Question about 2wire Wireless-G 802.11g ADSL Gateway
My xbox360 will not obtain an ip address[from my 2wiregateway]
I have my 360 connectected wired,my 360 recognizes the connectivity but cannot obtain an ip address
    Sergeant:
  • 366 Answers
Set router DHCP server on
Posted on Jan 20, 2009
Will not assign IP address
Steps for these found on http://support.xbox.com/en-US/xbox-live/connecting/error-cant-obtain-ip-address-router-modem-978976 and include
1. Restart modem and router2. Check wireless password3. Configure IP settings manually 4. Set an alternate MAC Address5. Turn on DHCP.6. Bypass router entirely and connect instead to the modem using a wired connection
Aug 09, 2012 | D-Link DGL-4500 Wireless Router
Microsoft Wireless Network Adapter Xbox 360 can't connect to xbox live and cant obtain IP address
if its having trouble obtaining ip address it sounds liek you need to manually config the connection on the xbox by typing in the name and any wep key and than going into your router and making sure it has multiple ip's available for the xbox for my xbox I had to enter the name of the connection because it was a weak signal despite the proximity I changed it to connect to linksys which was my router name at the time and never had another problem I hope this info helps if nothing I suggested works it may be a problem with your adapter just not having the signal strength if you have had it connected via wire in past and know the router will accept other computers than I would have to say this is your problem
Hope I helped
Please leave feedback
Thanks
Robb
Apr 02, 2010 | Microsoft Wireless Network Adapter Xbox...
Cant get on to xbox live using wired connection
If you are connecting the system directly to your Broadband Modem than your ISP may have your regularly connected computer's MAC address logged in their system. Generally only Cable Modem companies do this, so to see if that is the problem do the following:
1. Locate your Cable Modem
2. Flip it upside down and locate the MAC address, it should look like this:
3. Write down the MAC address
4. Now turn on your Xbox360 and go to the network configuration menu.
5. find the part that says CLONE MAC ADDRESS and then put in the MAC address you wrote down.
6. after the settings have been entered back out to the main menu, and power off, then power back on your Xbox360, you should be able to get on line now.
Jan 02, 2010 | Microsoft Xbox 360 Console
Xbox 360
  1. First, turn your Router off and wait for a couple of minutes (unplug power from the wall)
  2. Turn off your modem (unplug power from the wall)
Reboot both the devices and they will obtain a new IP address.
Let me know.
Jul 09, 2009 | Microsoft Wireless Network Adapter Xbox...
Dynex 4 port hub xbox 360 IP address error
Here is a link to their Support site: http://support.xbox.com/support/en/us/nxe/default.aspx Select "Troubleshooting/Connection" errors page. On the LEFT, select "Network Help". That should put you in the area you need.
Jun 12, 2009 | Dynex 4-Port 10 Mbps Ethernet Hub
PHYSICAL IP ADDRESS NOT RECOGNIZED, IT JUST SAYS FF-FF-FF-FF, AND DOESN´T RECOGNIZED THE IP ADDFRESS FOR THE INTERNET CONNECTION?? PLEASE HELP, DO I HAVE TO FORMAT MY COMPUTER OR I JUST NEED A DRIVER?
Update the O/S first
Check the connection is DHCP
control panel,network connections, right click your connection to the internet, properties,
TCP/IP VER4, highlight this in grey, click properties,
should be set to
( obtain I.P. automatically ) tick this box.save it.
Reboot the system.
hope this helps
Regards
Apr 19, 2009 | Toshiba Tecra M2V-S310 Notebook
My xbox 360 says i need an IP adress
The XBOX is configured for connecting to a router or server that will assign it an IP address. Connect it to your router instead of your laptop.
