Question about ASUS Eee PC 900 16G Notebook
Computer will not start up windows start up window keeps running.
I have an asus eeepc this windows start up window keep running without the computer going to the desk top
    Genius:
  • 1,269 Answers
When the computer is booting, keep pressing F8, that will give you an option to login. Select Last Known Good Configuration and enter. check if that boots the computer to desktop.
Posted on Jan 16, 2009
  • 238 Answers
One of your system files is missing/corrupted. The solution for this is to insert your Operating System disc. You can Repair the missing/corrupted file using your Operating System disc, it will not remove your files saved in your harddisk so you don't have to worry about that. Just choose the option Repair.
  • ASUS Master
  • 19,396 Answers
That usually means that you have to reinstall Windows.
On an Eee there is no CD, therefore you need to install from a USB pen drive.
Copy the recovery disk on the USB stick, or if you have one use an external cd drive to reinstall Windows.
Try first unplugging charger and removing battery from eee, but this rarely works.
ASUS EeePc 1015PEM reboots at windows startup. even with new hdd and fresh install. ok when in bios screen or if i boot into linyx
Which windows OS are you using? windows xp, 7 or 8?
Anyway the problem might be corrupted installation CD. If you install windows on other computer using this CD, so if CD is OK, then
start your laptop and press F8 repeatedly until Windows Advanced Boot Options appears. Then choose automatic restart on system failure. This option will allow you to see Blue Screen Of Death and to understand what causes a problem.
Sep 21, 2013 | ASUS - EEEPC Eee PC 1015pem-pu17-wt...
Formatting asus notebook eeepc windows xp version 2oo2 service pak 3
to format a computer, go to start, then click all programs, accessories, then RIGHT CLICK command prompt. RIGHT CLICK. hit run a administrator. then when the black window pops up, type:
format x
replace x with whatever drive you want to format. hope I helped.
Jan 31, 2011 | ASUS Eee PC 900 Notebook
EeePC Asus mini notebook. Semi colon appears and keeps repeating after I type some characters. I reinstalled windows xp and upgraded to windows 7 same problem
i dont believe this one---make sure you have the correct keyboard country settings enabled other than that corrupt soft,make sure you have the correct OS as supplied by Asus
Aug 31, 2010 | ASUS Netbook
I have a asus eeepc 900 netbook.suddenly it stop booting & everytime showing"windows could not start because the following file is missing or corrupt:Windows/system32/config/system.You can attempt to...
Windows could not start because the following file is missing or corrupt:
/WINDOWS/SYSTEM32/CONFIG/SYSTEM
You can attempt to repair this file by starting Windows Setup using the original Setup CD-ROM
Select “r” at the first screen to repair
So then i click r at the first screen and nothing happens...It keeps on repeating to repair on and on with the same message after i clicked r. I can't even access to the window...what can i do???
Jun 15, 2010 | ASUS m6n Notebook
Is it possible to install windows operating system on an asus eee pc 701sd and how would it be done with no disk drive
Insert the windows disk in the CD-Rom drive in the computer, then press F12 when you first turn it on. keep pressing it until a menu appears. In the menu, select whichever option is the CD-Rom drive. then follow the onscreen instructions to install Windows.
Feb 21, 2010 | Asus Eee PC 701Sd Notebook
I have an asus eeepc 900. i have an error message
hi charmed4031this netbook comes with an internal harddisk on which windows is installed but lacks any optical drives so far.
You will have to get an external CD/DVD-drive plus a Windows-CD for it from which you safely can reinstall windows or replace the missing file. Please find out which windows version you are using(Win200, Win XP Home for e.g.,), lend or buy this external drive, connect devices and let the computer work it's magic, if still facing diffifculties, you know where to find us ;-)
Sep 18, 2009 | ASUS Eee PC 900 16G Notebook
ASUS eeePC 900 Keeps rebooting at XP load screen.
You're computer is booting that's not your problem. Its just not booting into Windows which is a different subject, so a boot disk will not do you any good. You have some corrupted files at the Windows end not the start up end. The only way to correct the Windows corrupt files is to use a Windows disc. So you'll have to buy/borrow a portable DVD/CD player and a copy of windows. Once the Windows disc loads then its just a matter of clicking on "repair" when the disc asks..that one of the drawbacks of netbooks..If you have any questions let me know..
Apr 20, 2009 | ASUS Eee PC 900 PC Notebook
I have an asus eeepc and the windows startup window keeps going over and over without going to the desk top
boot loops usually indicate 1 of 2 thinks
- a corrupt or damage operation system
or
-a bad hard drive
unfortunately, i know these netbooks don't have a disc drive, but if you have access to an external one, see if you can get your hands on a hardware testing program like drive fitness test. if that passes, you know your operating system needs to be reinstalled.
Jan 16, 2009 | ASUS Eee PC 900 16G Notebook
My asus eee pc may have a virus
Are you on Linux or Windows XP? Given that Linux is nowhere near as bad as XP for viruses, I'll assume XP.
If on Windows, keep pressing F8 on Post (machine Switch on).
From the menu of options, select 'Safe Mode' - this is a mode that deactivates all start up programs and drivers.
From within here run a virus AND spyware scan.
You can get free Anti-virus from www.MajorGeeks.com
Use AVG Free Adition or Aviva (aka Antivir)
For Spyware, use Spybot
You will probably need to download on another computer.
Jan 11, 2009 | ASUS Eee PC 900 16G Notebook
COMPUTER NOT STARTING..
What u do before restarting EEEPC Please Tell Me So I can Solve Your Problems
Dec 06, 2008 | ASUS Eee 4G Notebook
ASUS Eee PC 900 16G Notebook Logo
57 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
