Question about Panasonic NN-T654SF Microwave Oven
My Brand New Panasonic NN-SD697S 1.2 cu.ft. 1300W Microwave
The microwave will not heat and cuts off - a message code comes up in the sensor timer box -- H98. I have only had the microwave since early August 08. I have moved and cannot find the manual.
PLEASE HELP!!
Thank you,
Rebecca
  • Panasonic Master
  • 19,396 Answers
If you still did not find the manual, contact Panasonic at the link below:
Consumer electronics product support at Panasonic.com
Posted on Jan 23, 2009
  • 63 Answers
I am afraid I have some bad news, the code H98 on the Display a problem with the microwave
generation system. This is the part of the microwave that creates the energy that cooks the food. According to the manual, the microwave needs to be serviced. I hope that it is still under warranty. Sorry that I don't have better news for you.
David
Posted on Jan 16, 2009
  • David Vawter Jan 16, 2009
    Also, you can Download the Manual here This is also a link to the Support page where you can enter your zip code and find a place nearby that can service it for you. Might be worth getting an estimate, but I am guessing your money will be better spent towards a new Microwave.
    President:
  • 1,596 Answers
Set the Time on it ? and Clear Button for Message
Panisonic inverter microwave lights up but doesn't fully come on
How to fix microwave that counts down but does not heat or ...
? 4:51
https://www.youtube.com/watch?v=PIU1NRpeA_8
Oct 2, 2012 - Uploaded by G-Unit_YouTuber
How to fix frigidaire microwave door sensor relay switch. ... with a different part number (D3V-16G-2C25) but it doesn't look like it's stocked. ... Problem now is that when we open the door, themicrowave comes on by itself! ... I am not sure, when you hooked up the volt meter, did the lights turn on and off ...
All comments on Fixing Panasonic inverter microwaves ...
https://www.youtube.com/all_comments?v=hBJJU4ZRh7U
i have a nn-h965wfx the light comes on the countdown initiates but nothing comes .....I have a similar full size panasonic inverter microwave NN-L931BF built in ..... After putting it all back together the thing doesn't even power up the display.
Panasonic 1200W 1.2 Cu. Ft. Countertop Microwave Oven ...
www.amazon.com/Panasonic...Microwave.../B005BFZ...
Amazon.com, Inc.Ft. Countertop Microwave Oven with Inverter Technology NN-SN661S Stainless at Amazon.com. ... The microwave panini meals even end up with toasted crisp bread. ...But, right now, I find the interior light functionality just fine. .... (1) In this Panasonic, the light doesn't come on when the door is open; it only comes on when ...
Jan 05, 2016 | Microwave Ovens
Start button not working
take it to a repair shop many things can cause this problem
May 11, 2015 | Panasonic NN-H765WF Microwave Oven, 1.6...
Where is fuse located
Leonard, first, unplug the microwave and then turn it around so that you are looking at the back of the unit. Take the screws out that hold the cover onto the unit, most will be accessible from the back, but some may be on the side as well. Once you have all of the screws out you can remove the cover and set it aside. Find where the power cord goes into the back of the unit and follow the black wire from the cord to where it stops. Usually it will go either to a circuit board where your fuse will be located or it will go directly to the fuse holder. The holder could be a block mounted to the unit or it occasionally goes to an in-line fuse holder. The fuse will be stamped with the amperage rating on one end of the fuse on the metal collar. You need to make sure that you replace it with the same amperage fuse. Hope this helps!
Feb 16, 2015 | Panasonic Nn-sd697s Microwave Oven Single...
Trouble code H98
H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
R
Oct 03, 2014 | Panasonic NN-H765BF 1250 Watt Microwave...
Power shuts off completely
Microwave NN-SD697S; Went i push start switch, some time start and some time not, power it fine. thanks for replying
Feb 02, 2013 | Panasonic NN-SD688 Microwave Oven...
Panasonic microwave model #NN-SD697S stopped working. Timer works for 2-3 seconds without motor running(heating) then turns off. Push start button, nothing happens.
@William Miller - where are you located if i'm interested in your help with the microwave repair? I'm having the similar issue with the Start buton not working for my Panasonic NNSD697SS. Thanks
Feb 10, 2011 | Panasonic Microwave Ovens
Panasonic genious sensor inverter 1300w nn-t664sfx displays code "h98" & will not run - what's the problem?
Mine did this once and it was the magnetron. Once replaced, it worked fine. Repair is an option if it is still under warranty or someone will do it on the cheap. Otherwise, just get a new microwave, since this is the main part.
Oct 04, 2009 | Panasonic NN-S960WA Microwave Oven
Panasonic Microwave SD697S quit cooking and has
HI, this will require the skilled hands of a qualified Panasonic tech. The damaged part here is the Magnetron assembly. this is a very sensitive part that creates radiation and the heating process as well. you will need to replace this device asap if possible...
thank u
rate me!!!
Jul 28, 2009 | Panasonic Microwave Ovens
What cause the wattage difference?
Wattage is based upon voltage & current. I would think that on the 1300W unit, either the voltage or the current is higher than that which is used on the 1200W unit.
Perhaps the magnetron in the 1300W unit is being driven harder. Are the fans the same size?, The magnetron in the 1300W could be running harder and they have a larger fan in it.
In any event, if the part numbers are the same, you should have no trouble using one units parts to fix the other.
- Jim
Feb 17, 2008 | Panasonic NN-S561 Microwave Oven
Panasonic Microwave Warm
Replace the h.v. capacitor (the silver can mounted in back under the magnatron) and the h.v. diode and it will be fine.
Hope Ya Fix It!
Jan 30, 2008 | Panasonic NN-S960WA Microwave Oven
Panasonic NN-T654SF Microwave Oven Logo
174 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
