Question about LG LB1200ER Air Conditioner
Unit dosent start up
This unit was installed today , model awhbeus the condenser comes on and when its time for the blower to come on the unit shuts down .the thermostat wires are |#1 red |#2 brown |#3yellow |#4 blue . whitch wire goes to the fan?
  • 2 more comments
  • isaacschofie Jan 16, 2009
    ||||||||||||||||#1r #2br #3y #4 b
    the other end goes to the condenser outside same letters
  • Ken Bledsoe May 11, 2010
    That is the thermostat designation I need to know the other end of those wires where they go. On your furnace part.
    Can you go to the board that these wires are connected and give me the letter designation and color of wire that it is.
If i dont get it figured out i will get the installer to take it back to the supply house .
Posted on Jan 16, 2009
Why does my unit not cycle after installing a new blower motor?
First, when you say why doesn't it cycle, can you be more specific? Is the fan not running, always running and doesn't shut off, outide unit not running? What exactly is not cycling
Jul 04, 2014 | Ruud UBHC Air Conditioner
I have a carrier Day & Night a/c - heater unit. the model # 591ANX0480000ACAA, 208/230 volts. my blower fan stays on continuously, even after turning the thermostat off. the condenser fan does not come on...
If the blower fan in the furnace won't turn off, there is a tripped/blown limit. It's a safety. As for your condenser fan it could be a run cap or motor. Do yourself a favor and have a licensed HVAC contractor take a look. Find a NATE certified or ACCA member. You will find a much better more qualified contractor.
Sep 23, 2013 | Carrier Packaged A/c 3 Ton 13 Seer And...
Why is my 95% rheem furnace blinking code 2
Check condensate water /drain stopped up. It will allow a start after a reset but then it shuts the combustion air fan down and that shuts the unit down this will require a service tech make sure their familiar
with 95% units
Oct 19, 2012 | Rheem Gas Furnace 60000 Btu 95% Afue. Rgrc...
My blower unit in the attic is not working at all. I had a leak in the ceiling and the unit would come on sometimes but not all the time and now it does not come on at all. I have had the ac recharged and...
Hello, if the unit is a 90% unit it is possible that the condensate line is clogged and therefore shutting down the unit as a safety. I would make sure the line is clear first, it is also possible that the relay on the integrated control board is bad and not engaging the blower motor.
Aug 10, 2011 | Ruud UBHC Air Conditioner
My Taylor 745-27 starts hopper comp. comes on, blower starts,beatersrun,fan shuts down beaters stop compressers sun for a shoet time then shut down, the beeps and starts the process over again Any...
could be a dirty condenser. Hi pressure safety is preventing a dangerous condtion by shutting it down. When pressure drops, unit cycles back on. Check it out.
Jan 12, 2010 | Freezers
Intertherm model T3RC-030K Shortly after unit comes on in the heat mode it starts to frost up,it will shut down and defrost and come back on for approx 5-10 minutes and again shut down to defrost the temp...
Hi, if this is a split system with a remote condenser It sounds as though you are having a problem with the thermostatic expansion valve on the heating cycle. If indeed this is a heat-pump, it has 2 metering devices that meter freon into the evaporator to heat or cool. The reversing valve changes the direction of the flow. If the condenser starts to ice up and shut down and repeat itself. I would say that is you're problem. This is something that would have to be changed by a service tech do to the equipment required to do this. I wish I could offer you a quick fix but I can not. You can let me know if this is a split system, and I may have other solutions for you, so get back to me on this please.
Sincerely,
Shastalaker7
Dec 23, 2009 | Heating & Cooling
Goodman condenser model GSC130361DF. compressor
That is normal too me. Just set it lower for more comfort.
Jun 28, 2009 | Heating & Cooling
Coleman evcon blower not working properly
My Coleman Evcon ac unit,heater and blower does not work.not even the outside condenser comes on.Any ideas on what is the problem?
Jun 22, 2009 | Coleman Heating & Cooling
Coleman A/C-Heat Pump Start and Stop Run Problems
well you have it great job! on the out door unit when it will not shut off disconnect the yellow wire on the stat wires coming from inside if unit stops stat bad if not contactor "points' if they look pitted or buzz change them #1 reason for compressor failure high amp draw thru bad contactor hope this helps aboout 15.00 at hvac store seperate wires with zip ties so dont get mixed up if only one set of points then 30amp single pole 24vac coil contactor
Jun 04, 2009 | Coleman Mach III Air Conditioner
Exhaust Fan (outdoor blower?) shuts off after 1 minute, and motor feels hot
sounds like your condenser fan (the outside blower) has gone bad or the capacitor (small silver box looking thing attached to the motor). the way to test the cap. is with a digital meter that can test for micro farads. the reason it gets hot is you have electricity going to the motor. normally it would transition that energy to motion energy. however since the motor is not turning that energy has to go some where, so it turns into heat energy. your best bet is to replace your condenser fan and capacitor. that is if your comfortable with that type of repair. otherwise call someone out to repair and tell them what your make and model is so they can bring the parts with them and save you some money. hope that helps
Jun 11, 2008 | Goodman Heating & Cooling
LG LB1200ER Air Conditioner Logo
46 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
