Question about GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker runs but wont heat
Have a ge spacemaker about about 5 or 6 years old runs and light works but it wont heat anything.
  • 2 more comments
  • trussellfl Jan 16, 2009
    I have a GE Adora Spacemaker xl1800 that stopped heating yesterday. The unit is 2.5 years old and has worked fine up to this point. Does anyone have an idea what the problem is?
  • Anonymous Jan 16, 2009
    I have same issue with GE profile spacemaker II
    Also, I noticed that when I turn it on, its loder than usual
  • trussellfl May 11, 2010
    The GE Adora Spacemaker xl1800 model number is HDM1853BJ02. The unit does sound louder than usual. The turntable and the light also work.
  • William Miller
    William Miller May 11, 2010
    When you hit Start to
    cook, do the inside light and turntable come on?
    Any unusual noises? Is
    it louder or quieter than usual?
    We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
    What is the model number?
    A GE model number looks like this: JVM1430WV001
  • 6,784 Answers
Hi, there are three issues that will cause a no heat situation in a microwave. these issue are a failed Magnetron, busted cut-off fuse and, failed diode.
I recommend checking all these area that are located inside the microwave for faults.
The most common issue will be a failed Magnetron.
The diode and, fuse will be located on the noise filter assembly.
Posted on Jun 22, 2009
My 10 year old GE Spacemaker XL1400 microwave has stopped heating the microwave's contents.
probably a magnatron failure
take it to an appliance repair shop for a proper diagnosis and get a quote as repairs can be more expensive than new unit
Nov 24, 2015 | GE SpaceMaker Microwave Ovens
Problem with the GE Spacemaker (JVM1640SJ) Microwave Oven GE Spacemaker XL1800 won't heat food anymore....It worked this morning, now won't heat. What should I do?
GE Will replace the magnetron for 9 years! Mine is a 2004 model with a one year warrently according to manual. HOWEVER they did say the magnatron was covered for nine years: call 888-239-6832. When I called they said thats all they get calls for and would send out in 3-5 days. NO CHARGE. I had to ask if there was coverage longer than a year on major parts and that's when they offered the info and I eventually was transferred to the right office. Saved $120 bucks on parts alone.
Jun 13, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Oven not heating. runs but no heat. GE Spacemaker (11 years old) Light works, table turns. Seems a little louder when turned on
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Sep 26, 2010 | GE JVM1440 Microwave Oven
JVM1640WB007 MICROWAVE RUNS BUT DOESN'T HEAT. WHAT COULD BE THE PROBLEM?
It is most common for the magnetron in GE microwaves to go out. This is the part that heats the food. Basically everything on the unit works and runs like normal but it wont heat. Check your owners manual for the warranty on the magnetron. They usually put a 5-7 year warranty on the part itself. If you dont have the owners manual check for it online. Hope this helps you.
Jan 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
It doesn't heat anymore. About 5 years old only.
Check the door safety switch. When they go bad, they oven doesn't know if the door is closed or not. Find them inside on the side opposite the hinge. They go bad because we (read "you and me" open the door with the oven running and that cooks the contacts on these little switches.
Need more info? Post a comment to this question
thanks for your interest in fixYa.com
Dec 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Model # jvm1650wh05 GONE CRAZY
I have a GE Spacemaker microwave oven and it is not heating the products. The light works, turntable turns but wont heat anything?
Jan 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven does not heat anything
It's probably a defective magnetron.
This should have a one-year full parts and labor warranty, then another several years on the magnetron, typically 9 years.
A typical service call for this might run about $175 for the visit and repair labor, assuming the magnetron is still covered under warranty. Compare that to the cost of buying and installing a comparable oven.
Your owner's manual will tell you how long the magnetron warranty is.
You can save that home visit charge and get a diagnosis for about $25 or so by removing it from the wall and taking it to the nearest GE-authorized servicer.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Nov 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven does not heat anything. Clock, turntable, lights work. I turned the turntable off while the oven was cooking--heard a noise, now it doesn't heat anything.
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Jul 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
2 1/4 year old GE Spacemaker XL 1850 Microwave doesn't heat
Check this website:
http://www.partselect.com/microwave+no-heat+repair.htm
It sounds like it is either the power diode, the high voltage capacitor or the magnetron. If it is the magnetron, it may not be worth fixing as these can cost well over $100.
Do you hear a buzzing sound?
Dec 13, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Nov 03, 2007 | Roper MHE14XKB Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
524 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
