Question about Compaq Presario X1000 Notebook
Presrio X1000 DVD/CD Rom driver not working
TOSHIBA ODD-DVD SD-R6252 after i installed Windows latest service patch, my driver cannot be found. I have uninstalled the patch but still no DVD's or CD's can be read. I can't repair as i woudl need to use the drive to re-install?
Any ideas please?
    Sergeant:
  • 366 Answers
From Microsoft KB :
This method provides step-by-step instructions for how to use Registry Editor to delete the following corrupted Registry entries:
  • UpperFilters
  • LowerFilters
Step 1: Start Registry Editor loadTOCNode(3, 'whattotry'); Start Registry Editor. Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'whattotry');
  1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE.
  2. Expand SYSTEM, and then expand CurrentControlSet.
  3. Expand Control, and then expand Class.
  4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
  5. In the details pane of Registry Editor, on the right side, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only.
    • If you see the UpperFilters registry entry in the details pane of Registry Editor, go to step 6.
    • If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to "Step 3: Delete the LowerFilters registry entry."
  6. On the Edit menu, click Delete.
  7. Click Yes when you receive the following message: Are you sure you want to delete this value?
The UpperFilters registry entry is removed. Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'whattotry');
  1. In the details pane of Registry Editor, on the right side, click LowerFilters.
    Note You might see a LowerFilters.bak registry entry. You do not have to remove that entry. Click LowerFilters only.
    If you do not see the LowerFilters registry entry, unfortunately this content is unable to help you any more. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  2. On the Edit menu, click Delete.
  3. Click Yes when you receive the following message: Are you sure you want to delete this value?The LowerFilters registry entry is removed.
  4. Exit Registry Editor.
Step 4: Restart your computer loadTOCNode(3, 'whattotry'); Restart your computer. After you have done this, try to access the CD or DVD drive. If you can access the CD or DVD drive, and if you do not receive an error message, the problem is resolved. You can reinstall your CD or DVD writing or recording software.
Posted on Jan 16, 2009
I have a toshiba satellite it will not play any audio sound and when you go on the volume it says it as toshiba dvd-rom sd r2412 and all i want is sound on my laptop can you help me please
Do you have sound at all, or just not when you play a CD or video DVD?
Fist thing to check is if your audio drivers are installed and working properly.
If necessary, find and install the right sound driver for the computer.
There are some more things to try to fix sound in Windows, hope that helps.
May 12, 2010 | Toshiba (SD-R2412) for Satellite A10, A15,...
I have a toshiba ODD-DVD SD-R5272 that runs in win 2000 But the windows drivers it uses say its only a CD rom I have done the firmware update ...With no help What else can I do ?
Make sure you have the proper driver installed and that it is working.
Go to PCPITSTOP and have them scan your machine. It is a free service.
I hope this helps you
a
Sep 21, 2009 | Toshiba SD-R5272 DVD±RW Burner
Toshiba satellite p205ds7454, pioner dvd-rw dvr-k17lf ata device
If you are asking for the information regarding the ODD here it is: DVD SuperMulti (+/-R double layer) with Labelflash? drive supporting 11 formats * Maximum speed and compatibility: CD-ROM (24x), CD-R (24x), CD-RW (4x), DVD-ROM (8x), DVD-R (Single Layer, (8x)), DVDR (Double Layer, (4x)), DVD-RW (4x), DVD+R (Single Layer, (8x)), DVD+R (Double Layer, (4x)), DVD+RW (4x), DVD-RAM (5x) * Supports Labelflash? media to burn high quality labels directly on the disk. If not ( Cant read CD or DVD ) then most likely the lens on the ODD is already busted. or ODD cant be detected then just go to the Website support.toshiba.com and download the latest update for the ODD. And install the driver on your NB and restart the NB. If still the same then the ODD you have is already busted what you need to do is to buy a new ODD.
Aug 07, 2009 | Toshiba Satellite P105-S9722 Notebook
I need driver Toshiba DVD sd r2102
DVD & CD R/RW use generic windows drivers for the most part. Remove the drive from the list in device manager. Windows will then install the drivers again when you reboot.
Mar 23, 2009 | Toshiba SD R2102 CD-RW/DVD-ROM Burner
Dvd rom
Hello
To isolate the issue please perform following steps.
Click Start and select Run . In the Run box type devmgmt.msc and press enter. This will open Device Manager.
