Question about Philips 52 In. LCD HDTV
No picture/intermitten picture
Hooking up Denon avr-789 to directv box, ps3 and 1080p tv using HDMI cables. intermitten picture while watching directv and white fuzzy picture while trying to use ps3. audio is fine..
  • 8,596 Answers
I just got through explaining this to someone else - the HDCP encryption system that Philips uses is not future-proof - you will continue to have this problem as long as you use an HDMI connection with a Philips TV. My advice, which you can take or leave, is to use Component (Red, Green and Blue) cables. you won't get 1080p, but you will get 1080i, which is pretty close.
-Tha Mp3 Doctor
Posted on Jan 18, 2009
How do I get HDMI cables to sync or talk to each other. We had this problem when we hooked up an Apple TV box to a Denon AVR-E400 and our Sony HD TV. We were told to disconnect all HDMI cables unplug
Personally I would use an RCA cable and hook up the AVR.
((RCA out of TV to AVR audio in))
((cable box HDMI cable output to TV HDMI Input1))
(As far as the AppleTv I would use a separate HDMI Input2)
If your AVR has a dvd or blue ray player Hook up a
HDMI cable out to another Input HDMI3 of the TV
using separate inputs on the tv will allow your surround system to be
used on all modes(CABLE,DVD/BLUERAY,APPLETV)
Sep 27, 2014 | Denon AVR-E400
No sound coming out of speakers tuner or cat/tv
Please add details of setup so I can help you. For example. My Directv box hooks into my HDTV HDMI. Sound is carried inside that cable. I then get sound on my TV from my Directv RCVR without any other hookup. But I do have more. I use an optical cable to go into my Denon 1312 TV/optical input. Since my Wii, PS3, VCR, and formerly Xbox360 all plug into the HDTV inputs and I use it to switch. The Denon is not HDMI capable so this is best for me.
This is the first thing I would try. hook the HDMI to your HDTV from the CATV/SAT box and turn up the sound on the TV. [Box and TV on and correct input used] If you hear audio, the hook it back up as before. Now, turn on the Denon to radio. and turn it up. Got sound?
NO: check speakers and speaker setting. Let's say you have speakers hooked to A but not B. is the selector on B or AB. That won't work. It has to match the hookup. If speakers are on A only, select A only, etc. Also check with known good speakers. Also check all cables to be plugged into the correct spot and plugged in fully.
Thanks PM me if you need more help.
Aug 07, 2014 | Denon AVR-1601 Receiver
Denon AVR-2807 HDMI out signal
i seem to have a similar problem with my Denon AVR 4310CI . The output to my LCD TV just went green . On checking with some people , they suggested resetting . it didnt work . Any probable reasons
Feb 06, 2010 | Denon AVR-2805 Receiver
Picture takes 1 min to show up on TV thru HDMI
There are firmware upgrades on (some) receivers, call customer support for Denon, or an authorized service center. They can help you over the phone. If you need more help, post a comment and I can help you further.
Aug 05, 2009 | Denon AVR-2307 Receiver
Reciever problem
How do I connect direct tv to denon and then get sound
If the RCA TV has HDMI input connect as follows:
1. Connect an HDMI cable from the Directv box to an HDMI input on the Denon.
2. Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV
3. Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV.
4. On front of denon press the input mode button to select auto
If the RCA TV has Component input (Green,Red,Blue) connect as follows:
5. Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR).
6. Connect a Component Video cable from the Denon to the RCA TV Component Video input.
7. Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8. On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows:
9. Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR).
10. Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11. Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV.
Feb 25, 2009 | Audio Players & Recorders
Connection problem with Denon 589 and direct tv
Feb 08, 2009 | Denon AVR588 Receiver
Best way to hook up all my componets
The best way to use the Denon and get your money's worth is to connect all devices to the Denon using HDMI connects if possible, if you use HDMI make sure you assign the audio if needed.
HDMI from Denon to TV. the Denon will upconvert all signals to HDMI to the TV
Jan 29, 2009 | Denon AVR588 Receiver
Denon avr-1907 sound from TV stopped working
Help with hooking PS3 to a Denon Receiver. It worked before, but I had to move everything to a different location and when I hooked it back up the PS3 has sound but no picture. I have it hooked directly to the receiver with and HDMI cable (the receiver is hooked up to our cable box which is directly hooked to the tv via HDMI cable).
Jan 03, 2009 | Denon AVR-1907 Receiver
Audio troubleshooting with an AVR Denon 900
ok i have the same reciver do you use hdmi to go to your tv or componet what ever you use there will be an audio out for rca on the cable box if you dont use a cable box keep reading but use hdmi to tcv then the rca audio out to the denon avr 900 obviously out it in the vdp/tv unput. and if you dont use a cable box your tv shoiuld have an audio output in the back of it for rca connect rca to audio output then other end to the denon avr 900s vdp/tv input
Dec 27, 2008 | Denon AVR-900 Receiver
Denon avr-1909 crackling sound while watching Uverse HD.
It may may the the AT+T box is really not compatible with the AVR or the Pioneer.
Check the specs on those input/outputs for the Ubox and the receiver.
See if they agree. If so, try another hookup method like HDMI ( which carries the audio too)
Nov 05, 2008 | Denon AVR-1905 Receiver
Philips 52 In. LCD HDTV Logo
260 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
