Question about RCA 27F530T 27" TV
Rca tv 27V513T
My rca tv 27V513T is locked and there is no remote control how do I unlock it?
  • dwlj_dj Feb 18, 2008
    how would you set the remote when the tv needs to be on to program the universal remote. Is it possible to still set the universal remote even when the tv is off. Instructions always tell you to have tv on.
  • 126 Answers
I've kind a seen this problem before i dont beleive a univesal remote will help because the problem i fond is you can not get a menu to pull up with universal. you may try to hit the power button and volume together or try to push two button at ince can't remember right of the top of my head what the are but it will help you get to factory program side i beleive then you may need to program
Posted on Feb 19, 2008
  • 398 Answers
If the TV is in "parental lock", then it will not respond to the buttons on the front of the TV. Get a cheap universal remote control, program it for RCA, turn the set on and go through the menu to unlock.
Posted on Jun 29, 2007
  • a_gates75 Jan 08, 2011
    I have a RCA Universal Remote that will work the functions of the Main Menu as well as turn the tv on and off. But it will not unlock the password. I have no clue what the password is; as I didn't set it myself. What should I do now that the front panel is locked and the tv is demanding a password?
SOURCE:
How to unlock without remote
RCA TruFlat 27F520T 27" TV Unlock without remote ... - Fixya
www.fixya.com > ... > RCA > RCA TruFlat 27F520T 27" TV
Question about Apex Digital Standard (CRT) Televisions. 1 Answer ... unlock key lg lcd tv without remote how do I unlock an lg tv without using the remote?
unlock child lock tv without remote Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your unlock child lock tv without remote question. Get free help, tips ... How to off child lock off in my panasonic tv without a remote? ... tv without aremote? iv ... Are you a Standard (CRT) Televisions Expert? Answer questions ...
How to Unlock a TV Without a Remote ' eHow
www.ehow.com > Tech
How to Unlock a TV Without a Remote. In life, simple yet unexpected events take place, such as the loss or an accidental breakage of the television remote.
How to unlock without remote control model - Standard (CRT)
Jan 20, 2016 | Televison & Video
I have an RCA tv that the parental locks are set on and now the remote wont turn the tv on
you probably need to go for a universal remote , and check as the problem might be on the existing remote may not be working and then using the universal remote , u can undo the changes you have done .
Dec 14, 2014 | RCA 27" Tv Sdtv Universal R.c. connections...
How do i manually reset my rca tv model 27v513t without a remote?
To reset it to its factory settings, you must have its original remote control. A universal remote won't go.
Nov 11, 2013 | RCA 27F530T 27" TV
MODEL #27V513T
You must have its remote control to unlock it.
Jan 23, 2013 | RCA 27F650T 27" TV
What buttons do i press on the remote to remove fpa lock on a rca tv model 27v513t
Most RCA TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Jul 07, 2012 | RCA Televison & Video
Is RCA 24V511T digital or analog? Also can I use a universal remote or do I need the replacement for the original remote that came with it? I
Hello
This CRT based tV is an anlogue one. You can use a universal remote control, except to unlock the FPA lock to this TV. By anyway, this TV has been locked with FPA lock, you must have its original remote control to unlock the lock. You can use most of the RCA universal remote controls with this TV.
RCA RCR 311W will be better. The setup codes are:
1000, 1002, 1004, 1005, 1014, 1025, 1078, 1081, 1095, 1096, 1097, 1098, 1099, 1100, 1101, 1111, 1128, 1130, 1132, 1134, 1144, 1146, 1149, 1171, 1205
OK.
Sep 22, 2011 | RCA 24V511T 24" TV
FPA LOCK ON MY RCA TV MODEL 27V513T
go to menu of your remote and unlock the fpa
May 26, 2008 | RCA 27F530T 27" TV
Rca tv 27v513t fpa lock
yesterday i was watching tv but suddenly it turned off and after that i was trying to turn it on but i wasn't.......but today it turned on , infact i was trying to turn it on.........i wanted to know what is the problem so pressed on botton and it said "FPA ON " after 10 min.again it turned off..............i don't know what should i do...........can you please solve my problem......i will be so nice of you.
thank you
Feb 08, 2008 | RCA 27F530T 27" TV
RCA Model 27V513T FPA Lock On
hey i have the same problem only i don't have a remote and i locked my tv out of my own stupidity. its model no. is 27V512T if you're any good with chips mabye you figure out a way to reset the tv.
Jan 17, 2008 | RCA 27F530T 27" TV
RCA 27F530T 27" TV Logo
279 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
