Question about Kenmore 62602 Electric Dryer
Electric dryer heat coil off mid cycle
The older model electrc kenmore dryer is shutting off the heat coil after about 2-3 min or run time.  The tumbler and fan still run completely through the cycle but heat does not turn on  untill manually reset ?
    Problem Solver:
  • 12 Answers
You have 3 thermostats. By the description of the problem it sounds like it needs a new high limit thermostat. All 3 thermostats and the heating coil can be checked with an ohm meter. Also check the ground on the heating coil. It could be grounding it's self out.
Posted on Jan 31, 2009
GE spacemaker electric dryer PCKS443EBWW. Dryer shuts off mid cycle on timed dry setting. Wait till cool down and will start again. Venting is clear, I vacuumed inside and around motor. Any ideas?!
Mark, Could be limit /over heat/thermal fuse/switch, check or have checked by a good repair Tech., diagnosed and estimate repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What to Check when your Dryer Shuts Off Mid Cycle
Whirlpool Maytag Dryer Diagnostic Shuts off mid cycle not heating...
Kenmore Whirlpool Clothes Dryer Repair The Most Common Problem
GE electric dryer overheating shutting down
Jul 10, 2016 | GE Dryers
MY DRYER SERIAL NUMBER X073808040 STOPS AFTER 20 MINUTES
Kenmore Dryer - heats & runs but stops mid-cycle - Ask Me Help Desk
https://www.askmehelpdesk.com/.../kenmore-dryer-heats-runs-but-stops-...
Kenmore Dryer - heats & runs but stops mid-cycle. Asked Aug 30, 2006, 12:25 PM - 10 Answers .... Unfortunately it shuts off after a few minutes, I'll estimate about 5.After waiting about 30 minutes, ... New Member. Jun 16, 2010, 09:20 AM ...
Sep 15, 2015 | Dryers
How to replace a heating element on a Kenmore Elite Oasis ST dryer
Sounds like you need to replace the timer one the dryer not the element but to make sure I would do a little trouble shooting to rule out the element or heating coil turn on dryer cycle like normal for about 30 seconds then open the door to feel for heat if you do feel heat its your cycle/timer knob if you don't feel heat then it's the coil or element witch are the same also first always check your lint trap and ducts going outside the dryer make sure you have proper airflow through ducts vents. clogged vents ducts ect. Cause over heating of element coil causing a safety fuse to shut down heating coil/element but will not stop cycle also moisture censors detect moisture causing cycle to continue on hope this helps.
Sep 04, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore Dryer
What is the model number of your unit?
Nov 26, 2012 | Kenmore Dryers
My dryer is getting so hot that it is shutting itself off mid cycle. I can restart but it only runs a short time....gets really hot and shuts off again!!
Check your entire vent tubing from the outside vent to the line coming out of the back of the dryer.
Overheating indicates low air discharge flow. The air in the dryer must move out quickly so the heat doesn't build up too much.
Try that & post back.
Gary
Sep 15, 2011 | Kenmore 600 6965 Electric Dryer
Kenmor 80 series gas dryer model # 11076822695 dryer is heating up for about 2 min then it gose cooled for the rest of the cycle
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Kenmore 72802 Gas Dryer
My kenmore dryer keeps shutting off mid cycle.
sounds like your motor is over heating and shutting off.once it is cooled it starts.listen next time and see if their is a humm or pause when restarting the dryer.solution is replace motor.
Mar 11, 2009 | Kenmore 65924 Electric Dryer
Kenmore 62602 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
