Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Will light up and then gives flame LED - Reddy Heater-170,000 BTU Kerosene Deluxe
  • lynns001 Jan 16, 2009
    Trys to come on then puff out smoke, LED lights up flame!
  • 92 Answers
Flame sensor is bad. you can get one from Mr. Heater that will fit for 3 bucks or get the actual replacement part from reddyparts.com for 18. wires don't matter just splice it to your old wires.
Posted on Jan 23, 2009
Error code= two red flashes, lockout/ no flame
Trane XV80 hard lockout, 2 flashes, Can't be reset - DoItYourself ...
www.doityourself.com > ... > Gas and Oil Home Heating Furnaces
Jan 10, 2013 - The only way I can get diagnostic Red LED light to reset is to switch ... a2 flash with absolutely no operation from the furnace does seem to ..... inducer gets a demand you should get a pressure switch error code 3. ... the flame sensor wire and giving the furnace a heating demand after resetting power twice. Luxaire Furnace Blowing Cold - 8 Red LED Flashes
Mar 1, 2010
Winchester furnace diagnostics
Feb 14, 2010
American Standard Freedom 80 - Cold Air - Getting Error Code 9 ...
Nov 20, 2009
York ignition lockout due to retries
Dec 29, 2008
More results from www.doityourself.com
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
cause this fault. 2 RED FLASHES: This indicates that thenormally open pressure ... The furnace will lock out for one hour and then restart. 7 RED FLASHES: This fault code indicates that the flame could not be established. This no-light ... problem. Bothheating and cooling operations will be affected. Check
Jan 23, 2016 | Heating & Cooling
Dimplex dakota heater is working but flame effect is not its led I think not bulbs.
Says you can turn it on and off? Did you knock the switch?
Can I operate the flame effect on the fire without the heat?
All our Optiflame and Opti-myst fires can be operated on a flame-effect only setting, as can the flickering flame effect on our freestanding bar fires.
Is the flame effect expensive to run?
No, to run the flame effect involves powering light bulbs and a small electric motor and in most cases costs no more than a couple of pence an hour. Some of our fires have LED lamps fitted which are even more energy efficient.
Some have bulbs, some have LED.
Example calculations:
Using UK standard average price of electricity of 14p/kWh (source: Energy Saving Trust Feb 2015)
Optiflame LED flame effect only (eg Danesbury) = 0.1p every hour
Optiflame conventional bulb, effect only (eg Cheriton) = 2p every hour
Opti-myst, flame effect only (eg Oakhurst) = 3p every hour
Opti-V single screen = 0.5p every hour
2kW fan heater, on constantly (no thermostat) = 28p every hour
Optiflame lightbulbs for sale. Remove the coals and check for bulbs.
https://store.gdcgroup.co.uk/dimplex/products/index.htm?product_code=FP03022
Dec 23, 2015 | Dimplex Heating & Cooling
Protech 62-24084-02 troubleshooting
62-24084-02 LED CODES
POWER LED - GREEN
ON - Normal
OFF - No power to board
OK LED - GREEN
One Blink - One hour retry delay
Two Blinks - Pressure switch failure (remains open)
Three Blinks - Limit switch fault
Four Blinks - Pressure switch failure (remains closed)
Five Blinks - Twinning fault
FLAME LED - YELLOW
ON - Good flame
Rapid Blink - Flame present with gas valve de-energizing
Slow Blink - Marginal flame
Jan 01, 2014 | Protech Rheem/62-24084-82-1PK - Integrated...
Lennox 80uhg3-75a-3 igniter sometimes doesn't light , left LED slow flash, right LED solid.
Should be a trouble code on the panel or in the literature book that came with unit. More than likely it's on the inside or outside of the blower panel. This will indicate Red light on Green light slow flash = what trouble code or issue it's having. Most common problems with a gas furnace is the flame sensor needs cleaning. There is a little rod that sticks down into the flame when the burners ignite. It's the only thing the flames will come in contact with besides the furnace itself. It will have 1 wire connected to it. Clean that rod with a piece of light grit sand paper. Don't take much force to clean it so try not to damage it by shining it to look like new. Cycle and see if it will hang in there. Hope this helps!
Sep 17, 2017 | Heating & Cooling
I have a Goodman GMP 125-5 furnace. It had a 3 light code i replaced the presure switch now it is giving me a 1 light code please help
A sampling of various failure codes on a furnace:
Read one LED flash that stays on continuously to mean your furnace has no signal coming from the thermostat and will not operate. Turn the power off and check the thermostat for improper settings or connections.
