Question about Daewoo DSC-30W60N 30" TV
White line My Tv has this annoying white line on the top of the screen. It's been there since we bought it a couple years ago. The bottom of the screen is cut off a little bit too. It looks like if I can find a way to just move the picture up a little bit this problem can be fixed. I can't find any way to do this on the tv's menu. How do I do this? Thanks!
  • omeed tabrizi Aug 27, 2007
    I don't know how to access the service menu. How do you suggest I should find out? Thanks.
    -Omeed
  • 45 Answers
You have a shifted picture upwards the white line is the overlaped picture. Try accessingthe service menu and shift the picture down. Patrick
Posted on Aug 27, 2007
SOURCE:
I have a 27 inch sansui television. It is about 5 years old and white lines have started to appear at the top of the screen. They are kind of annoying. Does anyone know what that is.
If your TV has a picture tube rather than an LCD display, you have a problem with the vertical circuit
(the circuit that "paints" the picture from top to bottom). Usually a capacitor in this circuit will open up causing this type of problem.
Stargazer
Jan 04, 2010 | Sansui 27" TV
Thin white horizontal lines across top of TV
replace vertical out put ic and related capacitors
please refer to a qualified tv personal to check tv
Jan 17, 2009 | Televison & Video
Wavy red lines or red pixelation, not sure what it is
Go to Vizio website and buy the extending warranty, you need to have your TV replaced since the problem is with the screen itself.
Dec 15, 2008 | Vizio L32 32 in. LCD HDTV
Toshiba 32D46 - Will Not Turn On - White Lines Near Top of screen
I have the same problem with the same TV from Tosiba. I think Tosiba know about it but did nothing to repair it but sold millions of the same TV and Made good money. I think we all should soin togather and file a class action lawsuts against the company. They must fix the TV or pay our money back plus pay for our pain and suffering. There are many lawfirm will take this case and get paid from proceed. [email protected]
Dec 11, 2008 | Toshiba 32D46 32" TV
Corner tints and white lines
it can be a picture tube problem. moreover, check if your tv is dusty inside it . clear it with blower and try again.
regards,
Jul 31, 2008 | JVC AV-32120 32" TV
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
Top of the screen Picture Problem
sound like you have 1 or a couple of leaky/bad capacitors in the tv's vertical circuit, typically, there sould be 5 to 10 caps. in all, but you just need 1 bad one to cause your problem. good luck.
Mar 13, 2007 | JVC AV-27230 27" TV
Daewoo DSC-30W60N 30" TV Logo
93 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
