Question about Electrolux EOB6636X Ultrafan Electric Single Oven
Too much smoke in the oven
Ive had my cooker for about three months now, each time i use the grill or the oven, it fills my kitchen with smoke, i thought in the beginning this was due to it being new, but it gets used every day and i thought by now it would have stopped, anyone help?
    President:
  • 1,462 Answers
Really the only reason for smoke is fat on the elements especially the grill element. suspect problem may be due to what you are cooking
Posted on Jun 18, 2007
HOW TO GRILL?
You cant really grill in an oven because ovejs dont use an open flame unless its a gas stove. Even so, if you try to grill in it you will probably fill your house with smoke.
Jul 16, 2014 | Smeg Ovens
Beko DVC5622X bottom oven wont heat up
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. If this helped you why not get me a beer?
Paul is from the Naturally he would appreciate beer How to Repair Home...
Oct 27, 2011 | Ovens
The grill on my Hotpoint EW 41 Electric freestanding cooker has stopped working after my wife put aluminum foil into the grill pan which then touched the grill element causing it to 'blow' and so...
The grill element should not 'blow' by just touching it - it should be earthed. The elements do gradually disintegrate over time & the inside wire element either fractures or touches the element casing causing the mains to trip. Sometimes this makes it trip just once & then stops working. Replace the element - not usually any fuse in circuit with this. Often held in by 2 screws adjacent to the element at back of oven and conections via Fast-ons- Rick
Jun 12, 2011 | Hotpoint Ovens
Resetting the clock
You can set the timer on a single oven slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking.The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
INSTRUCTION BELOW.
  • Fill the insert of the single oven slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  • 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
  • Please rate this solution after use.
    Thank you and thanks for using fixya.
    Oct 03, 2010 | Maytag CWG3100A Gas Single Oven
    My grill on my oven is melting the knobs and the heat is that hot i have to stand away from the cooker i have to switch the knobs off a tea towel and it fills the kitchen with smoke is this covered under...
    I assume that you are grilling with the oven door open and not closed, if you are grilling with the door closed, then this will cause an overheating problem,if this is not the case, then I would suggest that the grill regulator is faulty,. and needs replacing.
    It not covered by health and safety rules.
    Please leave any comments you may have, as I like to know if my comments are appropiate.
    Thanks.
    Nov 25, 2009 | Belling Ovens
    Smoke comes out of grill on electric cooker
    This sounds like some of the power wiring, or leads which go to the "electric" burners. the smoke is a wire based or very chemical based smell. that in it self is toxic. when it comes to something as major as this you should for your own safety contact the seller if it is under warranty. The voltages and risk or burns electrical and heat wise are not worth the risk to your person and or life and or property.
    Nov 10, 2009 | Stoves 720EF Electric Double Oven
    My CDA fan oven will not get hot
    Ok , classic example of a fan oven element blowing, take the cover off inside the cooker held on by 4 screws so you can see the round element, you should be able to see where its blown a big hole.
    replace element
    ( make the cooker is turned off of course)
    Sep 18, 2009 | Ovens
    Cleaning above the grill element
    I would not advise you to remove the element unless you feel competent to do so.
    Best thing to do is to put the grill full on and let all the fat and grease burn itself off.
    you will not hurt anything by doing this.
    Make sure you have the griil door open and your house door.
    Plz rate my solution.
    thanks.
    Dec 18, 2008 | Candy FP855 Electric Single Oven
    SMEG A21X-5 Freestanding Cooker: Main oven has smoke/fumes everytime its used!
    usual cause of fumes is if the grill is in the oven, when for example a roast is done, fat spits onto the grill element and the circular element and smokes. if you leave it on, the smoke will clear. some ovens have a fat guard which clips over the grill in the centre of the back panel to prevent this.
    to clean glass, just use scouring pads - glass is virtually impossible to scratch
    Oct 01, 2008 | Smeg Ovens
    Electrolux EOB6636X Ultrafan Electric Single Oven Logo
    761 people viewed this question
    Top Electrolux Ovens Experts
    ashburton
    Mack Baxter
    Are you an Electrolux Oven Expert? Answer questions, earn points and help others
