Question about McCulloch 26cc Gas Blower Mcb3208
Lost screw I have a McCulloch MAC 320B gas blower and lost one of the screws holding on the air filter. Where can I purchase the screw in the Northern Virginia area?
    Problem Solver:
  • 16 Answers
Whereever you got the blower should have screws
Posted on Jan 17, 2009
Main throttle adjust for MB3202 gas backpack blower?
You'll probably need to contact your local service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Jul 28, 2013 | McCulloch 26cc Backpack Blower with Dual...
I need to replace the gas bubble on a McCulloch Power Mac model 600032-54.....32cc i don't want to break the plastic ring around the bottom that holds it.. Thanks
If its a remote primer, it is sold as an assembly and just clips into the tank, if it is on the carb itself it will be retained by the metering cove of the carb held with four screws.
Jun 20, 2012 | McCulloch Garden
IS THERE A STANDARD STARTING POINT FOR AIR FUEL SCREW ADJUSTMENT IF SCREWS ARE STARTED IN CLOSED POSITION? LIKE 3.5 TURNS OUT.
A good place to start is 1 1/4 turns out. If you have to go more than 2 1/2 turns out, there is another problem. If you have 10% ethanol gas in your area, expect to be replacing the diaphragm in the carb and fuel lines every 3 years or so.
Aug 23, 2010 | McCulloch 26cc Gas Blower Mcb3208
Need to locate chain & bar oiler adjustment screw for mac 3200 chain saw
Look to the lower left side of the bar (as you hold the saw normally)--there should be a screw head in the engine case there. Check the adjustment by holding the bar tip at speed near a piece of cardboard for a couple of moments--it should throw off a thin line of oil. Hope this helps!
May 01, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Fuel Mixture Ratio Is it - 25:1 40:1 50:1
not sure if yo are changing the jets out but if your using the original screws and jets screw both screws in till they stop then turn 1 and a half turns out they try starting if it kicks and won't run then turn each screw another 1/2 turn out try starting if it runs rough adjust the gas jet a little bit till it runs smooth once it warms up give it full gas and you should get just a slight puff of black smoke to be set right, if it's too lean it will get hot and will be hard to start if it dies, if that happens then give it extra gas. once warmed up it should idle without dyeing if it dies adjust the idle screw up 1/4 turn at a time till it runs at idle without holding the gas trigger, be sure you replace the in line fuel filter and fuel line first then clean the air filter before doing any adjustments. most problems are caused by plugged fuel filter due to ethanol in the gas.
Mar 10, 2010 | Garden
There is a mixture adjustment setting problem on my MAC-320BV How do I fix it? Charlie
remove the cover on the blower there should be a filter and a couple of mixture screws that may or maynot have limit caps on them there you can adjust mixture settings. What type of carb is it Wolboro,zama ect.
Dec 21, 2009 | McCulloch 26cc Gas Blower Mcb3208
Mcculloch Virginia hedge cutter manual
mcculloch virginia mh542 hedge trimmer, fires 1st time, will only tick over roughly on full choke only then stalls when throttle applied, I have fitted new plug'cleaned air filter and new fuel mix but no change.
Nov 25, 2009 | Garden
Craftsman gas blower model #358.797130. replaced gas line and filter.Had to take gas tank out to connect line. Cannot find how to connect the carbuetor to stay on the gasket. diagram in the book doesn't...
Probably a couple of screws that you took out to access the carb from inside the air filter housing. Probably Torx head screws. You line up the carb and put the air filter housing back on over the carb, lining up the holes in the engine block.
Does this look like the answer you were seeking? Or did I mis-understand?
Nov 01, 2009 | Craftsman 4 Cycle Blower/Vac
The second hand McCulloch 120 chainsaw I purchased
I think the pre-adjust settings are to turn jets in all the way and back out 1.5 turns each. then:
You will find a Low and High adjustment screw. At idle turn the screw in or clockwise until the rps starts to decrease. Then start turning it out till you hit max idle rpms. Turn screw back in a quarter to half turn and it should be idling smoothly. Be careful here and get someone to hold saw if necessary but hold in throttle to full speed and do the same with high adjustment screw. turn it in till rpm starts to drop then back it out until you get to max rpm and it won't go any higher then turn it back in a half a turn.
Jun 08, 2009 | Standard Oregon Chainsaw Chain For...
McCulloch 26cc Gas Blower Mcb3208 Logo
125 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