Interpret one LED flash that blinks on and off to mean your furnace has locked out because it could not ignite after three tries, and must be reset. Interrupt power to your furnace for 20 seconds or lower the thermostat so your furnace does not try to heat, then reset the thermostat to the previous setting. After one hour of lockout, your furnace will automatically reset itself and try to operate as usual.
Decipher two LED flashes to mean the draft blower is not working, or your furnace has a short in the pressure switch circuit. Turn off the furnace power and repair a short or replace the pressure switch.
Read three LED flashes to mean your furnace has an open pressure switch circuit or it has an induced draft blower operating. Check the pressure switch hose of your furnace for blocks or an improper connection. Also, look for blockages in the flue, and tighten any loose wiring.
Translate four LED flashes to mean your furnace has a primary limit circuit open, possibly from loose wiring or blocked filters. Check and clean filters, tighten wiring and check the flue for blockages.
Interpret five LED flashes to mean your furnace senses a flame without a call for heat. This could be from a gas valve closing slowly or a burner flame lingering.
Read seven LED flashes as a warning of a low flame sense microamp signal. This could happen with a coated flame sensor or a lazy flame from poor gas pressure. Turn off the power and adjust the gas pressure according to the information on the rating plate.
See eight LED flashes as meaning an igniter circuit problem due to a bad igniter or an igniter connected improperly. Replace the bad igniter or check the ground wiring, making necessary corrections.
Decipher nine LED flashes to mean the high-stage pressure switch circuit will not close during a high-stage-induced draft blower operation. Your furnace may have a pinched or blocked pressure switch hose, a blocked flue or loose wiring.
Read continuous flashing on the LED to mean your furnace has a reversed polarity of 115 volts. Turn off the power and correct the wiring polarity after reviewing the wiring diagram.
Oct 28, 2011 | Goodman Heating & Cooling
Ignitor bar lights, flame comes on, blower motor runs, but flame goes out. Is this a problem with the flame sensor?
Junk builds up on that sensor. Making it not sense as QUICK as it once did. Use a dry brillo pad to clean that dude up. Video:
Electronic ignition old school pdf
Jan 29, 2011 | Heating & Cooling
I have a Rheem Furance that has turned off. Just a few hours ago the main fan turned off. The Furnace doesnm't light even the draft fan does turn on and then the main fan blower motor turns on. I can hear...
You will need to reset the furnace by turning the power off to it. Then as the furnace tries to light, watch the LED for blinking. Hopefully it will give a code other than 1. Try checking the air filter for blockage, make sure all hoses are free of moisture and any drains are not blocked. Check the air intake and exhaust pipe for sags where water could block it.
The sequence of operation is this:
Thermostat calls for heat, the LED may blink telling you it registers the call. The inducer (exhaust) blower starts closing contacts in the pressure switch (small disc shaped thing), the igniter glows orange (seen thru a small window high up on furnace front), gas valve opens allowing main burner to light, flame travels to all other burners, flame rod senses flame within a few seconds and keeps gas on. Room air blower starts within 90 seconds.
Any deviation or delay in this sequence and it goes into lock-out.
Jan 22, 2011 | Heating & Cooling
I have a Goodman GDT045-3A heater and the burner is cycling on and off. The error / control LED is on constantly. Turn the heater on everything starts up and after 3-5 minutes the burner shuts down then...
Hello ,
"Usually" a faulty flame sensor will cause the unit turn burns off and on. The furnace usually goes through its start up and burners turn on as they should then if the flame sensor/rod doesn't to sense anything and the furnace doesn't get a signal it will usually cut the burners off and re-attempt the burner sequence again because it looking for that signal from the sensor. The flame sensor is usually located opposite of the ignitor. The flame sensor/rod is usually in from of the burner. Sometimes you can get away with "GENTLY" cleaning the flame rod with some sand paper since its always in direct contact with the flame. Try to get it looking nice and new but do clean too hard as it may break which Iv seen. Make sure you turn off power to the furnace before working on it. Work safe.
Now, as for the LED error light. Usually the owners manual will have something in the troubleshooting section referring the the LED error lights. Perhaps it may have a different issue which corresponds to the LED indication. I would start here first to get you going in the right direction. If it does mention something about the flame sensor/rod then proceed to do the above that I mentioned. Worst case scenario if it does mention this, you will need a new one.
Hope this helps.
Oct 21, 2017 | Goodman Heating & Cooling
I get a 5 flash on the led code light
I forget what that code is...theres a sticker in the blower compartment or in your manual will tell you what 5 blinks means....typically its a flame signal error code....The flame sensor should be cleaned annually anyway to eliminate this problem...4 inches long and resembles a straight coathanger....clean/shine it up with emery cloth
Oct 24, 2009 | Goodman GDS80904BNA Open Flame Heater
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
42 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