Jan 06, 2009 | Microsoft Xbox 360 Console
Xbox live
THINGS TO TRY loadTOCNode(1, 'whattotry'); Direct connection with a modem only loadTOCNode(3, 'whattotry'); 1. If you are connecting to Xbox Live by using a modem that is connected directly into your broadband socket, your IP address settings are obtained from your ISP. Set your IP address in Network Settings to Automatic. 2. If you use a static IP address that you obtained from your ISP, you must manually enter this address in the Dashboard. Contact your ISP for their static IP address if you do not know it. If the IP is not static, continue with the rest of the troubleshooting. 3. Power cycle the modem. 4. If your ISP requires PPPoE settings, verify that you have entered them correctly. 5. If your ISP does not use PPPoE authentication, do not use these fields in the Dashboard. Shared connection with a modem and a router loadTOCNode(3, 'whattotry'); 1. Power cycle both the modem and the router. 2. Try connecting the Xbox 360 console to Xbox Live by using the modem only. This eliminates any configuration problems on the router. • If this setup works without the router, there is a configuration issue with the router. See the router's documentation or contact the technical support group. 3. Verify that your router's DHCP service has been enabled. See the router's documentation or contact the technical support group. 4. The IP address that you entered in the Network Settings area of the Xbox Dashboard may be incorrect. Set your IP settings to Automatic. 5. If your ISP requires PPPoE settings, try to connect with only the modem after you enter the PPPoE settings in Network Settings. • If you can connect, see your router documentation to configure the PPPoE settings correctly on the router. 6. If you are receiving an IP conflict error in the More Info section, turn off all the devices on the network. Try to connect with only the modem and Xbox 360 console connected. • If this works, there is a configuration issue on the routers DHCP server. See the router's documentation or contact the technical support group. Shared connection with a gateway device (combined modem and router) loadTOCNode(3, 'whattotry'); 1. Make sure that the device is turned on. 2. Verify that there is activity with the blinking lights sequence WAN, ADSL, and Internet connected power. Note These names will vary from model to model. 3. Power cycle the gateway device. 4. The IP address that you entered in to the Network Settings area of the Xbox Dashboard may be incorrect. Set your IP settings to Automatic. 5. If you are receiving an IP conflict error in the More Info section, turn off all the other devices on the network. Try to connect with only the Xbox 360 console on the network. • If this test works, there is a configuration issue on the gateway DHCP server. See the router's documentation or contact the technical support group. Shared connection with Microsoft Windows Internet Connection Sharing loadTOCNode(3, 'whattotry'); 1. Verify that you can browse the Internet. If you cannot browse the Internet, Internet Connection Sharing is not configured correctly. 2. Power cycle the modem. If the modem does not have an on and off switch, unplug the modem from the power outlet. You cannot follow this step if you are using a USB modem. Instead, go to the next step. You must follow this step if you are switching the modem between the Xbox 360 console and a computer. 3. On the computer, click Start, click Run, type ncpa.cpl, and then click OK. 4. On the View menu, click Tiles. 5. If the connection is listed as Firewalled, the firewall may have to be configured. See your firewall documentation. 6. Enter manual settings in the Dashboard for IP address, subnet mask, DNS address and gateway: • IP Address : 192.168.0.2 • Subnet mask : 255.255.255.0 • Default Gateway : 192.168.0.1 • DNS server (Primary): 192.168.0.1 • DNS server (Secondary): 192.168.0.1If none of this works you might be banned. If you modded your xbox360 or for downloading game saves from the internet to boost you gamer score. You might be banned!
Oct 14, 2007 | Microsoft Xbox 360 Console
Wireless adapter
It sounds like you have an access control (allowed MAC address) list set up on your wireless router and have not added your Xbox 360's MAC address to the list.
Aug 15, 2007 | Microsoft Xbox 360 Console
Problem connecting to the net
You router may be set to be DHCP enabled so that it allocates the ip addresses automatically to each pc, so check that the pc's network card with connection problems is set in the properties on the TCP/IP line is set to obtain an ip address automatically. You can also try, Start>run then type ipconfig /flushdns to clear the pc ip address and dns. and restart pc. Lastly if you pc is both network cabled and wireless, ensure one or the other is dissabled as this can confuse the ip adress alocation.
Apr 29, 2007 | Linksys Wireless-G WRT54GR Router
Open Questions:
See all 2wire Wireless-G 802.11g ADSL Gateway Questions
2wire Wireless-G 802.11g ADSL Gateway Logo
171 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
