Question about iLO DVDR04
Dvd recorder I have a dvd stuck inside. It will play but when I'm finished it won't open to change dvd's. How do I get it to open. I tried unplugging it for for a few minutes to try to reset it, but it didn't work.
  • Anonymous Nov 12, 2007
    Ilo told me to remove the cover and use the manual lever to open the tray - THERE IS NO MANUAL LEVER!
I have this problem with my ILO quite often when leaving a disk in for a while. The only way to fix it is to take apart the recorder and manually remove the disk. The last time that I did this I dabbed the sticky part of the ILO with a Kleenex (to tone down the "stickiness"). Time will tell if this worked, but so far so good...
Posted on Apr 29, 2008
There may be a hole at the bottom of the player that has a slot for a flat head screwdriver. This is your manual release for the door kinda like the paperclip in a DVD / CD ROM drive.
Posted on Jan 20, 2008
I had the same problem. it was the disk that was left in the recorder for along time.
i disassembled the recorder (2 screws on the sides and 3 in the back) and took off the cover of the dvd recorder (4 screws). The disk was GLUED to the base it spins on...
i did it just yesterday and left it without a disk for 24 hours toprevent it froms ticking again. will see if that works...
Posted on Nov 19, 2007
You have to remove the dvd from the case. There is a small lever on the lower front where you used to push a pin to open it manually. Do not pull the try out without moving the release. It will destroy the dvd. I am speaking from experience. If the dvd is bad, you can replace it with a newer dvd. Might require surgery on the case though. If you have other questions, contact me directly offline at gamer1863@hotmail.com.
Posted on Nov 17, 2007
SOURCE:
Magnavox ZC320MW8 door stays open
f the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual.
God bless you
Sep 27, 2012 | Magnavox ZC320MW8 DVD Recorder Refurbished
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
My Samsung DVD/VHS recorder the DVD won't close after playing DVD
Never force it, just use the remote.
If it won't stay in, unplug the unit and wait a while.
I think we get viruses from the TV signal which might be temporary (hopefully).
Apr 24, 2012 | Samsung DVD-VR330 VCR and DVD Recorder
Jvc dvd player won't open
when you hit the eject button try tapping the top above the disk drive. it may be somewhat stuck. if that doesnt fix it you might have a broken belt or a belt may have come off in it. the belt controls the movement of the drive in and out
Mar 21, 2012 | JVC DVD Recorder - VCR Combos: DVD...
I have an AKAI DVD RECORDER DVDRW 120... 3565-1546/ My problem is that the tray is stuck and will not open. I do not want to pry it open and am hoping that you have a solution that can help me.I have...
This is a common problem. There might be a cd stuck inside (they ussually get stuck on top spindle) plug out and open cover and manually release cd
May 12, 2011 | Akai DVDRW120 DVD Recorder
URGENT! DVD not ejecting or playing.
It seems you will need to open the damn thing, or search for a tech, verify your warranty, dont void it.
First you can try to move a little bit the dvd, unplug and plug, change disc, ieverything that can move a part inside the dvd must be pressed, surely is stucked between the play and the open stage.
Jul 17, 2010 | Pioneer DV-515 DVD Player
DVD locked in and door is not opened
might have stuck inside...u got to open up the system onlly
Apr 01, 2008 | LG RH177 DVD Recorder/HDD Recorder
Dvd recorder stuck in Repairing Mode
I don't see any opening hole to retrive the CD inside the best option we can do is to open the the cover chasis and pull out the cd on the tray.
Thanks,
Mar 01, 2008 | Emerson EWD7003 DVD Player
LG RC195 VCR/DVD Recorder
You need to "Finalize" the disc, or it will not play on any other dvd player other than your LG. Finalizing the disc permanently commits any data onto the disc, no more writing or editing can be done.
Jan 23, 2008 | Computers & Internet
iLO DVDR04 Logo
116 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
