Question about InFocus TD40 40 in. LCD Television
Suspected power problem
Got one of these TD40's and the past year its been cutting off. I turn it on and it will run for 10 hours straight no problem. but sometimes it cuts off after 30 seconds to 2 hours. the light on the front just blinks amber. called the company it cost over 1000 bucks for them to fix the problem. Is their a tech manual available. If i know the cause of the problem as long as its not the main board i think i can fix it. Has anyone else experienced this problem can you give me some tips.
5 Suggested Answers
Marrie
  • 563 Answers
SOURCE: My LP 750 is dead
Hi there
This sounds like a faulty Mainboard - could you supply me with your country and the part number on the Mainboard ?
Posted on May 13, 2008
projdoc
  • 2237 Answers
SOURCE: A power cut whilst the projector being used,
it could be the fan, colorwheel or high temp. remove the lamp and turn it on. do the fans spin? if not, replace the fans. does the colorwheel (colored glass wheel near the lamp) spin? you should be able to see it and hear a high-pitched whir. if not, replace the colorwheel. if the lamp was still hot when it was turned off, you need to let the fans run and cool. then unplug it, plug it back in and try again.
Posted on Nov 09, 2009
projdoc
  • 2237 Answers
SOURCE: after green blinking goes out, image appears for
fan issue. make sure they are all spinning and replace as necessary.
Posted on Mar 18, 2010
heathgr
  • 442 Answers
SOURCE: I went to turn on
Check that the air vents are clear of all blockages, dust etc. filter is clean and cover on firmly.
Posted on Mar 19, 2011
Troy Bilt TB575EC cutting head hard to load, now doesn't spin.
Remove the cutting head spool and see if you have old grass stuck around the shaft area that could be causing to cease your shaft..
Mar 03, 2018 | Troy-Bilt 4 Cycle Straight Shaft String...
Why does my garden tractor shut off in the middle of cutting? Sometimes just the blades turn off and sometimes the whole thing just shuts off as if I turned the key off.
can be a weak coil, very wet grass, or lack of maintenance. have the valves regapped if not done in the past 300 running hours
Jul 05, 2011 | John Deere Garden
Blade wonders on straight cut
When doing any straight cut use a straight edged piece of something to run the jig saw along, using as a guide, this will usually keep it all straight, sometimes it can be a loose blade, or a bent shaft?
Mar 08, 2010 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
Sound cuts out in Westinghouse LTV-32w6 HD TV
is it ran through a HDMI cable?
sometimes the source is at fault or it could be a bad hdmi cable or maybe a bad hdmi port. if your using a hdmi try plugging it into another hdmi port and see if that helps
Jan 06, 2018 | Westinghouse Televison & Video
I have a 10'' table saw
If it cuts straight it's fine. It's likely just some play in the bearings. I wouldn't worry about it unless it starts to cut not so straight...
Oct 06, 2009 | Craftsman 10" Table Saw
Dometic Duo Therm Ac, Fan runs, Compressor cuts in and out?
your compressor is locked up. i would try replacing the round start capacitor. you need to check what the exact rating for yours is but I believe one of these two will work for ya. In the meantime do not continue to try to run it, it will kill the compressor.
seth
53-64 mfd
45-53 mfd
Jul 19, 2009 | Dometic Rooftop RV Air Conditioner
It just won't keep running after running fine a while.
PROBLY NOT TRIP CHARGES ARE AT LEAST 45.00 AND THEN 65.00 PER HOUR PLUS PATS WHICH ARE EXORBENT
May 20, 2009 | Mitsubishi VS-55707 TV
Cutting straight
The tension on the blade. the position of the guide rollers, and the condition of the blade are all important to get a straight cut. You might want to try lowering the guide rollers down close to the wood being cut. good luck.
Apr 26, 2009 | Ryobi 9 in. Benchtop Band Saw
Starst and runs for a while and sometimes only for a few mins
Does the car seem to run ok untill it dies ? if yes it sounds like the ignition module
Jan 16, 2009 | 1992 Buick Park Avenue
Engine runs for short period and cuts out.
Check the fuel and air mixture screws when it is running .Turn them so it almost stops then start turning them until it runs smoothly
Nov 13, 2008 | Garden
InFocus TD40 40 in. LCD Television Logo
35 people viewed this question
Top InFocus Televison & Video Experts
rostit
Are you an InFocus Televison and Video Expert? Answer questions, earn points and help others
