Question about Kodak EASYSHARE V1253 Digital Camera
My flash won't work?!?
No matter what flash setting i put my camera on, it will not take the picture with the flash. i though the flash was altogether broken, but every once in a while it will work, sometimes the first picture after i turn the camera on, but never any more. help? :(
  • 3 Answers
THE PROBLEM WITH THAT WAS YOUR SHUTTER BOARD, THE SHUTTER BOARD HAS A FLASH CAPACITOR ON IF THE CAPACITOR HAS TO MUCH VOLTAGE THE SHUTTER BORD WILL BURN THE U HAVE TO BRING IT FOR THE SERVICE IN KODAK.
Posted on Jan 31, 2009
Canyon eos auto mode= won't take a pictuRE
Push your shutter 1/2 way down. See whats the readings in view finder.
Jul 04, 2013 | Cannon EOS 50D Digital Camera
My Pentax Optio M90's Flash has stopped working.. it doesn't matter if I have selected the flash to be on or off it still won't work. Even when setting are set at auto it still won't work...
Hi kerritm,
This indicated that it's time you need to replace your flash , therefore you can get it done via a service center,
The camera's flash has a certain life and you can't expect it to be ok for many years together ,
In unfortunate cases , it stops working due to hard ware failure.
Therefore , Please get the flash replaced and you would be able to use it.
Hope this helps..:)
Jun 19, 2011 | Pentax Optio M90 Digital Camera
I've had my camera since june...i won it nd since i been taking pictures it hasnt been flashing and im wondering whats the matter with it...NEED HELP PLEASE!!!:)
is the camera flash set on auto or manual flash? if its manual you need to tell the flash to fire off,,if auto it fires when there is too little light,,
Aug 26, 2010 | Cameras
Sony CYBER -shot DSC-w190 does not flash when taking picture although flash auto on
It will only flash when there is not enough available light when in AUTO flash mode.
To flash no matter what, go into the camera setting and select that choice.
Normally something like demand flash or a symbol that looks like a lightning bolt. Then it will flash every time. That does use more battery power though. By the way, I like that setting better too.
Dec 29, 2009 | Sony Cyber-shot DSC-W190 Digital Camera
The built in speedlight on my D 70S is not synching. Seems like the flash goes off before the shutter opens.My pictues all comes out dark no matter what I try. Can you help me?
I fixed this same problem with my D70s today, after twelve months of getting dark pictures despite the flash firing. It started syncing properly after I performed the following, though I'm not sure why as I was just mucking around.
- Set Program to P. - Push button to activate built-in flash. - Push, and keep depressed same button, which will put you in Flash Exposure Compensation mode. - My Flash Exposure Compensation was on +0.3 so I set it to 0.0 by turning the front wheel. Seemed to fix it.
Sep 23, 2009 | Nikon D70s Digital Camera
I have a brand new Finepix S8100fd camera and the majority of the photos are speckled no matter what setting I use. However the super macro setting rocks and pictures are super clear! My Fuji 7.1 mega
Common issue with the A8100fd. The most likely problem you are having is not enough light. Try shooting in bright sunlight to test the "graininess". Make sure you use the flash anytime the light is not bright. Even though the camera will shoot in low light (without flash), because it defaults to a high ISO setting, which (just like film) accentuates the "grain", or more properly termed in digital photography, "noise". Set the camera for a low ISO setting and use the flash whenever you see the "red hand" symbol on the screen.
Apr 22, 2009 | Fuji FinePix S1000FD Digital Camera
The flash will not work on my Samsung S860 Digital Camera. It used to work and now it doesn't... I tried to go through the menu to fix it and it seems to say it is on? But, when you take a picture it does...
the S860 has three flash modes in which the flash only fires under certain conditions.
- in Auto Flash mode and Auto & Red Eye Reduction mode, the flash will only fire if the subject or background is dark; otherwise it won't flash.
- in Slow Synchro mode, the flash only fires when the camera's using a slow shutter speed.
if you have your flash mode set to any of these, the flash will only fire when the camera determines that flash is needed; otherwise it won't fire. to have the flash fire all the time and automatically vary its intensity according to how much light is needed, set the flash mode to Fill flash; to turn the flash off altogether (so that it won't fire no matter what), set the flash mode to Flash Off.
for all the details on the S860's flash modes, you can download the user manual here and refer to pages 28 and 29.
hope this helps...
Mar 08, 2009 | Samsung S860 Digital Camera
Flash wont come on
If your flash is failing, it will require service by Canon.
Dec 24, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Loud firecracker pop and flare when flash goes off.
I had same problem, and mine stopped working altogether also.....
Interested to know what happened on the one that was sent in to get looked at in December 07
Nov 13, 2007 | Canon PowerShot S1 IS Digital Camera
Flash works but timing is off
If your camera is set properly there seems to be bad connection between shutter and the flash and you will have to send it in. I would though look again at the way your camera is set up for flash fotography.
Aug 13, 2007 | Sony Cyber-Shot DSC-P200 Digital Camera
Kodak EASYSHARE V1253 Digital Camera Logo
135 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
