Question about Maytag MER6772 Gemini Electric Kitchen Range
Maytag Gemini Double Oven-bottom temp problem
Top oven works fine--when setting bottom oven to auto temp of 350 the temp doesn't go pass 150--went to 225 once, but now only goes to 150--replaced heating element last year, it wouldn't have gone out already?
  • 1 more comment
  • chad dieman Feb 24, 2013
    I have the same oven. The oven is only 14 months old. From other web sites it sounds like a control board. WTF. I spent alot of money for this and now it's no good. It would'nt feel so bad if it was 10 years old. Not willing to spend $450 on a new stove. Will not buy another maytag item in this house.
  • Anonymous Mar 26, 2014
    Oven will not heat higher than 150
  • Anonymous Mar 28, 2014
    This Maytag Gemini model # MER6872BAW top oven works fine but the bottom oven won't heat up past 150 degrees. I don't know if it is a bad element in the lower oven or if there is a bad sencor. Is there a way to check the element to see if it is bad
After power outage clock on oven will not set unless the oven itaelf is on unable to set clock
Posted on Jan 28, 2009
I have a defy Gemini gourmet double oven. The top oven works but no light. The bottom oven there is nothing not even the clock is working. What could be wrong and how do I fix it?
First check and make sure you are not in Sabbath mode in the manual. if you are not in that mode then most likely your oven went over temp and the thermal fuse shorted out. You would need the fuse and most likely a temp sensor because it went over temp. I am not there to do tests but that is what is most likely.
Jan 18, 2016 | Ovens
The top oven only heats up to like 150. Is it the heating element for the top oven? If so is it hard to exchange?
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jul 27, 2011 | Maytag MER6772 Gemini Electric Kitchen...
MAYTAG GEMINI model MER6770AAW Fault code F1-L -same code for upper and lower. After reading other comments, it appears that the temp sensor(s) are bad. I need to find part #'s and cost. Thank you Pete
Here's a late response, hopefully helpful to someone... I had the same issue with same model Maytag range. I pressed the CLEAN option on the touchpad (bottom oven) and that option seemed to work. I pressed Auto Set and I let it go through "remove oven racks" until the display panel read 100 degrees and then pressed CANCEL. About 30 seconds later, when the oven was out of "clean mode," I pressed BAKE, then Auto Set, and it's been working fine ever since...
I'm sure the sensor needs replaced and will go permanently sooner or later, but if anyone out there gets the F1-L code but hopes to at least temporarily revive your oven maybe this will do the trick.
Feb 15, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Lower oven does not get hot.
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Jan 17, 2010 | Maytag Gemini 30" Self-Cleaning...
Bottom oven does not heat
i ceertainly think that there is problem with the burner. as per the working principle of an Oven the ignitor is doin its job so the problem is with the burner please do check it out...
Nov 25, 2008 | Maytag MGR6772 Gemini Gas Kitchen Range
Heating
i would first check the lower units bake element , usually a visually inspection is enough to determine if its good or nor, usually a burn mark can be seen on the element itself, and if you can even see the element the bottom f the oven cavity will lift off for better inspection
Mar 25, 2008 | Maytag CWE5800A Electric Double Oven
Maytag MER6772 Gemini Electric Kitchen Range Logo
1,100 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
