Question about RCA RT2760 System
RCA RT2870 USB won't allow playlists or let me skip folders
When I load 4 folders with 10 mp3s in each folder from my PC to the USB Flash stick device, and then plug it into the RCA RT2870 USB plug, and select "USB mode", it reads the USB device as "F4 T40" - so that means 4 folders (the "F'), and 40 songs total (the "T").
My question is how do I get to F3 (or Folder 3) without having to press the remote control "skip button" 20 times in order to get to song #21 (i.e. the first song in Folder 3?)
Do I need an mp3 player to do this? And if so, what mp3 player is compatible? I already tried my Ipod Nano, and it wasn't compatible for the USB mode. I tried running it through the "line-in" Mode and it sounded disappointingly bad.
Thanks for any help.
  • PrairieHawk Feb 11, 2009
    Same thing here. The only partial solution I've found is to dump all the songs into one folder and use "random", like an Ipod Shuffle. But I'd really like to be able to choose songs by their name.
I have this same system and it looks like the USB playback is lacking this feature, of switching folders. A workaround is to use shuffle play to jump to one of the last songs in the first folder, then turn off shuffle and skip forward a few songs until you get into the next folder....and so on. Not very good, but for this price I was glad to have USB playback.
Some generic MP3 players will work in the USB port, but they play exactly the same as a USB drive. SO no real solution for this.
Posted on Aug 02, 2009
Can't create a playlist on rca pearl mp3 player; it wants to play all songs by genre, etc. additionally, it won't even ''import'' certain songs.
Step 1. Put the playlist in a regular Windows folder on your desktop.
Step 2. Open a window for Window Explorer and navigate to your Rca Pearl which should show up as a portable USB device.
Step 3. Open the Explorer window for the device and navigate to the "music" folder.
Step 4. Drag and drop your playlist folder that you created into this folder.
When you navigate through the pearls songlist the name that you gave the folder will show up AND all the songs in that folder will play in order...... DONE!!!
Apr 03, 2010 | RCA Pearl TH1102 MP3 Player
Shuffle All Works only with 1st 250-300 odd mp3s from total 670
i dnt know how to remove my password so plz tell me how to remove my password
Apr 15, 2009 | Philips GoGear Flash MP3 Player
Sansa e270 playlist in rockbox
all tracks will be in their proper folder, but as far playlist (that is winamp playlist) rockbox will create a playlist unless you change it .....
here read 4.4 of rockbox
Mar 18, 2009 | SanDisk Sansa e270 MP3 Player
I have a technika View box sp-108 which alows you to view your ipod videos etc on the 7" screen. it also doubles up as digital picture frame allowing you to load mp3 video and jpeg photos from flash...
Make sure you don't have to many folders or sub folders, best to keep it simple.
Wipe the card and format it as "FAT" not "FAT32" just right click your usb or SD card in vista or XP and select format.
Drop your MP3 album onto the card, If you use your USB Stick and SD card at the same time then it will default to SD and not play from both.
I found it would not read from one card unless I had a playlist, so I used a free program called Playlist creator 3 - get it here (only relates to MP3's)
I dropped and xvid movie onto the SD card and it played fine, just make sure you are in the correct menu 1st! and the movie isn't in some very old format as it may not play all codecs (encoding used to make movie)
Hope this helps
Sep 22, 2008 | Audio Players & Recorders
Philips GoGear SA3245 - Playlists Not Showing Up on Player
Have solved this problem on GoGear syncing with WMP 11 by going to options on the device itself, then go to the "settings" option, scroll down to "PC Connection Preferences", from here you will select the check box saying "MTP" then back out of options and connect your device and go back to your WMP 11 and drag your playlists to the syncing area and resync your device. You should then be able to see your playlists under the playlist option in music along with the "playlist on the go" playlist.
Hope this will help!
- Jared
Determan Technology LLC
Aug 31, 2008 | Philips GoGear SA3245/37 Digital Media...
Putting music into playlist
do not ADD mp3 tracks into the playlist folder. this is not how it works. connect the player to the pc, then transfer mp3s into the MUSIC folder. Get into the foled, right click on song you want to be on playlist, and option PLAYLIST comes up. press on it and a new window will open, with playlist options. you can drag and drop mp3s in there, and so you'll have your playlist.
Jan 17, 2008 | Samsung YP-U3 MP3 Player
Flash Drive
Open up "my computer" on your pc. Find your downloads from your Zune playlist and right click with the mouse on that folder. It will give you the option to move this folder. Move this folder to the drive labled "removable disk". This should work. Let me know if it does not work.
Cynthia Charczenko
Dec 19, 2007 | SanDisk 1GB Cruzer Titanium USB Flash...
Siren 4GB MP3 Player
windows media dont surrport mp3 u cant play mp3s but thats it. when u plug in the usb from ur mp3 player it should pop up new hardware found in the right bottom corner double click on that i should open up the mp3 folder after that just click and drag the music u want in to that folder and ur on your way. if u want a play list right click in that folder and go to new folder and label it what u want.
please rank
Nov 09, 2007 | Siren Edge MP3 Player
Sansa E250 Folder Problem
Must create playlist - so sorry
Nov 02, 2007 | SanDisk Sansa e200 MP3 Player
RCA RT2760 System Logo
538 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
