Question about HP Compaq Presario V2000 Notebook
Back light my monitor was flashing also, then went blank. was told by best buy it was the back light. how difficult is this to replace? is there a manual for instructions? any special tool?
  • vickil45 Jan 18, 2009
    Thanks for the suggestion, but for the cost of having a computer geek fix it I can add a couple of hunderd dollars and buy a new laptop which is what I did. I just don't want to discard this too when a backlight is all it needs.....thanks
  • 33 Answers
It's not hard to replace LCD but I will recommand if any professional do this for you.
Posted on Jan 18, 2009
  • Jay Patel
    Jay Patel Jan 19, 2009
    everything is one piece means backlight is inside lcd. so if want to get rid of this than you have to replace lcd.
Blank screen the screen has been working for over a year and all of a sudden went blank its not my pc as i plugged my pc into another screen and worked fine.... the standby flashing stops flashing when i...
Since you have tried another monitor with your computer, then we can only assume that your LCD monitor had gone bad.
If the light is green but you can't see anything on the screen, then most likely the backlight has gone bad. Unless you want to take the monitor apart, I would suggest buying a new monitor.
Apr 19, 2010 | Samsung SyncMaster 203B LCD Monitor
My DELL flatcreen just went blank and is now flashing yellow light, won't turn on
Check and make sure your connections on the back of the PC are snug...and make sure you have a good connection at the back of the monitor.
Flashing light...is loss of signal.
Good Luck,
Mike
Nov 06, 2009 | Dell 1702FP UltraSharp 17" TFT LCD...
Heard a pop and screen went blank - won't come back on.
Your Lcd Projector Lamp/DLP Television Lamp went out
its about $165-$200 to replace if not under warranty
Nov 28, 2008 | Hitachi Televison & Video
Laptop Monitor keeps going blank or near blank. When the monitor is moved into a different position it may turn back on or it may not.
Sounds like the back light of the screen is playing up or there is a loose wire. Either way the screen will stop completely and will not keep working. The best thing to do is try and buy a new back light for laptop screen and replace it, or take it to a professional to look at and repair for you. It's not a simply fix. Thanks igi_57!
Aug 11, 2008 | Computers & Internet
Blank monitor
Try unplugging the power cord to your computer tower, click the power button to drain the capacitors in the mother board then plug the power cord back in and try to boot up. Has helped me repair several similar black screen problems. Chuck Housecall101@aol.com
Jul 24, 2008 | Star Logic 17" LCD Monitor
Green light blinking screen blank
Hi Suzee,
Is the green flashing on the tower or the monitor?
If it is flashing on the monitor, then it might be tht the monitor is not gettign signal from the tower.
To check, disconnect the monitor from the tower and check the monitor. If you get a msg on the screen like no input signal or check video cable, then 99% monitor is fine.
Check for the power supply light at the back of the tower.
Disconnect everything from the computer and then press and hold the power button on the comp for about 30 seconds.
Then connect the cables and check if it is working.
Jan 14, 2008 | Sony SDM-S73/B Monitor
Monitor flashes image for split second then goes blank but green LED flashes as well
while the monitor is still powered on, but with the LED flashing, unplug the monitor from the PC. press the power button, and the monitor should go off, now plug the pc back into the monitor. Turn the monitor back on and it should work.
Occasionally this will not work for me, but if I repeat it it normally works
Hope this helps - my problem is intermitant so it may be different to what u guys have
May 02, 2007 | ViewSonic VX924 19" LCD Monitor
Moniter
does it display a picture for a few seconds before it goes blank. or do you not get any picture?. i think i might know what it is but if you could let me know :-) All the best John
Mar 02, 2007 | BenQ T701 TFT 17" LCD Monitor
No Display
I have the same problem - the blank/black screen and blinking green power light. The speakers on the monitor work (I can hear the start-up sound that Windows makes), but the screen is blank. We bought the monitor on Halloween Night 2003 at Best Buy and had zero problems to date...except for last night. The Best Buy gang told me this afternoon that it was an internal hardware issue. I called the manufacturer and the tech guy confirmed the problem by saying he was almost positive it was the internal "inverter board" - which means you have to send it in to get it fixed. I guess this is a fairly common problem with these monitors by the way he made it sound. So, that's a $70.00 deal (service, parts, labor, and shipping back to your house) - that is, if there are no other issues with the screen itself - then the cost goes up. So by the time you pay to send it to them and then pay them to fix the board - it looks like you're better off buying a new flat panel monitor. Yikes. Anybody else with any suggestions - other than buy a new one? Thanks!!
Oct 19, 2006 | Mag Innovision LT776s 17" LCD Monitor
HP Compaq Presario V2000 Notebook Logo
48 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
