Question about RCA Lyra RD2763 MP3 Player
Ticking noise It does not let me put music on it, it makes a ticking noise when i turn it on, and it deleted all of the music it self.
  • 32 Answers
The ticking noise is the arm inside the hard drive swinging back and forth in an effort to find the first sector of the drive. Best guess is a stuck spindle on which the platters ride. Another common name for this condition is called "stiction." If you feel comfortable, you can take the hard drive out and remove the cover off of it. Then, gently take your index finger and touch the edge of the platter and attempt to turn it. DO NOT touch the surface of the platter or play with the servo arm. You must do this in a dust free environment and as quickly as possible. Otherwise, you can take it to someone who is familiar with hard drive repair. Once it is working, you will need to a backup of the drive. Also, you will need to replace the drive because it will stick again. Good luck.
Posted on Jun 18, 2007
Cub cadet 524. Why won't it propel itself and makes an awful ticking noise?
Sounds like the plastic gears in the self propelled gear box are stripped or out of mesh for some reason. The clicking is most likely the gears trying to mesh
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Jan 24, 2016 | Garden
Hi I turn the heat on in my 06 dodge magnum I hear a ticking noise then goes away now no ticking noise and no heat
Could be your blend door getting stuck thats making that ticking noise. Check your heater hoses to make sure they are getting hot. Check with caution theu may be very hot.
Jan 02, 2016 | Dodge Cars & Trucks
Haier dryer makes ticking noise
The ticking noise could be either a piece of the belt hitting as it spins around, it could be something stuck in the drum that is hitting it as it turns too, or it could be the electric motor making the noise. Either way it sounds like you may need to tear it apart to see what's going on.
Jul 18, 2014 | Haier HLP140E Electric Portable Dryer
Ticking noise when ignition key turned
You need to put a better ground or a audio capacitor
Apr 06, 2013 | Car Audio & Video
There is a ticking noise everytime my car is on that sounds like the turn signal noise but theres no pattern or order to the ticking. i thought the hazard switch was bad, what could the ticking noise be?
It could be a relay clicking under the dash due to a bad ground circuit somewhere in the vehicle. It would be best to have a professional put an ear to it.
Jan 16, 2011 | 2003 Pontiac Grand Am
I have a ticking noise when i try to turn on the tv..
Try putting on the back piece. Some of these TVs have a circuit protection system that will not deactivate with the back open. (It is like an old circuit breaker with the fuse out.)
I hope this helps.
Jun 03, 2010 | Philips 50PL9126D/37B 50" DLP TV
I have a 1998 GMC k1500 and it makes a ticking noise eveytime u step on the gas?
WORN PISTON RINGS MAKE A TICKING NOISE.VALVE LIFTERS MAKE TICKING NOISE.WORN DISTRIBUTOR SHAFT BUSHINGS MAKE A TICKING LIKE NOISE.
Oct 29, 2009 | 1998 Chevrolet K1500
Samsung 2253bw lcd monitor makes loud, fast ticking noise > 10hz. Noise occurs even when monitor is powered off with switch.
Turned out ticking noise was harmonic vibration triggered by a nearby airconditioning compressor. Once I guessed the cause, putting a rubber pad under the monitor to dampen the vibrations eliminated the ticking. Removing the pad caused the ticking to reoccur. Ditto with turning the A/C off or on. Weird!
Jun 05, 2009 | Samsung SyncMaster 2253BW LCD Monitor
Ticking noise
Could it be an exhaust leak? A minor one can make a ticking noise.
Jan 14, 2009 | 1991 Jeep Wrangler
Ticking noise
lost contact use soldiring iron
Sep 19, 2007 | Sanyo AVM-3659S 36" TV
RCA Lyra RD2763 MP3 Player Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
