Question about Averatec 6200H Notebook
Averatec 6200 battery not charging past 25%
I recently replaced the charging jack myself. The laptop will work using AC power. While running on AC, the battery remains at a constant 25% charge and will not drain or charge further. I also noticed that while off and plugged in, the light that indicates that it is plugged in does not blink, which would notify that it is charging.
  • jmb7 Jan 16, 2009
    not the most frugal solution but, you may be right
  • 366 Answers
Battery older than 3 years can be dead and not charging any more.
try a new battery
Posted on Jan 16, 2009
My Acer aspire 4935 is not recognizing the AC adapter. When ever I shutdown the system and connects the AC adapter, it works and the charging LED lights up. Once I press the power button to boot the...
Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause:1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Feb 09, 2011 | Acer Aspire 4730-4947 Notebook
Sometimes the Adapter Charges other times Doesnot, and now finally out, cant charge!
Possible cuase:
1 AC adapter failure
2 Power jack failure
First replace it with another working charger, see if the problem gone. If not, there may be strong possibility that the power jack was broken.
Here below are some common symptoms of a bad charger.
-The laptop only runs when you keep the power cord in a certain direction.
- The laptop only runs on battery power.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently.
- The unit suddenly shuts off
- Sparks come out of the back of the laptop.
Reference: Dell Latitude D620 Charger
Jan 20, 2011 | Dell Latitude D620...
Averatec 3120V - AC adapter light blinking, no charging
get another ac adapter or check if the power dc jack is loose.
Apr 01, 2010 | Averatec 3120V Notebook
Battery will not charge. The battery is new, verified on another laptop and it works fine (takes a charge). Unit works fine when connected directly to AC. The laptop is a Dell inspiron E1505. How do I...
This isn't easily done. Have you recently replaced your power adapter for any reason. I've found that some laptop batteries won't charge if the charger is just slightly different from the original one, even if it's another Dell power adapter. If you haven't replaced the power adapter recently then it may be that your female power jack isn't properly seated or soldered into the motherboard. To reseat or resolder the jack with require you do completely dismantle your laptop. If you're not confident it doing this, then don't try it yourself. Also, resoldering the jack isn't as easy as it would seem either. Before doing any dismantling, remover your battery, turn on your computer and gently wriggle the adapter around in the female jack of the computer. Does your computer shut off on you? If so, then you definitely have power jack issues. See
Mar 13, 2010 | Dell Inspiron E1505 Notebook
Power supply connection intermittent
It is common for all laptops. The DC jack is loose on the main board. It's wise to send it away to one of the many laptop repair facilities....Just Google...Laptop Jack Repair.
Nov 27, 2009 | Averatec 3200 Notebook
Dc power jack not charging
Even though the best thing you should have just done is to take along with you the AC Power Adapter that came with it, so as to get the exact replacement, but I will still tell you the best one for your PC.
Try and Make sure that the specifications for the one you will buy meets the this output power rating :
DC Voltage : 20V
The Current should be : 3.0A.
Product Number : 76-011651-5A
Hope this helps you out.
Mar 31, 2009 | Averatec 6100 Notebook
No Power
i belive battery is displaced reset the battery and then see
if not then the power cord inside teh machine is unpl;ugged
then u nneed to chk wd the tech
May 22, 2008 | Averatec 6200 Notebook
New battery runs down fast
bad battery.. RMA that back to where you bought it from. probably wasnt a new battery they sold you. id charge it from completely dead to completely full one more time and if you dont get at least an hour out of the batt then i would return it..
Jan 18, 2008 | Averatec 3200 Notebook
Averatec 6200- battery
Are you using a travel adapter (converter)?
Nov 27, 2007 | Averatec 6200H Notebook
Plug in is broke
you cant buy a new one..........
Oct 07, 2007 | Averatec 3200 Notebook
Averatec 6200H Notebook Logo
208 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
