Question about Uniden 5.8GHz Dual Cordless Phone
Phones out of Range
We have a Uniden Power Max 5.8 GHz with three phones in this set. Due to teenagers in the house; the phones now don't work. Not sure if the phones are mixed up from their original bases (does that matter) but also have an error saying "out of range".
  • An0nymouse Apr 01, 2009
    When I am on the phone, the person on the other line tells me the phone is beeping twice, and when it double beeps four times, it hangs up and says out of range. even though I am fairly close to the base.
    Problem Solver:
  • 16 Answers
If you start over and unplug the home base and then plug it back in and set the time and date etc, then re register all the handsets by placing them into the base for 10 seconds each, that should take care of the problem,,,Good Luck.
Posted on Feb 15, 2009
Will a cordless phone interfear with your internet or the cordless phone if its to close to your internet box?
A wireless router and wireless network adapters can have interference issues with cordless phones. It depends on the network adapter frequency and the cordless phone's frequency. Most problems will occur with a phone that uses 2.4GHz. This frequency will interfere with 802.11b/g networks and single-band 802.11n wireless signals.
A DECT cordless phone operates at a different frequency from the 802.11g and 802.11n single-band and will not interfere with a wi-fi network with those modes.
However, some routers and wireless adapters can use the 5GHz range (802.11n and 802.11ac, among them). These can have a problem with cordless phones that use 5.8GHz. However, there is a simple solution to avoid much of the interference at 5GHz. First determine the frequency range of your phone by getting the FCC ID from the base of the phone. Then use Google or another search engine to find "FCC ID Search Form". It has been at http://transition.fcc.gov/oet/ea/fccid/ in the past. The first three characters are the Grantee ID for the search form. The rest is the product ID. Look for the SAR report for the phone and then (probably on the second page) find the TX frequency range and the Max RF output power tested. Now go to the wireless router's setting page and make sure that it is using channels that do not use the same frequency and power range. See http://bradsfavorite.com/avoid-interference-5-ghz-wifi-5-8-ghz-cordless-phones/ below the 5GHz Wifi Frequencies for a table with the channel and frequency ranges for routers.
I hope this helps.
Nov 01, 2014 | Lands Phones
Have Uniden EX14560 and do not know how to turn ringer back on..can you help me?
Do you mean the Uniden EXI4560 2.4 GHz phone? With the handset in standby, press the volume up button (above End and just below the LCD screen). Then you will be able to toggle between the 5 available ring tones and volume levels. (I'm assuming the unit is set to Ringer Off which is another choice in the list.) Press End to confirm and save your ring volume setting.
Most Uniden manuals are available from Uniden on the product page or the support page. The product page is http://www.uniden.com/cordless-phones/24-ghz-extended-range-cordless-technology/invt/exi4560g/ . Then go to the Manuals tab. The direct link to the EXI4560 manual is http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/EXI4560om.pdf .
All of the Uniden manuals are here: http://www.uniden.com/scat/cordlessphones_mnl . Use the drop down menu to select the type of phone and then find it in the list by numerical and alphabetical order. The EXI4560 is on page 4 under cordless phones.
I hope this helps.
Aug 25, 2011 | Panasonic UnidenEXI3226 : Two-Line 2.4GHz...
I have the Uniden Max 5.8 GHz and there are three phones, but one of them has all the info on it but none of the buttons work at all. What do I do?
SWITCH OFF THE PHONE REMOVE THE BATTERIES FROM ALL THE HANDSET, THEN INSERT IT AFTER 15 MINUTES, THEN DO THE INITIAL PROCESS, AGAIN IT WILL WORK AS USUAL.
Mar 16, 2010 | Uniden Cordless Phone
Will Uniden 2085 DECT phone work in india
The phone will not work with 220 V. And as an FYI, taking the unit out of the country will void your warranty.
Apr 01, 2009 | Uniden 5.8GHz Cordless Phone
Dead Uniden DCT5280 Handset
if battery just replace battery but the head sets are compatible with other handsets of same ghz say 2.4 you just gotta set in base and let base recognize new hand set these phones are practically built the same way but only with new technology
May 03, 2008 | Uniden Cordless Phone
UNIDEN POWER MAX 2.4 GHZ
Do you have the manual on line for the Uniden PowerMax 2.4 GHZ
Apr 01, 2008 | Uniden Cordless Phone
A calling block to mobiles for home phones help imfo
to block any call press *67 before dialing the number, to unblock a call you need to dial *82 before dialing the number. both are free.
Jan 11, 2008 | Uniden DXAI5188-2 Cordless Phone
Uniden 5.8GHz Dual Cordless Phone Logo
403 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
