Added 1 gb mem to laptop with 1 gb mem. Still shows 1 gb. Tried switching the memory and machine reads both ok by themselves but not with both installed.
SOURCE: ACER 9410-4933 LAPTOP ? Won?t boot with 4Gb CRUCIAL RAM
YES THE FREQUENCY OF BOTH RAMS DO NOT MATCH ... THATS BOOTING WITH EACH BUT ONLY ONE BY ONE ... YOU NEED RAMS OF SAME FREQUENCY AND SYSTEM WILL SUPPORT BOTH OF THEM TOGETHER ...
SOURCE: How easy is it to install RAM into a new sony vaio VGN NR110 laptop
Most current laptops have a lid/panel underneath the bottom covers hiding the memory. You need to turnover the laptop and visual inspect the bottom panel/cover. Memories often are readily accessible to the user. They are underneath a lid/panel which is roughly squarish about 2 X 2 inches. It is normally held in place by small screw(s). Upon screw removal, you need to pry open the lid cover to expose the memories. Pressing sideways on the 2 retaining clips of the memory would pop it out slightly which should then be relatively easy to remove.Popping in new memory is the reverse. Diagonally insert the new memories into the slots to initially set them in. Gently but firmly press on the memories downwards to lock them in place. You will notice that the 2 retaining clips will automatically lock in place.
Alternately, for a few more, you can purchase the memory from any computer shop/store and ask them to install hereby assuring yourself that the job was done right. Further the store will not have any excuse/reason when the new memory malfunctions and can be readily replaced.
Of course yo can do it yourself, it is relatively a simple job and if you are willing to take the risk (very minimal), go for a DIY (do-it-yourself).
Hope that this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
SOURCE: IBM Thinkpad T43 Memory
ok listen listen the answer is this the other memory is right under the keyboard. turn the lappy upside down the screws that hold the keyboard in are the ones mark with two triangle then open the lappy like you would normally for operation use a screw driver flat head is good put it between the bottom left or right corner better yet put it in line withe the down arrow key push the keyboard up as though you are pushing the function key closerto the top then pluck up the keyboard gently as you would a tin of paint gently a cable is there that connect the keyboard to the motherboard disconnect install the memory then work the steps backward
SOURCE: Acer Aspire 5601 4GB memory upgrade problem
did you try swapping the order of the memory sticks in the machine? for example, if you put stick 'a' in slot 1, and then put stick 'b' in slot 2, did you reverse it and put stick 'a' in slot 2 and stick 'b' in slot 1? sounds corny but i have fixed many computer memory issues in that way. also - have you verified you did not get a bad memory stick? can you boot (and will the computer recognize) stick 'a', then replace it with stick 'b'? try that and post what you find out here.
Testimonial: "Good advice. Thanks."
SOURCE: Can't get computer to recognize memory upgrade
Hello macvalland,
Here's a 12-step memory upgrade procedure from the tigerdirect.com website:
Upgrading Your Memory to Improve Performance
Compiled By Our Editors
http://static.tigerdirect.com/html/installingmemory.html
12 Quick, Easy Steps to Installing Desktop Memory
Increasing your computer’s memory is one of the most powerful ways to improve performance.. The following 12-step guide illustrates how you can install your desktop memory upgrade in 10 minutes or less with the use of a demagnetized screwdriver. But before you begin, make sure you are working in a PC-e environment. If you handle your circuitry improperly you can inflict permanent damage. Your PC’s biggest enemy is static electricity. Static electricity can damage your module and other computer parts. You need to ground yourself to avoid "shocking" your computer. Grounding yourself removes any static electrical charge your body might be carrying. To ground yourself, you can wear antistatic wrist straps or you can do the following: With your computer turned off, touch an unpainted metal part of your computer case with your hand. Plant your feet and do not walk around (because walking can produce static electrical build-up. Now you’re ready to proceed with our 12-step program for installing memory:
1. Make sure your PC has been turned off PC! You’d be surprised how many people forget this common sense first step.
2. Remove all the power cords from your computer system.
3. Remove all the screws that secure your computer case and put them in a place where you can
easily find them..
4. Remove the computer case. Usually you can simply lift the case off once you have removed all the screws. However, if you have difficulty removing the case, consult your computer’s user manual.
5. Locate the memory slots on your motherboard. In some PCs you will find then beneath a power supply or drive. If so, you may need to remove some additional parts in order to gain access.
6. If you need the replace an existing memory module, undo the module clamps and gently lift the memory module out of the slot.
7. Take your memory module out of its anti-static bag and hold it gently by the edges. Line up the notch on the bottom of your new memory module with the empty memory slot and press the new module down with your thumbs until the pins rest snugly inside the slot. You may have to exert some pressure! When will hear a click when the memory module is installed correctly.
8. Secure the new memory module by attaching the module clamps.
9. Put the computer case back on.
10. Replace the case screws to secure the case.
11. Attach your power cord.
12. Now that your new memory has been installed, turn on your computer!
Once your memory has been physically installed, the computer must install it electronically. Once your PC is turned on, you may have to go into computer BIOS to enable your system to detect the new RAM you have just installed. Refer to your computer us
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Vista
