Question about Panasonic Palmcorder PV-L652 VHS-C Analog Camcorder
My zoom buttons don't always work.
Sometimes digital zoom works and sometimes it doesn't. At times it gets stuck on D-zoom 2 and everything is blurred. At other times it gets stuck on D-zoom 1 and refuses to zoom in for close-ups. I can't figure out whats wrong. Redd123
2 Suggested Answers
  • 68 Answers
SOURCE: Palmcorder will not focus
you should changed the focus to manual state please try to see in the viewfinder , do you have the MF apears , try to enter the menu and change to auto focus state regards please don't forget to rate thx
Posted on May 03, 2007
  • 169 Answers
SOURCE: Zoom is stuck and reset button not working.
one of the two motor of the lens of your camera is stuck up that why push reset is alway appearing and the power is blinking....only a technician can fix your problem....
Posted on Sep 09, 2007
0 characters
1 Points
My canon elura 60 digital video camcorder doesn't zoom in and out. it seems to be stuck
Sometimes a smack around the edge of the lens will work. If it doesn't, then it might be a motor issue and will need to be taken apart.
Nov 12, 2010 | Canon Elura 60 Mini DV Digital Camcorder
Camcorder zooms by itself.
this is some problem with the panel of buttons is your unit.
this will need some service from the company directly.
Jul 24, 2008 | Sony Handycam DCR-TRV330 Digital Camcorder
Zoom is stuck
Zoom assy may be defective or problem with the lens. Try moving the zoom lever back and forth a few times. Sometimes, something in the lens will get stuck and it just takes a little repetition to get it "unstuck". If this does not work, you will have to have it repaired by an experienced technician. <a href=""></a>
Aug 30, 2010 | JVC Everio Digital Camcorder
I have a JVC Everio GZ-MG155, and the zoom is stuck at 1x.
did you try holding down the record button and the picture snap shot button at the same time to reset it? It did for me.
Nov 25, 2008 | JVC Everio GZ-MG155 Camcorder
Zoom Lens Problem
Sorry there is something wrong with the mainboard when we get these at work thats usually what it is sometimes on the newer models the flex comes loose but not on this one if you have a warranty send it in if not its not worth fixing sorry
Dec 22, 2007 | Canon ZR500 Mini DV Digital Camcorder
Mvx1i zoom does not operate at all
I had the same on mine and here is the explanation because fixing it is not easy to impossible.
I had it fixed on mine just to see it getting worse after that.
Reason: The Zoom Slider puts a resistor to some printed curcuit board just beneath it and if that gets oxidised due to age it stops working. Only the remote workes then.
Workaround (recommended): Use the remote.
Fixing it is nearlky impossible as the printed circuit board is on the other side of the camera from where you start opening it and you have to comletely dissasemble it. I did and tried fixing it by cleaning the circuit boad, but it somehow changed the restance value and then it was stuck in full zoom all the time. Then had to re-open again and sever the connection completely, thus having the camera stuck in full view at least. but because of this strange resistor concept of the design, having the connection severed does not disable the zoom but rather simulates constant zooming out. hence my remote is now not longer working.
Hence: keep it simple and use the remote and be happy.
Dec 18, 2007 | Canon MVX1i Mini DV Digital Camcorder
i have the same problem.full charged battery and sometimes it comes on and then it cuts dead.sometimes it is on and works and when using the zoom it cuts dead and after a few days it work again for some minutes .
Aug 11, 2007 | Panasonic NV-GS17 Mini DV Digital...
Sony Handycam PC101E Record button/power switch...
there are loose connection of the power switch try to clean the contact of the switch and adjust it...use a pencil eraser only do not use any spray and liquid.....if you cannot put it back don not try open the camera....better go to the qualified and service center....
Aug 10, 2007 | Sony Handycam DCR-PC101E Mini DV Digital...
Jul 09, 2007 | Panasonic Palmcorder PV-GS9 Mini DV...
Canon MVX250i Zoom Problem
I had this problem on this camera. I found the battery removal rechnique seemed to work for only a short while, then the problem would come back repeatedly. I looked into just buying a new one but when I explained the problem to a salesman in an independent camera shop, he asked me if I'd just tried hitting the top of the camera. Apparently the motor sometimes gets stuck. Since the camera was virtually useless I tried this (hit it 2 or 3 times quite firmly, near the lens and by the accessory shoe). Now it zooms in and out perfectly and so far hasn't reverted to its problem state.
Must try to give the camera shop some other business - maybe when I buy a new stills camera
Apr 23, 2007 | Canon MVX20I Mini DV Digital Camcorder
Panasonic Palmcorder PV-L652 VHS-C Analog Camcorder Logo
19 people viewed this question
Top Panasonic Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
