Question about Garland H283 Gas Kitchen Range
Frigidaire oven pilot light won't light
The pilot light went out on the oven. the stove work's just fine. the pilot light won't light. Help please!!
  • dusteerust Apr 08, 2009
    i was cleaning my stove top and the pilot lights wont light i cant figure out how to get the top to come up so that i can light it
SolutionGuy
  • 331 Answers
SOURCE: Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Posted on Aug 15, 2007
SOURCE: oven pilot light won't light
you must push and hold the button on the bottom fo the safety valve until the thermocouple is warm enough to keep the safety valve open. @ 25 - 30 seconds
Posted on Feb 05, 2008
Part of the problem was my own ignorance about this particular Kenmore gas oven. It doesn't even have a pilot light. Instead, there is an electric heating element close to the burner which gets so hot that it ignites the gas. It seems that the heating element also doubles as a temperature sensor, so that it opens the gas valve only when the heating element is hot enough to ignite the gas. This heating element, called the "ignitor", no longer gets hot in my oven even though there is 120VAC applied to it when the oven knob is turned on. Therefore, the ignitor is defective. I ordered a new one on-line from "Appliance Parts of America" for $31.50 plus shipping, and this should fix the problem. If it does NOT, I'll add to this post.
Posted on Apr 21, 2008
aborcass
  • 2651 Answers
SOURCE: premier 30 inch gas stove oven does not light
do you hear any clicking when you try to start the oven portion of the range? if not lets try this, open the lower drawer so you can see the burner bar and mechanism for lighting the bake bar. as your watching the mechanism turn on the oven (nothing should happen as per your issue) while oven is on try lighting one of the top burners, any one will do wanna check if that lites the spark and in turn lites the oven pilot.if that does infact work you have a bad spark switch for the oven control
Posted on Oct 29, 2008
SOURCE: Gaffers and Sattler vintage stove oven pilot 1956 W54 series similar problem
My mother had the same problem with her Gaffers-Sattler range. No one could figure out what was wrong with it. Her local new appliance repair people said to contact J.E.S. Enterprises, Inc at www.theoldapplianceclub.net. Whew; thank God for that tip. They knew exactly what the problem was and repaired the unit for her. The stove is running again like a workhorse! Here is their number - 805-643-3532.
Bob Allen
Posted on Nov 24, 2008
Oven pilot light won't light. Stove burners work fine.
if you have a pilot flame oven replace your thermocouple
if you have a newer oven you will have an ignitor
please advise me on whitch type of oven you have
Feb 05, 2013 | General Electric ge JGBS04BPW wb1k5 Oven...
We have a Frigidaire electronic ignition range about a decade old. The stove works fine. But lately we've noticed if we're using any stove elements the oven won't ignite and heat up. Conve
Sounds like the pressure regulator on the stove is going bad. The pressure regulator is located in the back. Your gas supply line should connect directly to it.
Dec 23, 2012 | Kitchen Ranges
On my GAS stove and broiler work fine but my OVEN does not light. I do not hear the pilot light or spell any gas. Where or how can I check
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Apr 29, 2011 | Frigidaire Ovens
Won't get hot, smells like gas
Most of these new fangled gas stove feature a silicone carbide ignitor to light the oven. Older stoves used a standing pilot light. As silicone carbide ignitor age a little they tend to get weak and fail to open the gas safety vave sufficiently enough for ignition. Take a look
Jul 06, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
OVEN PILOT WENT OUT
hopefully the gas smell isn't too strong and posing a hazard to you. If it is, reach behind the range and turn the valve until it is across the gas line and not parallel to it. You should be able to raise the top of the range from the front and see all the workings underneath. There you will find the pilot light.
Feb 14, 2009 | Tappan 24 in. Freestanding Gas Range...
Pilot light
It was an electric ignition
Thank you
Nov 11, 2008 | Frigidaire FGB24S5A Gas Single Oven
Apr 21, 2008 | Kitchen Ranges
It is usually a bad thermocouple. Mine had only had a weak pilot flame and the problem turned out to be a corroded and leaking pilot gas line. It was leaking whee it enters at the bottom of the oven chamber.
Mar 05, 2007 | Garland H286 Gas Kitchen Range
Garland H283 Gas Kitchen Range Logo
892 people viewed this question
Top Garland Kitchen Ranges Experts
John Tripp
John Tripp
Dennis Boxerman
Are you a Garland Kitchen Range Expert? Answer questions, earn points and help others
