Question about Reddy Heater-40,000 BTU Kerosene w/T'stat
Won't ignite and fill the entire tube with flame, cold air, smoke
I have a M50S 50,000 btu heater on kerosene, had a buddy throw it away because it did this, thought I scored but don't know now. He had diesel fuel in it, but I changed that and put kerosene in it. Looks like it should work, had cover off, igniter sparking, flame inside, end doesn't glow though, blows cold air and smoke. I am a mechanic by trade, thinking, wouldn't have smoke if fuel wasn't getting there, wouldn't have flame inside if igniter wasn't working, really need it going right now, girlfriends car wouldn't start this morning-------OH BOY can you please help me????????
    President:
  • 2,976 Answers
The deisel fuel hogged it up. Clean everything out and replace the wick. Deisel fuel is filthy to burn and it needs a lot of airflow.
Posted on Jan 16, 2009
My ready heater 100,000 will run for app. 5hrs then flame out and blow smoke or unburned fuel the same several times pressure is right
If the heater continuously has a 5 hour run-time check to see if the fuel pickup tube goes to the bottom of the tank. If broken, cracked, or shortened the fuel will stop being picked up when air is sucked rather than fuel.
Feb 08, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
Older torpedo style kerosene 50,000 btu smokes
clean out the fuel nozzle and if it wont burn cleanly, replace it.
Jan 03, 2010 | Heating & Cooling
Reddy Heater Kerosene 50,000 BTU produces TOO
There are2- adjustment screws on the back 1--air---#2-fuel. adjust it while running for the perfect combination for the fuel/ air ratio.!
Dec 21, 2009 | Heating & Cooling
My 110,000 reddy heater flames up then after a minute or two just blows cold smoke???
Time for a Full tune-up, plug--fuel filter- 2-air filters -vanes in the pump.
Dec 13, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Burners are only lighting half way and then gas cuts out. Then the system repeats it' self. coleman heater mod #7995856, serial #1287658845. this is pretty close or just like heaters used in RV'S
OK, the burners will need to have flame on the entire surface or it will trigger a sensor and shut-off. Get a brush and maybe even one of thoes can of air and blow off the burner. Stay away from the glow ignitor because that is very delicate. Once you get flame on all surface of the burners, the unit should stay lit.
Oct 19, 2009 | Coleman Propane Forced Air Heater...
No heat, just smoke, flame inside,
MORE THAN LIKELY NEEDS SERVICED START BY REPLACING FUEL NOZZLE WITH THE SAME NUMBERS THAT ARE ON THE OLD ONE SHOULD HAVE 2 NUMBERS ON IT DEGREE AND GPH RATING MATCH BOTH GOOD START AND LEAST EXPENSIVE AND MOST COMMON PROBLEM FOR WHAT YOU DESCRIBE
Jan 16, 2009 | Reddy Heater-30-55,000 BTU Variable
UNIT LITES THEN GOES OUT BLOWING SMOKE
needs a new nosel and tuneup kit you can get it at sears for about 12.00 dollars
Dec 23, 2008 | Dayton 511 Utility Heater
Igniter lites up fan kicks on and within 5 sec shuts off
Dustin, The ignitor only glows for 5 seconds, just long enough to ignite the fuel. The heater is shutting down because the photocell does not see the correct flame color.
Since you say "comes on for 5 seconds", I can only assume that there is a flame. You do not specify a lack of flame. I am also assuming that you have had the heater running this heater season and the problem just started.
YOU must find out if the problem is fuel delivery related or electronics related. Start by checking the pump pressure.
Follow these troubleshooting tips
Dec 21, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Reddy Heater-40,000 BTU Kerosene w/T'stat Logo
230 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
