Question about Kenmore Elite 45986 Front Load Washer
Kenmore m#44052 front load washer
Washer washes will not drain or spin, when draining starts humming
  • 5,911 Answers
If you have no known issues with your plumbing, it sounds like you either have a failed drain pump, or something obstructing the pump, preventing it from draining. As long as the wash tub is still full of water, the unit will not proceed to a spin cycle. I would recommend you check the drain pump first. The following link explains how:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Make sure you also check all the drain hoses for clogs as well. In particular, the hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Small articles of clothing have been known to find their way into this area. NOTE: Using a wet/dry shop vac will go along way towards assisting you with emptying the washer of all water and minimizing the mess associated with cleaning out the drain pump.
If you clean out the pump and the unit still does not drain properly, the manufacturer recommends replacing the drain pump. The next link explains how:
http://www.fixya.com/support/r401841-replacing_kenmore_elite_water_pump
Normally, a drainage issue is also associated with an error code of either "F02" or "F21, depending on model. Does your washer also show any error codes on the front panel? Now...with that said, the absence of an error code does not necessarily mean you do not have a failed component. For some reason, sometimes an error does not always get generated.
I hope this helps you. Let me know if you have further questions, or still need assistance.
Posted on Jan 16, 2009
The water in my front-loaded kenmore-he washer is not draining and doesn't seem to spin very fast either.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 10, 2011 | Kenmore Front Load Washer
Washing machine does not spin on spin cycle,only hear a humming noise.
heatman101
Jun 27, 2011 | Kenmore Washing Machines
Moter not spining but humming loudly has drain pump on top , moter acts like it wants to turn
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Mar 05, 2011 | Kenmore Washing Machines
I have a Kenmore top load washer model 20692. The washer won't drain and whenever the washer is supposed to turn all I hear is a hum. What could be the problem and is it worth fixing in a 10 year old...
Sounds like you have multiple problems...you are right... probably not worth fixing...
Look at the front loaders... they use way less water and are more gentile on your clothing...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 08, 2010 | Kenmore Washing Machines
Kenmore Front Loader Washer Doesn't Drain
heatman101
May 25, 2010 | Kenmore Elite 45986 Front Load Washer
Wont spin or drain it only only hums when turn on
Either your drain pump is bad or something is stuck in it.  It won't spin until it drains so fix the drain pump, and it will spin.  You should be able to get at the drain pump by taking off the bottom panel, or back panel.
Dec 19, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Kenmore front load washer 44052
Mine issue was a loose connection. I removed the back panel and pushed in all the wires. The washer started working again. If you take off the back panel and the belt is broken then that could be your problem. Unplug the washer first.
May 22, 2008 | Kenmore 44042 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
214 people viewed this question
Sal De
fordexpert
Robert Rankin
