Question about Kodak EasyShare C703 Digital Camera
Lens stuck open
I have a Kodak easyshare C703. The lens is fully extended, and when I turn it on the screen reads "Lens Error 20E1,0,0" then it shuts itself off. My husband claims he didn't drop it(?). The Kodak site wasn't useful. PLEASE HELP!!! Thank you!
  • 2 more comments
  • Anonymous Dec 27, 2007
    I have the Kodak EasyShare C703 and the lens is staying open, when i turn it on it reads lens error: 126, 1, 0-0.
    I just got it two days ago, and it worked fine yesterday.
    I didn't drop it, shake it, or less with the shutters.
    I don't know what to do.
  • Anonymous Jan 08, 2009
    • the len on my c703 is fully extended, I put new batters in it, no responds what should i do?
  • sunstar5000 Apr 14, 2009
    I have a Kodak EasyShare c643 and I sat on it. The lens won't go back in and i says:  Lens Error: 123,0,0, -26
    Help it's about $100 + shipping to fix it is there any other way???
  • Anonymous Mar 13, 2014
    how to turn on
Hi! Sounds like we have the same problem but mine says lens error 221,0,0,0 and my daughter dropped mine. If i dont get an answer soon, im sending my in for repair, it will only cost me $50.00. Here is the website incase you want to fix yours :) WWW.Kodak.com and just click on the repairs and services. Good Luck!!
Posted on Sep 06, 2007
I have a Kodak C613, it was dropped down the stairs and the lens in stuck out, and will not come in. When I turn it on it says "Lens Error: 123, 0, 0, -23" It fixed itself once, but now it will only let me view picture when I go to favorites mode before I turn it on, then press review. Any ideas on how to fix it?
Posted on Jun 15, 2008
I have the same lens error 20E1,0,0 on my Kodak C163 , unlike you who have that little bit of doubt judging by that question mark at the end of your sentence that your hubby dropped it , I was the only one who ever used my camera , I didn't even have it for a month treated it like gold, doesn't even have a scratch on and now they telling me that It is from human fault , and the warranty doesn't cover it, just strange that it seems to be a common problem on the easyshare camera's I honestly think this is a manufacturing fault or design flaw
Posted on Jun 26, 2008
Mine did that for a while and eventually fixed its self... well my 6 month old daughter dropped it again today now its a lens error AND it wont open!
Posted on Sep 24, 2007
SOURCE:
When I power up the camera the lens opens and immediately retracts and the camera shuts off. I've attempted to push every button while turning on the camera to no avail. I also held onto the lens when it...
Have you made sure that the batteries are LiIon and fully charged? I had a similar problem with a Kodak Easyshare camera that required the higher voltage LiIon battery pack rather than alkaline AAs which will fit in there but is not exactly right.
Feb 09, 2011 | Kodak EASYSHARE M763 Digital Camera
Hi, My Kodak EasyShare C613 intermittently starts up ok, but other times the lens extends and the viewfinder stays on the initial screen. (The Kodak EasyShare system 'share') After around 40 seconds...
My camera is stuck on the screen that says "lens error" and then has four different numbers in a row. The camera lens is fully extended and will not shut off...any suggestions of what the problem could be?
Nov 04, 2010 | Kodak EasyShare C613 Digital Camera
The camera turns on then shuts back off again
hat type of problem is usually associated with a lens extend error.
It is usually caused by weak batteries or dropping the camera.
Keep your eye on the LCD screen when you turn the camera on.
Do you see any type of error message?
Now turn the camera on again and help the lens extend by gently pulling on the lens as it extends.
Does the camera stay on when you do that?
Sep 24, 2010 | Kodak EasyShare Z740 Digital Camera
My Kodak EasyShare M340 turns on, but then shuts off immediately.
omg! thank you so much Stephan you are th best i just bought the camera for Christmas. Went to the beach yesterday and it sttopped working the method with holding the lens and moving it around i saw some sand come out now it works!!!!!! :-D
Oct 07, 2009 | Kodak EASYSHARE M340 Digital Camera
Camera lens wont open or close after being dropped. it won't turn on and take pictures
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Jul 06, 2009 | Kodak EASYSHARE M1063 Digital Camera
KODAK Z1275
I semi resolved the problem with my Kodak Z1275 with this suggestion; Step 1, making SURE the batteries are good. Then, position the camera with the lens pointed up or down (depending on stuck lens position, USE GRAVITY AS YOUR FRIEND) and gently tap on the lens just as you turn on/off the camera. You may have to do this several times before the camera will close the lens. From my research this camera has a faulty mechanism for the lens which causes the software to recognize a lens failure thus shutting down the camera. Poor designed lens mechanism! I now am using my camera again, but regularly have to remember to allow gravity to assist in lens opening (turning on) and lens closing (turning off) as well as occasionally giving it a light tap or in extreme cases lightly assisting the lens opening/closing. Hope that helps! Oh and I don't suggest buying another Kodak camera!
Sep 15, 2008 | Kodak EasyShare Z1275 Digital Camera
Kodak
Hey,
Seems the lens mechanism is stuck and would need to be taken apart, its best to send the camera in for repair.
http://www.advancecamera.com/repair <- Get a free estimate from there.
Thanks,
Ekse
Aug 29, 2008 | Kodak EasyShare V603 Digital Camera
Lens error No. 221,0,0,0
I have Pentex Optio E 30 camera
When i start my camera , i get error message Lens Error : 221,0,0,0
lens got stuck and it is not coming out for zooming
Sep 06, 2007 | Kodak EasyShare C703 Digital Camera
Kodak EasyShare C703 Digital Camera Logo
449 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
