Question about JVC Audio Players & Recorders
Set up my JVC Rx-D702B last night - worked fine after a bit of consternation with the manual. Using KEF5.1 speakers w/subwoofer, Hdmi from my cable box to the reciever along with hdmi in from bluray, hdmi out to tv. After about 1.5 hours of being on, the 5.1 speakers stopped working - subwoofer works still. Speakers are fine - checked them on another unit. Using the test tone, no output except from subwoofer. Did a fuse blow or something worse. Tried a reset today but still the same
SOURCE: I have a new Denon
The Denon 688 does not process sound via HDMI, you have to run a seperate cable to get sound. Choices are analog audio jacks (red and white) or either a toslink (optical) cable or an rca digital audio cable.
Cheers!
Posted on Mar 26, 2008
SOURCE: XBox 360 to Reciever to TV via HDMI no sound
I recently got the same receiver and had the same problem. Here's what I was told - and it worked for me:
Even though HDMI cables carry audio and video, for whatever reason this reciever won't accept audio through hdmi. Apparently only much more expensive recievers carry audio through hdmi. What you have to do is run optical audio cables from your xbox, cable box, dvd player or other video device to the optical inputs on the back of the reciver. Then you customize the scene buttons to match your video and audio inputs.
You can get these optical cables pretty cheap on line or even at target. Don't get ripped off by Best Buy for these cables. I love best buy, but they rip off on cables!
This receiver is great - once I got it all figured out and running right I've loved it! Hope everything works out for you!
Posted on Mar 09, 2009
dunnbiker
  • 8546 Answers
SOURCE: Unable to play DTS-HD & True-HD
What do you hear? Do all other modes work ok?
If Audio Select (Page 44 and 98) is set to HDMI you will hear silence if no HDMI signal is present. I think AUTO is the best choice here.
On Page 98 of the manual it says a bunch of things concerning automatic signal detection and input selection.
Initial configuration D) INIT. CONFIG
Use this feature to select the settings of the audio input jack select, active decoders and extended surround when you tum on this unit.
Audio select AUDIO SELECT
Use this feature to designate the default audio input jack select setting (see page 44) for the input sources connected to the DIGITAL INPUT jacks when you tum on the power of this unit.
HDMI set E)HDMI SET
Use this feature to select the component to play back HDMI audio signals.
Support audio S. Audio
Use this feature to select whether to play back HDMI audio signals on this unit or on another HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = RX-V663
FUNCTION
Plays back HDMI audio signals on this unit. The HDMI audio signals input at the HDMI input jacks of this unit are not output to the HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = OTHER
HDMI component connected to the HDMI OUT jack.
NOTES
This unit transmits audio and video signals input at the HDMI input jacks to the HDMI out jack only when this unit is turned on even if "S.AUDIO" is set to "OTHER".
I'd look in these areas for specific guidance.
Posted on Apr 27, 2009
  • 3 Answers
SOURCE: I would like to hook up my components without
You should not lose any picture quality from the DVD player. I am currently having the similar setup with PS3 as the Blu-ray DVD player with HDMI and a Samsung DVD as regular player with component cable to a Samsung LCD TV. Remember the quality on Blu-ray is better than normal DVD so don't expect more than what it is.
Posted on Oct 18, 2009
  • 118 Answers
SOURCE: With Cable connected to the rx-465 input, I'm not
is the cable connection hdmi? is the unit capable of upconversion to hdmi, if you use a component connection? probably not. if it is capable of upconversion, check your input menu settings
Posted on Nov 03, 2009
My left channel in my JVC RX-305 isn't working...what do I do to fix it? When I either push the volume up or down it makes a clicking sound. It was working just fine last night. My right channel is...
Try swapping the speakers or just check the left connections WITH POWER OFF. Disconnect the left speaker completely and see if the clicking stops.
Sep 05, 2011 | JVC RX-618V Receiver
Yamaha Rx-V367 Subwoofer not working, I have new Polk Audio PS10 hooked up with Y-Adayer and Subwoofer Cable to Subwoofer Jack on backn of receiver. No sound in Radio mode which other 4 speakers work, in...
Have you looked at the manual?
The NEW thing doesn't work.
Does the subwoofer work for setup? That would certify the hardware and speaker definitions are ok.
The PC has the responsibility for defining and sending out something between headphone and full-blown 7.1 though the HDMI. Check your PC sound controls and the "Information on HDMI" section of the manual.
For the radio mode, probably the only analog stereo source you have, read up on the STRAIGHT decoding mode and Sound Field programs.
May 08, 2011 | Yamaha RXV367 Receiver
I have a JVC rx-888 receiver but I couldn't connect my subwoofer because I don't know what kind of RCA cable should I use.
Use any RCA cable. If you have been aquiring audio video equipment over the last years you probably have some lying around. The Red Green and Blue ones that came with your Flat TV which you are not using because you hooked it up with HDMI will do just fine.
Dec 03, 2010 | JVC Audio Players & Recorders
JVC - Problem connecting a Powered Subwoofer to a Receiver
Have you set speaker setup configuration to SUBWOOFER YES? Also check SUBWOOFER OUT ON/OFF button on the front panel.
Feb 20, 2009 | Pioneer VSX-D511 Receiver
Speaker wire for subwoofer
Usually, a subwoofer will have its own built-in power amplifier. Thus, it will be designed to plug into a standard RCA jack (the type used for DVD players, etc). rather than having wires to connect to a speaker terminal block. Look for a jack on the back of the receiver called "Subwoofer", or simply "SW". If your subwoofer has 2 single wires, it WON'T work with your reveiver's subwoofer output, as this output only carries a line-level signal and is not amplified. You would need a separate power amplifier for this type of SW. If your SW speaker has a DVD-type plug, it should work fine with the receiver's SW output jack.
Jan 02, 2009 | JVC RX-554V Receiver
No sound from speakers after connecting to pioneer a/v vsx81
I had the same problem and resolved it last night. You'll also need to connect an audio cable (EVENTHOUGH YOU SHOULDN'T HAVE TO - to bad pioneer didn't fully implement the HDMI standard in this receiver) solution. I suggest using an Optical cable. This really annoyed me...see the manual on P.17 section #3.
Dec 28, 2008 | Pioneer VSX-818V-K Receiver
YAMAHA RX-V1800 no Sound
There is an HDMI setting that should be set to through instead of rxv1800. See page 88 of the manual
Sep 13, 2008 | Yamaha RX-V1800
JVC RX-809V
Go to the following website www.servicemanuals.net where you can get the service manual for $17.00, unbelieveable, don't you think? The service manual should help you sort out your hookup problems. Good luck.
Jun 10, 2006 | JVC RX-818V Receiver
54 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
