Question about Logitech S520 Mouse
Typing is an effort
Still typing 1 letter at a time computer clicks after each typed letter
i did go to keyboard settings i am not sure where to look
i saw speed tab...i clicked on that but did not see anything about keystrokes
  • fredguthart Jan 20, 2009
    THE ASSISTANCE OFFERED WAS CLEAR AND CONCISE
    APPRECIATE YOUR HELP
    through no fault of your own i am giving up
    many thanks for your effort and your patience
    Genius:
  • Logitech Master
  • 1,102 Answers
This is a laptop right
When you open keyboard in control panel those bars are for speeding up or slowing down
right click on my computer then click properties then at the top you'll see restore click that and restore your pc to an earlier date when you know it worked click apply then restart
if that don't help we'll need to try and update driver
Posted on Jan 16, 2009
  • 2 more comments
  • DEKR
    DEKR Jan 20, 2009
    try and update keyboard driver
  • DEKR
    DEKR Jan 20, 2009
    should have been in the keyboard settings
    go back to control panel keyboard open it then properties
    then click driver and then update driver
    DOES YOUR KEYBOARD NEED CLEANED
  • DEKR
    DEKR Jan 20, 2009
    what OS are you running
    and how old is the laptop
  • DEKR
    DEKR Jan 20, 2009
    sorry to hear that your giving up
    If everything you treid failed and you cleaned your keyboard, I would think about getting a new one
Samsung p6800 screen keyboard displaying wrong characters
I could be wrong but it sounds like your keyboard layout is set to swype instead of qwerty. On the bottom left of the keyboard is the setting option.
Dec 01, 2013 | Samsung Black Leather Case For Galaxy Tab...
Samsung q45 keyboard intermittant
Try adjusting the keyboard input speed.
Go to Control Panel - Keyboard - Speed tab then adjust the speed settings.
Apr 06, 2013 | Samsung Q45 Notebook
I can`t get any upper case functions to work on hp 2011 keyboard what key do i press
1.Make sure the "Caps Lock" key is not on. Though this will be obvious to most people, if your keyboard is typing in only upper-case letters it can't hurt to check. Look at the "Caps Lock" indicator light on the top right corner of your HP keyboard. If the light is on, strike the "Caps Lock" key on the left side of your keyboard. This will turn the "Caps Lock" off, allowing you to type in lower case letters again.
2.Make sure the "SHIFT" keys on your HP keyboard are not stuck. Dust and dirt can build up on a keyboard over time, which can cause certain keys to stick. If either of your keyboard's "SHIFT" keys get stuck, your computer will type in only capital letters. Use a toothpick or cotton swab to remove the gunk from the key, which should help it return to its normal position.
3.Unplug your HP keyboard and then plug it back it. This will remove the device from your operating system and then automatically add it back in. This can have the same effect, essentially, as restarting your computer. If your keyboard was typing in capital letters due to an error being stored in your operating system's memory, that error will now be cleared and the HP keyboard will function as normal again.
4.Update your HP keyboard driver. Click "Start" and then right click on "Computer." Click "Properties" and then "Device Manager." Right click on the listing for your keyboard and then click "Update Driver." This will update the computer software that is associated with your HP keyboard. If your keyboard was typing in all capital letters as a result of an error with this driver, the error will now be fixed and you can use your keyboard normally again
Mar 01, 2011 | HP D8597A Keyboard
Can't type double letters can't backspace more
Push the shift key down until it beeps and it should unlock the keyboard and allow you to type normally.
Feb 08, 2010 | Dell 0Y3740 Keyboard
Yes I'm on xp. The taskbar lettering turns grey
try this:
1. From the start menu, Click on Run then type “dxdiag”
2. Click on the “More Help” Tab then click the “Override Refresh Rate” Button.
3. Set the refresh rate override value to 60
Jan 30, 2010 | Computers & Internet
I'VE TRIed different keyboards, all are doing same. cannot type normal speed. every key i have to hold down before letter appears. takes me forever to type one word
I think this is what is happening: You have stuff running in the background that is interfering with your work.
Do this: in Win XP, choose start>run
In Vista, choose start
In the white space, type msconfig and hit enter
When you get the resulting window, click on the startup tab. Uncheck everything.
Now restart your computer. It will give you a message that your system configuration has changed. Be sure to click the little box on the left that says "don't show this again" or something like that.
Now try typeing.
Does it work? If so, you can go back into msconfig and check the stuff that you need to run on startup (like antivirus software). Check only what you really need.
Good luck.
Oct 10, 2009 | Logitech 967437-0403 Keyboard
Trying to get the asterisk @ for email on a computer
Probably your keyboard is set to a different character set or language. To fix this go to control panel and click keyboard properties, there should be a tab for input locals. This sets the language and character set for your keyboard. To use various characters, you can use start , then type charmap.exe in the box and it will bring up a character map where you can select various characters such as the copyright sign etc. to use. Most windows from 2000 newer also have osk.exe, this draws up an onscreen keyboard you can click with your mouse to type.
Aug 29, 2009 | HP Compaq Presario 2200 Notebook
Locked keyboard buttons
If the wrong characters appear when you are typing or you are trying to use a keyboard that is different than the one that came with the computer, use the following steps to synchronize Windows to the type of keyboard you have:
  1. Click Start c01311982.gif , and type region into the Start Search field.
  2. Select the Keyboards and Languages tab.
  3. Click Change Keyboards .
    A Text Services and Input Languages window opens.
    Figure 3: Change Keyboard button
  4. Click Add .
    Figure 4: Add button
  5. Select the keyboard(s) you want to use and click OK .
    Figure 5: Add input language: US Dvorak keyboard selected.
    The new keyboard is added to the list of available keyboards and a keyboard icon appears on the system tray, allowing you to switch between the keyboard that you want to use with the mouse.
    Figure 6: Keyboard tray icon
  6. From the Text Services and Input Languages window, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    Figure 7: Move up button
  7. Click OK . You can now use the new keyboard. If you find that the new keyboard works well and you do not want to use the other keyboard, repeat these steps and Remove the keyboard that you do not want from the General tab of the Text Services and Input Languages window.
Jun 02, 2009 | HP DC170B Keyboard
Gateway laptop keyboard typing incorrect letters
Windows has support for many input-languages, e.g., for keyboards made in France with accented characters,
and for the DVORAK keyboard layout (which is a complete
rearrangement of the letters on the keyboard for maximum
typing-speed).
Go into "Control Panel", and "Regional and Language" and click the "Language" tab, and switch to the "USA Keyboard".
Feb 18, 2009 | Gateway 7001433 Keyboard
Keyboard is messed up
Try looking here to see if any of the keys are set wrong.
Normal 0 If you are then go to Control Panel.
1. Click on PRINTERS.
2. When the Printer Properties come up, CLICK on KEY SETTINGS.
3. Then set up the keys by selecting the key to be setup.
Hope this helps. Bud
Dec 14, 2008 | Saitek Eclipse (PZ30AUR) Keyboard
Logitech S520 Mouse Logo
162 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
