Question about Jura Capresso Impressa E8 Espresso/Coffee Maker
Capresso s8 weak coffee
Would you have any idea what would cause the capresso s8 to produce weak coffee over time? Does it need cleaned really well with cleaning caplets or does it need to be taken apart and cleaned or anything else?
  • boggsg Jan 29, 2009
    Thanks, anyway.
  • 4 Answers
You should probably run a cleaning cycle with a cleaning tablet (the one you drop into the ground coffee shoot, not a decalcifying tab).
This will clean out all the insides where coffee particles and oil can accumulate.
The machine will ask you to run a cleaning cycle after a certain number of cups brewed. But you can also manually start it.
(this is copied from the manual)
You can run a tablet cleaning cycle at anytime even if
the machine does not prompt you,
• READY. Push and hold the Rinse button until display shows
RINSE. The Dial illuminates.
• Turn the Dial until display shows CLEANING. Push the Dial.
Display shows EMPTY DRAWER.
(Follow the rest of instructions for regular cleaning cycle)
Posted on Feb 21, 2009
  • 515 Answers
I can not this type of machine:-(
I have seen a similar machine and there they use a caplets when they clean it, but i´m not sure how to do with your machine.
Best regards
Posted on Jan 29, 2009
My Capresso s8's display is blinking and making strange noise
All Jura machines in the series C, E, F, J, S & Z models have the same problem. The Jura recommended maintenance is insufficient or erroneous:
1- When new machine is set up, the owners click OK for use of Filter cartridges. This helps only to display reminders for replacing the filter.
2- The instruction also advises, regular use of Filters, eliminates descaling the machine. That is not accurate. Reminders for descaling are delayed or eliminated. This allows accumulation of Calcium deposits in the entire hydraulic and coffee system.
3- Cleaning tables recommended & sold by Jura do not remove Calcium deposits in the coffee/water passages. The automatic descaling method recommended by Jura also leaves the coffee side of the machine unclean. The error message in your machine is due to Calcium deposits in the Brew group, coffee outlet & the faucet dispensing coffee in the cup. I suggest all Jura machine owners should manually descale machine. Manually descaling includes use of 6 to 10 rinse cycles with descaling solution in the water tank. The error message "Clean Machine" is accurate & pointing to descaling the Brew group, coffee outlet tube and coffee dispensing faucet by using rinse cycles.
After the rinse cycles are complete, refill Descaling solution & continue descaling the rest of the machine using hot water dispensing function, until the tank is empty. Finally, give a final flushing of machine to flush out remaining descaling solution inside the machine.
Services Unlimited Inc Parts Guru Since 1988
Sep 23, 2016 | Jura Capresso Impressa S8 Coffee Maker,...
I have problems with my jura capresso f60, it no longer makes coffee, it grinds the beans, but no liquid comes out. On the screen it says open tap, we have no idea how to fix this.
Machine thinks that there is no water getting to the machine. Majority of the time, this is caused by blockages of coffee in the brew group due to improper cleaning. I'm not saying that you haven't been cleaning it but that is usually the cause. How old is the machine? And has there been a cleaning tablet been put through it every day? Advise removing the brew group and check all pipes are clear, clean all loose coffee and check if you can blow through all of the pipes if you can loosen them. Clean coffee outlet/spout also. If the machines water is fed from a tank, It could also be a small bit of dirt has been pulled through. Hope this helps.
Mar 30, 2011 | Jura Capresso Jura-Capresso Impressa F60...
I was going through the decalcifying process and the message "empty tray" displayed (Jura Compresso Impressa S8). I removed the tray, cleaned it, replaced it, but the message remains as "empty tray" and I...
I had the same problem and had success with cleaning the contacts in the back of the machine with a small nail file/emery board. I found that the contacts that are inside the machine had a little calisification on them. Once they were cleaned up no problem.
Aug 15, 2010 | Jura Capresso Impressa S8 Coffee Maker,...
No steam on Capresso Impressa S8
Most likely problem is over temp cut out switch. Small diode attached to the boiler to prevent damage during boil dry, or fault in the heating element itself. Difficult machines to repair and best handled by a service technician.
Sep 13, 2009 | Jura Capresso Impressa S8 Coffee Maker,...
Went to make a cup and only got about a qt. of a cup. tried again and got no water at all can you help
I own a Jura Capresso S8 espresso machine which has been wonderful except for the pump that makes the froth. I sent it back to be repaired once already, at the tune of $250.00. Now it seems to have gone again, and this time it will cost me $275.00 to have it repaired. Anything I can do myself?
Aug 14, 2009 | Jura Capresso C1000 Espresso & Coffee...
Jura Capresso C3000 keeps saying clean unit
We have the S8 here at our office. Ran the cleaning cycle and "Clean Now" message was still on and beeping afterwards. Read the Feb 28 comment and carefully cleaned everything that had grounds stuck to it. Ran the cycle again and it worked. Thanks all.
Feb 28, 2009 | Jura Capresso Impressa S8 Coffee Maker,...
Malfunction code 8 on Jura Impressa s8
To fix this problem you need to clean the layers and layers of coffee mud off the plates that dispense the spent grounds into the hopper. My suggestion is to do this major muck cleaning before you even put the cleaning tablet in.
Get a flashlight and pull the trays out and have a look at the mechanism that dumps into the hopper. You will see the layers of gunk that need to be scraped off. Easiest thing to get in there is a finger to start, then place it next to your sink and clean it with a water jet from your kitchen faucet, provided your faucet will allow you to do that. Let the runoff go into the sink of course. After you get it cleaned up, then put the machine through the cleaning cycle.
If you can't get the problem solved, the fix is a flat $200 from Capresso.
Call the number above to get set up with a service shipment, done in PA.
Devin in Ohio
Nov 21, 2007 | Jura Capresso Impressa S8 Coffee Maker,...
Jura Capresso Impressa E8 Espresso/Coffee Maker Logo
872 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
