Question about RCA HD52W66 Projection Television
RCA HD52W66 convergence
Resoldered flyback and fuses---------now tv is going off and on--
model rca HD52W66 itc222A-any clues in what to do now?
2 yrs. old started with rainbow effect convergence not on menu.
Father-in-Law had one for 6 months and they had to replace,
What is wrong with these TV's?
  • RCA Master
  • 8,617 Answers
Ceck CP150 and CP114 to see if the tops are domd eve slightly if so they will need replacement. They are both located on the deflection board where the flyback is also located.
Posted on Jan 16, 2009
Convergence option dropped from menu on rca tv
thats a very easy repair if you can solder Replace FL231, DL231 and CL230 then resolder the flyback that will solve the issue. You can get the Kit called ITC222 and ITC222a Convergence option missing repair kit from www.tvrepairworld.com which has the replacement parts and the CD with repair instructions.
Jan 01, 2012 | RCA HD52W56 52" Rear Projection HDTV
The picture looks 3D and when you select the menu all writing is in a U shape. The TV is a RCA HDTV and the model # R52WH74YX51. Serial #G402C10DZ, chassis #ITC222A, and was manufactured Oct. 2006.
Its more than likely the FL231 fuse has blown due to carcked solder joints on the flyback. very famous issue with that model if the auto convergence feature is no longer listed under the setup menu then you will need the convergence option missing repair kit from www.tvrepairworld.com
Aug 16, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My R56WH78 tv has lost convergence overnite,I can not access any convergence menu with the remote control,What should I try next.
This RCA tv model have a dead convergence fuse at FL231 at the right side of a FBT- a big black plastic block with a wire hook to a board.Must resolders the FBT-(Flyback tranformer too).U have all the tools and also can do basic soldering work too?Yes,try website like Ebay.com to by the RCA tv convergence fuse to replaced at location FL231 and and also resolder FBT-Flyback tranformer too.Will solved this tv RCA model convergence problems.
Aug 02, 2011 | RCA R56WH76 Projection Television
The blue,red and green colors need to be aligned but i cannot find the option in the menus. I Had to do it once but i cannot find the option now
Very common problen caused when the fL231 and DL231 blow it makes the option disappear from the setup menu. You can get the repair kit called the ITC222 and ITC222a convergence option missing repair kit from www.tvrepairworld.com which contains the parts and the CD with instructiions.
Jul 18, 2010 | RCA HD52W59 HDTV Projection Television
I can find where to line up the pluses for the colors
No,convergence screen set up menu appear,Mean convergence is dead.Replaced the FL231 all three of these caps convergence fuse,near the FBT,big black block of plastic,flyback tranformer.Resolders FBT also.Done this will solved ur convergence problem in this RCA tv model.Ebay.com to buy the FL231 convergence fuse for the replacement.
Mar 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My convergence keep going out, I replaced the convergence twice. I have a rca hd52w59 modle
When you say replaced the convergence twice, are you refering to the convergence boards or the FL231 fuse? If its the FL231 fuse unless you replaced the DL231 and CL230 plus reflowed the solder on the flyback it will continue to keep blowing untill the 3 parts are replaced together and the flyback gets resoldered. If you replaced the convergence boards then try resoldering the flyback.
Nov 27, 2009 | RCA HD52W59 HDTV Projection Television
R56WH78 RCA TV FlyBack
Resolder all the pinns on the FBT chances are FBT is Bad they go out alot Call UED for Parts 1-800-648-6657
Oct 19, 2009 | RCA R56WH76 Projection Television
RCA R52WH77 ITC222A chassis convergence problem - FL231 changed!
did you hear an arch before it went if so , one of your crts is arching
and sorry they are not avail anymore
Sep 20, 2009 | RCA Televison & Video
Convergence
Open Fuse FL231 will cause your problem.
Aug 06, 2008 | RCA HD52W66 Projection Television
RCA HD52W66 Projection Television Logo
375 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
