Question about Kenmore Elite 45986 Front Load Washer
Door locking mechanism keeps breaking
I have had my machine for about 7 years. For the third time, the small, narrow, black plastic mechanism that when the door closes locks the door has broken off. Each time, someone has to come and repair it, it is approximately $200. I like my machine, but am getting very frustrated with the delicate device. The newer models have a larger button that doesn't break off as easily. Any advice?
  • 640 Answers
Just and idea,,,put a little flat rubber or cushion pad between the door and the panel so door dont close so hard,,and tight,,,onthejob
Posted on Jan 20, 2009
You must close the door hard or it will not start
The locking mechanism is not closing completely unless you slam the door because the plastic parts don't slide easily after a couple of years. We found that putting a small amount of vegetable oil on the 2 locking hooks in the door will allow the components to slide easily and close properly so the machine will function correctly.
Mar 02, 2014 | Panasonic Microwave Ovens
Maytag Neptune washer front load- Can't open the door
Take out the bleach and softener tray (it just lifts out, angle it a little) and unscrew the 4 bezel screws and take out the bezel. You will find a red or green plastic pull line that is supposed to release the door. You may have to "man-handle" the door a bit and pull hard on the line before it will release. Once you work on the door release mechanism (I had to replace the wax motor again, even though it was the "upgrade" black plunger type) I recommend shooting a little silicon spray on the white plastic moving parts of the locking mechanism to get them to move more easily.
This is true on a Maytag Neptune MAH3000AWW front loading washer. Mine is 11 years old, and had the initial wax motor work done at 7 years.
Jun 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
93 jeep door lock Broken
It might an easy fix...
I had the same problem and it ended up that it only was a metal rod that was unhook from mechanism...
-undo your inside panel by pulling on it
- check the mechanism...
Be careful there is some small plastic pieces that breaks easily after 15 years of life!
hope this helps!
Mar 27, 2009 | 1993 Jeep Wrangler
Door lock wont engage
YOU MAY HAVE BROKEN THE BUTTON, A SMALL PIN LIKE PUSH BUTTON THAT PUSHES IN TO LET THE DOOR LOCK KNOW THE DOOR IS SHUT. YOU CAN USUALLY FIND A SMALL DIAMETER OBJECT LIKE WHAT IS IN A RETRACTABLE BALL POINT PEN TO SLIP INTO THE HOLE WHERE THE BROKEN PIN IS AS A TEMPORARY REPLACEMENT AND TO CONFIRM THIS IS ACTUALLY THE PROBLEM. IF IT IS, YOU WILL NEED TO REPLACE THE DOOR LOCK ASSEMBLY FOR PERMANENT REPAIR. DON'T SLAM THE DOOR SHUT BECAUSE THESE PARTS ARE MADE OF PLASTIC AND BREAK EASILY!
Jan 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Honda pilot door locks
It is because the door actuator is bad in those doors.
Replacements can be found at the dealership for around $60 or on Ebay for as little as $10. Number 5/24 in the diagram below. Actuator part # Left Side 72155-S5P-A11 & the Right side 72115-S6A-J01.
Expect to set aside at least 1-2 hours on the first replacement, lesser time on the ones afterwards. Be careful not to push parts in directions that they shouldn't be pushed in. Don't break any plastic parts/metal rods or connections - take your time.
1. Remove the plastic tab under the inner door latch.
2. Open the 2 small black colored screws.
3. Carefully swing the door latch attachment out by moving it down and out. Remove the rod and the electrical connection - there's a slot to press and pull-out.
4. Use a flat screw driver to carefully pry the window opening plastic area (its one piece and includes the cup holder). Remove the electrical connection - there's a slot to press and pull-out. Open the screw beneath the arm rest.
5. Use a flat tool (I used a metal putty 5-in-1 tool) to slide between the door metal and plastic areas - pull the plastic buttons/connections off, you'll hear them pop. Slide the door out.
6. Gently open the white plastic sheet about a quarter of the way from the top right down so you can reach in the actuator area (near the door latch - at the end of door with 3 screws). Remove the window guardrail, if its in the way - use a 3/8 bolt.
7. Use correct amount of force, without stripping them, open the 3 screws at the door latch.(Best to use a Handheld Impact Driver)
8. Take a good look at the connections inside. Disconnect the electrical connections (two of them) on the lock actuator.
9. Gently but forcefully (without breaking any plastic or other parts), push the metal connectors back and carefully remove the door lock actuator assembly from the door.
10. Replace with new actuator and assemble in reverse.
Nov 24, 2008 | 2004 Honda Pilot
Kia Door Handle
Remove the door trim inside by loosen 3 bolt with screw driver, then pull out the door trim, after that loosen the hex.bolt (3 hex-bolt) on lock mechanism bracket, after that you can loose bolt (4 hex bolt) on handle cover. Be careful to not drop the bolt, because the gap on sliding door is too narrow. After you removing the handle assembly you can see where is the broken. You can remove the handle from cover by removing pin clips on it. To fixing the broken handle you can just using plastic glue or you can drill a small hole and put some small wire to reinforce the plastic.
