Question about Jenn-Air JCD2290HES Side by Side Refrigerator
"Lock" light came on and I don't know how to turn it off.
Can't use water or ice features.
  • jillymac260 Jan 16, 2009
    Thanks. I found my manual while waiting for a reply and it also said to press the lock buttom 3 times within 10 sec. and that worked.
  • Kara Feb 08, 2013
    This fixed mine!!! ThaNKS!!!
  • 126 Answers
First press and hold the lock button for about five seconds. If that doesn't help unplug the refrigerator for about 30 minutes. It may be that you have an electronc gliche then and if you break the circuit by unplugging the refrigerator (you can also trip the circuit breaker that controls the refrigerator, if that is more accessible than the plug) it should reset. if not you may have a more serious problem with an electronic control. Good luck, hope this helps.
Posted on Jan 16, 2009
  • diane trott Jan 16, 2009
    Glad you are fixed! happy new year.
4 Suggested Answers
Krazytech
  • 725 Answers
SOURCE: Ice & water control buttons
sound like a bad(shorted) dispenser user interface INTERFACE DISP ASM WR55X10415
Posted on Apr 05, 2008
SOURCE: Whirlpool Gold GD5YHAXNL00 Doesn't dispense
Frozen water line. Turned down the temperature setting and the next day it was working again.
Posted on Jun 05, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Cube and water sensor on control unit don?t work.
Do you have a Brand Name and Model Number?
Posted on Jun 22, 2009
Water has stopped flowing to the ice maker but is ok to the door fountain. hoses appear to be ok.
sounds like you ice maker is shut off. There should be a switch next to ice maker to turn back on. Also look for a lock out feature for the ice maker. It could also be a sticking water solenoid to allow water to enter tray.
Dec 04, 2010 | Kenmore 57029 Side by Side Refrigerator
Red lock light is on below ice and water dispenser. How do I turn it off so I can get ice and water?
Does this model have a light button? (I know the 685 and the 695 do.) If it does, press and hold the Light button until all the LEDs light up once. This takes about 5 seconds. (Repeating the process will reenable the lock.)
I hope this helps.
Oct 13, 2010 | Sub-Zero 690 Side by Side Refrigerator
How do I shut off the ice and water feature on a model mzd2766ge? The house I'm moving into is not plumbed for it yet. Thank you for your help.
Hello. All you need to do is to raise the wire arm inside the ice maker, and above the ice bin. It will lock in the up position which turns this feature off. J.
Jun 27, 2010 | Maytag MZD2766GES Side by Side...
How do I unlock the water function? My daughter put the lock on the water feature and I can't unlock it.
Usually you just press and hold the lock key for 3 seconds until the "lock" light goes out. If the ice is still working, it is not the lock mode activated, but possibly a frozen water reservoir or maybe a defective fill valve.
Jun 16, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
NO ICE
Check this first,
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
ice and water dispensers. To turn off the ice maker, see “Ice
Maker & Storage Bin.”
 Press and hold LOCKOUT for 3 seconds to lock the
dispenser.
 Press and hold LOCKOUT a second time to unlock the dispenser.
Let me know if this helped, Sea Breeze
Mar 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice and water won't come out dispenser
here is link to your owners manual subzero.com
and here are instructions for using the lock feature..
LOCK For Models 685 and 695, the lock feature is used to prevent unintended ice and water dispensing. When the dispenser is locked, all key pads on the glasswell are deactivated to allow cleaning or to prevent small children from using the dispenser. To activate the lock feature, hold down the LIGHT key pad on the glasswell until the key pad lights flash once and the red LOCK icon is illuminated (approximately five seconds). The lights will remain in the state they were in before the lock feature was activated. To deactivate the lock feature, hold down the LIGHT key pad until the key pad lights flash once and the red LOCK icon is no longer illuminated (approximately five seconds). The lights will remain in the state they were in before the lock feature was deactivated.
Thanks Peyton
Mar 02, 2009 | Sub-Zero 695/S Side by Side Refrigerator
I have a Whirlpool(Model: GS6NBEXRL01) Side-by-Side has a sensor on the right side of the freezer and a flap on the left. The light is red and the icemaker is making ice, but will not dispense through the...
The Dispenser Lock (on some models)
ice and water dispensers. To turn off the ice maker, see "Ice
Maker & Storage Bin."
• Press and hold LOCKOUT for 3 seconds to lock the
dispenser.
• Press and hold LOCKOUT a second time to unlock the
dispenser.
Let me know if this is your problem, Can get the manual for you if you like, Sea Breeze
Feb 04, 2009 | Refrigerators
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
Apr 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Jenn-Air JCD2290HES Side by Side Refrigerator Logo
792 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
