, 2009
    You're welcome, I'm glad to help!
How do you pair blue tooth to Jabra VBT185z
it auto pairs .
set mobile phone to bluetooth on
finger click on blue tooth and select discover bluetooth devices
you should see mobile phone detect jabra vbt185z
then pin is 0000 if asked
http://uswww03.gnnetcom.com/jabra/verizon/vbt185z/Datasheet_VBT185z.pdf
Oct 19, 2015 | Jabra Radio Communications
I need to pair my bt2050 up to a new phone,it was originally paired wit another phone that i do not use anymore,im using a nokia x3 now and when im trying to find and pair up it says there is no device...
Hi Barbara,
Please follow the below steps, i hope your problem is resolved :-
  1. Make sure that your phone's blue tooth is out of hidden mode and , it now shows up as shown to all, in the connectivity settings.
  2. Make sure that you delete the pairing from the other phone , via it's blue tooth settings, if you are not using the phone and it's switched off , then you don't have to worry about it.
  3. Switch off the bluetooth and restart it , so that it's ready to accept new connections.
  4. Now go in your blue tooth option and search for a new paired device , it should reflect your Jabra blue tooth.
  5. If the above method does not work , sadly your phone does not support the Jabra blue tooth.
  6. You should also try connecting this blue tooth to someone else's nokia phone to check compatibility , if it's compatible with the other models, that means X3 is an exception to this compatibility.
Hope this helps.
May 11, 2011 | Jabra BT2050 Bluetooth Headset
I have a jabra bluetooth how o i connect to my phone
You need to put the bluetooth device in discover mode, then on the cell phone, you configure the blue tooth settings to "find" the bluetooth headset. Check out this document on how to pair a Jabra (may not be your model, but bet it is the same process). Good Luck!!
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT350/Documents/BT350_UM_NA_EN_491.pdf
Oct 17, 2010 | Cell Phones
Unable to make or receive calls using Bluetooth.
try to remove the Jabra Blue tooth that you have under th list of your paired devices. try to turn off the phone and blue tooth then pair it again.
Jun 25, 2009 | Cell Phones
Jabra vbt185z difficulties using voice commands
go to your phone tools and find voice command blue tooth and follow prompts . its all in the phone . the tooth is run by the phone. your blue tooth is only a reciever, the phone is the boss. good luck
Jan 15, 2009 | Jabra BT350 Bluetooth Headset Headset
Can't get my motorola verizon phone to work with blue tooth
Go to menu. Click on setting. Scroll down to connections. Then click on sync. The pin is four zero's.
Dec 30, 2008 | Motorola Mobility HS810 Consumer Headset
Jabra and Krazor problem
on jabra try holding vol butten and talk swich hold it till it blue light stars continue and then try surching in ur phone reply me
May 18, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Jabra BT350 Bluetooth Headset Headset Logo
70 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