Click on + sign next to CD/DVD drive and right click on all the devices listed unde CD/DVD drive and select uninstall. Then restart the notebook. This will automatically install CD/DVD drive drivers. This should resolve the issue. However, if the issue persists please download and install following dougnox patch if you are using XP operating system.
http://www.dougknox.com/xp/scripts/xp_cd_dvd_fix.vbs
Please make sure that if you are using XP then only try to download and install above dougnox patch.
This will resolve the issue.
Thanks
Regards
If you think the above information is helpful then rate me.
Jun 20, 2008 | Computers & Internet
Toshiba DVD ROM SD M1302 driver
If you are using Windows 98, 98SE, ME, 2000, NT or XP, and have an ATAPI/IDE CD/DVD drive, there is no driver needed (see Toshiba statement I have posted below). Under no circumstances, if DVD is properly installed and functional, will you need ANY driver!
If your DVD drive is a SCSI drive, then it may need drivers specific to the SCSI card you have installed (see the specs/manual or website for your card). You may also need the Adaptec SCSI setup, available at this address:
http://www.adaptec.com/worldwide/support/suppbyproduct.jsp?sess=no&language=English+US&cat=%2FTechnology%2FSCSI+Software&fromPage=driverindex
or use this address if you have a LOGIC based SCSI card or device:
http://www.lsilogic.com/
Now, if you meet the criteria for the first paragraph I wrote, and your PC does not load the driver automatically (after a reboot or two) then you have a PHYSICAL or HARDWARE problem. Either the DVD drive is improperly cabled, improperly installed or defective.
Those are all your options. See below, from Toshiba website
good luck
http://sdd.toshiba.com/main.aspx?Path=ServicesSupport/DeviceDrivers
ATAPI CD-ROM and DVD Drivers
Toshiba's CD-ROM and DVD-ROM drives do not require any unique device drivers for Windows '95/'98/2000/XP/NT.
After installing your drive and re-booting, your system should recognize your CD-ROM or DVD-ROM. Win '95/'98/2000/XP/NT Operating Systems support all Toshiba ATAPI CD-ROM and DVD-ROM drives natively.
DOS/Windows 3.x Device Drivers
This device driver is to be used with DOS/Windows 3.x operating systems. Do not use this driver with Windows '95, Windows '98, XP or Windows 2000 unless you are going to use your system in the REAL or MS-DOS Modes. Device drivers for Windows '95, Windows '98, Windows 2000, XP, OS/2, and NT operating systems are provided with the installation or setup software of each operating system.
DOS ATAPI Interface Driver
If you prefer using DOS click the link below to download a MS-DOS ATAPI interface driver.
atapi.exe
SCSI CD-ROM and DVD Drivers
SCSI interface drivers are written for the SCSI card you are using in your system, by the SCSI card manufacturer. They are not specific to your Toshiba drive and are not provided by Toshiba. If during installation Windows can not find the correct SCSI software driver for your SCSI card and you do not have the software driver that came with your SCSI card, contact your SCSI host adapter manufacturer.
Adaptec SCSI Drivers
LSI Logic (Symbios) SCSI Drivers
DVD Viewing Software
Toshibas DVD drives require a third party software to be installed in your system to enable you to view DVD movies. If you purchased your drive as part of a kit, the software may have been included. The links below will provide some possible solutions should you not have this type of software.
Nero6 (Toshiba recommends)
Toshiba does not recommend nor endorse any of the following manufacturers software products. Software names are provided only as a courtesy to our customers. Please check with the software manufacturer to assure that their software supports your drive model.
DirectDVD
Cyberlink PowerDVD
WinDVD
Media Burning Software
Toshiba's recordable drives require third party software to be installed in your system to enable you to burn media. If you purchased your drive as part of a kit, the software may have been included. The link below will provide some possible solutions should you not have this type of software.
Toshiba does not recommend nor endorse any of the following manufactures software products. Software names are provided only as a courtesy to our customers. Please check with the software manufacturer to assure that their software supports your drive model.
NTI CD & DVD Maker
Gear DVD & CD-RW
Roxio Toast (Macintosh)
Easy CD Creator
Stomp Clinkn Burn Pro
Feb 24, 2008 | Computers & Internet
Laptop dvd drive door will not open
There is a tiny hole on the draw in which to insert a paperclip to manually eject the draw.
Jan 16, 2007 | Compaq Presario X1000 Notebook
Dvd - cd rom wont work
Dear friend, In your system cdrom drivers currupted for that drivers you need to install a mscdx file in drive "c" then it works fine.
Dec 14, 2006 | LG CRN 8245B (CRN-8245B) Internal 24x...
Compaq Presario X1000 Notebook Logo
155 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