Oct 16, 2008 | 2003 Kia Sedona
Mazda 2003 MPV door locks
I just fixed this same problem. It happened to me 3 different times in a month so I got good at it. Before you dive into removing your door try this. Pull the door handle and release it letting it snap back several times. The problem is a half open door latch that won't let the door unlock. Do this as aggressively as you can to attempt to get the latch to return to its original position. Check the door lock between flicks.
Ok, if that didn't work, here is how to remove the door.
1. Remove the screw behind the door latch, you will have to pop the plastic cover off first.
2. Remove the rubber insert in the door handle
3. Remove the screw that is now visible
4. Now remove the window/lock control module, the back is free but the front has a plastic lip so lift the back up and pull towards the back of the van.
5. Remove the clips that attach to the lock and to the window controls (these can be a pain)
5. (Optional) Remove the bracket that held the window/lock control module
At this point your door is basically free, it is only held in place with plastic clips that can be easily forced off. If your door were open you would simple pull the bottom of the door out (hinged at the window) and lift it off. But since we can't pull because the door is closed we have to force it out.
From here it is pretty simple. Move the seat all the way back and tip the seat way back. Lift the door panel straight up. You will be breaking 2 plastic clips from the rear part but once you do it just pulls out. This is not that easy because the space is limited but just keep pulling and force the rear end of the door panel past the b-pillar. Once you do this it is free.
Have fun and try to keep the black gook from getting everywhere.
Oh, to fix the door lock just oil/grease it and manually move the mechanism several times.
Sep 20, 2008 | 2003 Mazda MPV
2000 Dodge Caravan Rear Door Latch
I had the same problem and fixed it using the following steps. I am not an expert or even very mechanically inclined, just desperate to get this fixed without spending any money. This was done on a 1996 Dodge Caravan. Similar steps should apply to a number of years of the Caravans and Voyagers.
Two people will make removing the panel easier. To do this, you'll need a phillips screwdriver, penetrating lubricant, and pliers.
First, if you cannot open the door at all: There is a small plastic disc plugging a hole just above the latch on the inside. Pop out that disk, and use a screwdriver to lift the latch mechanism. It should not take a great deal of force to move the latch. When the latch moves, push the door and it should open.
1. Remove the plastic panel on the inside of the van. You need to remove the handle and several screws on the perimeter of the door.
2. Disconnect the interior door lights by gently pulling the wiring harness (two of these).
3. Looking at the door from the interior, there is a small electronic plunger mechanism on the right side with an "accordion" (this is the electric lock). There is a rod that goes from the to the middle of the door, just above the lock mechanism. Another rod goes from the key lock to the latch. This rod, threaded on one end, snaps into a small bracket on the latch. It may need to be snapped back in. There may also be a rubbery/tar-like sticker near the locking mechanisms that can be removed (it can interfere with some of the moving parts).
4. Manually operate the plunger on the electric lock several times using pliers. Mine was extremely stiff. It should move the rod at least a full inch.
5. Spray lubricant on the latch, the back of the key lock, and the back of the exterior handle. Also spray lubricant into the key lock itself (where the key goes). Do NOT spray lubricant on the electronic lock mechanism or plunger.
6. Just above the latch, there is a small hole (only about 1/8" around). Carefully and liberally spray lubricant into that hole in every direction (this is where the rods from the key lock, electric lock, and latch meet). There is a white plastic post that comes out through another nearby hole. Spray lubricant liberally into that hole, too.
7. Again, manually operate the plunger on the electric lock several times using pliers. It should be considerably smoother to operate.
8. Put your key into the key lock and pull it out several times.
9. Spray lubricant into the key lock again, then carefully operate the lock with the key. If it didn't work or was stiff before, it should operate much more smoothly. Operate the electric locks several times.
10. When operating the lock, you should see the plunger on the electric lock move to its extents (at least an inch). Watch it when using a key and using the electric lock.
11. Check the movements of the rod and plunger when operating the lock, and the movements of the latch when operating the handle (when unlocked). If anything is still really stiff, use some more lubricant and operate the lock and handle again.
12. When reassembling the door panel, remember to plug in the two wiring harnesses for the interior lights.
I hope this helps!
Jul 06, 2008 | 2000 Dodge Caravan
My fromt loader buzzes while running.
Try some WD40 on the mechanism of the lock, not on door. And open & close a few times, while disconnected from the mains.
May 11, 2008 | Frigidaire GLTF1670A Front Load Washer
Door locked
Unplug washer or disconnect power for at lease two minutes. EEPROM ERROR A communication error between the Central Control Unit (CCU)and the EEPROM onboard the CCU occurred. Possible Causes/Procedure ■ A power glitch may cause this error. ? Verify CCU operation by running a Diagnostic Test or any cycle. PUMP DRIVE ERROR The pump driver fails to activate. ■ Replace CCU board. MAIN RELAYS ERROR ERREUR - One of the main relays is not working properly. Possible Causes/Procedure ■ The relay might be soldered or always open. Replace CCU board
Sep 24, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
27 people viewed this question
Sal De
fordexpert
Robert Rankin
