Question about Video Game Consoles & Games
Hi, I have a DS lite that won't power on, no lights flicker when I when i switch it on
    Problem Solver:
  • 6 Answers
It might have been used or something go buy a new one and see if that works hope this helps
Posted on Jan 16, 2009
My ds lite just switched off and it was charged
Hi, so if you try switching on the ds lite, nothing at all happens ??
Does the green light flash even if it is for like a split second.If it does then it is more likely top be a blown fuse. If 1 of your screens flicker also, this could be your problem as the ds will not start up with a broken screen. Please advise
Jul 31, 2012 | Nintendo DS Lite Console
Tip
DS Lite stopped working. Green/Orange light Flicker On then Off.
Has your DS lite stopped working? does the green/orange light momentarily stay on? Here are a few tips to help you on your way to repairing your DS lite.
These are the three top reasons for the above faults:
1) One of the screens is either not correctly connected or has devlouped a fault... If one of the screens flickers after you switch it on and just before the green light goes out then the screen that doesn't flicker is causing the problem, firstly try reconnecting it and if that doesn't work you will have to replace it, both screens are avaliable for a reasonable fee on ebay, search for either "DS lite top screen" or DS lite bottom screen".
(if you need help with replacing the screens check out my other tips and tricks I have issued on here).
2) Locate the inductor labled "L2" if this is missing then you will need to either solder it back on if you can find it or else you can buy another one again on ebay for a reasonable fee, search for "DS lite L2".
3) If both the above fail then chances are you have blown a fuse, if you can charge the DS then it is not your "F1" fuse in which case you will only need to replace the "F2" fuse, firstly desolder the old fuse and then solder on the replacement fuse, this should solve the issue. If however the charging light stays on for a very brief time (i.e 1-2secs) then you will have to replace the "F1" fuse, locate the "F1" fuse and follow the sames steps stated for the "F2" fuse. These fuses are also found on ebay, search for "ds lite fuse" and buy the quantity you require.
If you don't have access to soldering equipment or are unable to solder these very small parts (i.e fuse dimensions - 1.5 mm x 0.8 mm and the "L2" inductor dimensions - 2.5mm x 1.8mm x 1.8mm) The is a product called wire glue which is avaliable from ebay (located in the USA) which is fantastic as it is a glue with conductive properties.
You may find guides that tell you to "bridge" the fuses and "L2" inductor but I would strongly advise against this, afterall they are there for a reason and just think what damage would have happend if that fuse hadn't have blown.
Here is an image for the location of the fuses, also if you look just under the power switch you will see the "L2" inductor:
http://www.xdupe.com/assets/images/nintendo_ds/tutorials/ds_lite_fuse/usg-cpu-x3_fuses.jpg
I hope this helps and have to say that I accept no responsability for any damage that may occur to your DS lite when following these tips.
Regards,
SOD69
on Feb 08, 2010 | Nintendo DS Lite
Unit won't turn on !
This could be due to several things, the main ones being:
Regards,
SOD69
Feb 07, 2010 | Nintendo DS Lite Console
DS Lite wont power up, just flickers and goes out
ur problem with top screen.the strip may be damaged change the top screen .
Aug 29, 2009 | Nintendo DS Lite Console
Green power lights on but both screens blank
ur ds froze or it did not turn on all the way.Take it to Game Stop
Aug 24, 2009 | Nintendo DS Lite Console
DS Nintendo Lite - will not turn on
Sounds to me like you have a bad battery pack
Jun 14, 2009 | Nintendo DS Lite Console
DS lite, power is on but nothing happens
Ditto... except my daughter is 10. Both screens remain black, are fully charged and green light stays on for more than 4 minutes.
Sep 14, 2008 | Nintendo DS Lite Console
Green light goes on but nintendo ds lite does not boot.
TAKE IT TO A REPAIR SHOP SEE WHAT THEY CAN DO.
Jul 27, 2008 | Nintendo DS Lite Console
Video Game Consoles & Games Logo
48 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
