Sony KP-41T15 I also posted this on the site, but I fixed the spelling errors :) I will replace the pico fuses, they are cheap anyway. As far as theservice manual, I did a search on that sight and didn't come up withanything for my model. I might need some direction as to which onesthey are. I don't remember what site I was on when I read about them.
  • 1 more comment
  • Joe1974 Mar 09, 2009
    I was able to get the service manual form somewhere else. It helped me fix another problem I created with the set while working on it. Like I said in the other comment I really haven't done anything else with it. I'm not sure what to do next.
    Thanks.
  • Joe1974 Mar 10, 2009
    I have a problem with another set, do you think you could look at it? I don't even know if I posted it right, I know I messed up the first time. This is the link to where its posted.http://www.fixya.com/support/t1767828-ve...
    Thanks
  • turnings4725 Mar 27, 2009
    I have a Sony KP-41T15 Projection TV. The image is distorted - curved image on top & bottom of screen. Convergence seems good - but the image is concave on top & bottom of screen.
    Thanks, Don
    Turnings@sbcglobal.net
    Don Westman
  • 8,617 Answers
I just called over there to speak with sonnt who said check the following fusible resistors on the D Board R1643,R1644,R1645, R1646,R1647,and R1648. They blow fastr when you have a convergence issue. There are all 0.1 ohm 1/6 watt resistors.
Also he mentioned they do have the manual its just not listed, but if you email them they will list it for you.
Posted on Jan 16, 2009
How to go in service mode for tv sony kp-46wt500.i did change the stk ic,the convergence is good in the midle but bad on the side
Did you replace the pico fuses on the G board there are two and usually one will blow when the old ICs fail and just replaceing the two ICs on the D board will usually not fix the issue untill the two pico fuses are checked and the blown one is replaced.
Mar 20, 2012 | Sony KP-46WT500 46" Rear Projection...
Replaced Convergence chips, same problem
This set has pico fuses on convergence board and also on G power board, there should be 2 5 amp pico fuses on power board.
If convergence is bad exactly as before double check the power board fuses and check to see if voltage (it is marked!) is there with power board disconnected from chassis..
Steve
Mar 01, 2012 | Sony KP-61HS30 TV
I have a similar problem as described as a convergence problem with my Sony KP-53HS30 TV. Can you elaborate further on the solution to repair. Which IC and protector fuses do I replace? Thank you.
Your model uses two STK392-560 Convergence ICs. also there are 6 pico fuses on the D board and two pico fuses on the G board which may need replacement also. The Sony type 1 convergence repair kit from www.tvrepairworld.com contains the IC's pico fuses and a few resistors plus instructions on CD of how to do the repair.
Aug 08, 2010 | Sony KP-53HS30 53" Rear Projection...
Replacing STK392-560 on sony KP-51HW40
If they are open replace them. Do you have an OHM meter?
Nov 22, 2009 | Televison & Video
KP-51WS510 convergence problem. Replaced IC's and pico fuse
Nothing else to look for but to Replace the Convergence Ic's
Nov 06, 2009 | Sony KP-51WS510 51" Rear Projection...
How do i find the gbord on this tv i need to replace the pico fuse
the gboard is the power board which is located on the far left hand side when looking in the rear. It has the power cord attached to it as well. The picos are both 5 amp IC protectors
Apr 02, 2009 | Sony KP-65WS500 65" Rear Projection...
Sony KP-41T15
It should as Sony usually have very thorough service manuals
Jan 16, 2009 | Televison & Video
Convergence Problem
most likely cause is one of the 3.5 amp picos have blown when the old Ics failed. You can get replacement picos at the following link, and they also have the service manual which will explain how to adjust the colors through the service manual. Here is the link.
http://servicemanuals.vstore.ca/
Jan 15, 2009 | Sony KP-41T65 41" Rear Projection...
Sony kp-57ws510 convergenece prblem
You didnt replace the STK's? You must replace the convergance IC's or you will continue to have this problem.
Sep 18, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
The red convergence is off
replace the convergence ICs post your model and I will post a link where you can get the parts and they include step by step instructions with pictures so you can do the repair yourself takes an hour and will save you about a 400 dollar repair bill.
Mar 30, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
