Question about Jensen VM9510 Car DVD Player
Bypass parking brake for VR3
My in dash dvd player says i can't play movies while driving. anybody know how to bypass that? i know some systems have codes but i can't find any for the VR3 4inch in dash dvd navigation system that i got at wal mart. if anyone can help me it would be greatly appreciated! Thanks...
  • sheridan_chr Jan 16, 2009
    i don't have it connected at all to the parking brake because i didn't know what wire that was. so the drown parking brake wire coming off the unit is loose from everything. where exactly would that be on a 2004 chevy blazer?
Ok take that pink wire and wrap it around the yellow rca jack and tape it well and it should work
Posted on Jan 17, 2009
    Problem Solver:
  • 7 Answers
Hi, I had the same prob with mine. Pretty easy fixed. There is an earth wire connected to the park brake switch, you have to disconnect it. If you are not savvy with car stereo installation, I would advise you take it to strathfield or another car stereo installer - it is a quick and easy job and they shouldnt charge you more than 20 bucks for it.... if that. Beware though, playing movies in your field of view is VERY distracting and dangerous..... and illegal.
Posted on Jan 16, 2009
  • findads Jan 16, 2009
    OK, pretty sure you just earth it to the chassy
Is there any way to bypass the parking break guard for a video system in a car?
If you take the wire coming from the stereo to the park brake.unhook it. From the.brake then ground if the video. Should. Play any time
Feb 09, 2012 | Boss AUDIO SYSTEMS BV7300 Car DVD Player
Parking brake
better check on your dc wiring system make sure u have fixed them tightly
Sep 09, 2009 | Pioneer AVH-P4000DVD Monitor
Putting kenwood kvt 617 dvd in rear of surburan how can i bypass parking brake so movies can play while driving
On bypasses you can either hook the parking brake wire straight to ground, if that does not work you can install a toggle switch between the parking brake wire and ground so you can mimic the parking brake on off.
Jun 04, 2009 | Kenwood KVT-617DVD Car DVD Player
Can I watch movies while moving?
There is a wire that goes to the park brake switch. That will need to be permanently grounded to bypass the security feature, but if it's a factory player, it may be integrated into the car's electrical system and may give you a park brake light on the dash if you do this. Prolly best to remove the wire from the park brake switch, and move it to a switch you create on the dask or something, that way you can turn it onn and off at will.
Apr 26, 2009 | Car Audio & Video
VR3 VRVD630 dvd bypass instructions/codes
I also just bought a VR3 DVD -CD PLAYER MODEL# VRVD630 ALL I DID WAS CONNECT THE BROWN PARKING BREAK WIRE TO THE GROUND WIRE THAT LETS YOU WATCH DVD WHILE DRIVING HOPE THIS HELPS
GOOD LUCK STROUP
Nov 27, 2008 | Jensen VM9510 Car DVD Player
DVD player playing while driving
It's not that difficult. Get a two position toggle switch and run the wire that normally goes to the brake, into one end of the toggle. Then run a wire from the other end of the toggle to a ground. Whenever the message comes up on the screen about viewing while driving, flip the toggle switch on then off and it will bypass the safety feature. That's how I did mine and two other buddies of mine.
Aug 07, 2008 | Pioneer AVH-P5700DVD Car DVD Player
How do i bypass the parking brake switch in order for my video to play
There isn't any code that I know of. Most DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Jun 25, 2008 | Virtual Reality Sound VR3 CD Player w/ USB...
JENSON VM9512 CODES FOR BRAKE BYPASS
turn on the player, start the radio option, go into the setup menu, tap the language tab, ON THE REMOTE press "stop, stop, 5,4,3,2,1" This will bring up the secret menu, you do not need to connect the pink wire
Mar 10, 2008 | Audiovox VM9512 Car DVD Player
Jensen in dash dvd monitors
jensen double din dvd monitor it a uv8020 model to bypass the e brake or parking brake
Dec 19, 2007 | Jensen VM9510 Car DVD Player
Jensen vm9311
Need to know and bypass codes for the jensen 9311 but dont have the remote...
Oct 21, 2007 | Jensen VM9510 Car DVD Player
Jensen VM9510 Car DVD Player Logo
642 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Iron
Iron
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
