Question about Black & Decker VPX Drill/Driver
Black and decker electric drill driver quit working
I used my drill to stir up drywall mud in 5 gallon pails, the next day it didn't work
  • 66 Answers
It will never work again either. you can't use a little drill for a big job, and 5 gallons of drywall mud is a big job. Sorry for your loss
Posted on Feb 16, 2010
How long does it take to hang, tape, mud and finish a sheet of drywall
2 or 3 days, plus or minus depending on how fast the mud dries.
Apr 30, 2015 | Drywall
Tip
Fixing textured (not popcorn) drywall ceiling
If you've got a house built in the 90's, you may well have a textured drywall ceiling with a pattern on it. The most common pattern is a blossom texture with patterns of repeating ridges form circles.
The problem comes when you have to repair this ceiling. Knowing how to duplicate the texture is the problem.
Here are the steps to do this:
Replace/repair drywall ceiling until the surface is paint ready, but do not paint. Sand texture off of some of the adjoining ceiling to avoid a visible border.
Make sure you have a drop cloth down!!! This might drip.
Mix drywall mud down to the consistence of pancake batter. You want it stiff enough not to drip, but pliable enough to texture. The mixture should just barely be pourable.
Pour into a paint roller pan, and using a long nap roller with the lint removed (use masking tape) roll the joint compound onto the repaired area.
Allow to set for a few moments to make sure it won't drip Now get out your stomping (yeah, that's what they call it) tool, and texture the ceiling.
You can buy brushes to "stomp" your ceiling at many paint stores, but they aren't cheap. Instead, you can do what most drywall guys do, and make your own. Go to the store and get an old fashioned string mop. When selecting the mop, look at the head. Some have a rectangular bar holding the strings in place, and some have a round tab, about the size of a quarter. You want the one with the round tab, and get one with strings, not cloth strips.
When you get it home, hold the mop up to the ceiling, and note how long the strings need to be to create the same size pattern. Cut your strings about two inches longer, since the whole string does not hit the ceiling.
Trim the strings to the correct length, then soak the mop for 24 hours to limber them up.
Now back to the stomping. Once you have your drywall mud applied, all you have to do is hold the mop over your head, upside down, straight up, with the strings hanging uniformly around the sides. The mop should be damp, but not wet. You can add a bit of drywall mud to it first if you wish, I do not.
Hold the mop about eight inches below your drywall, and starting at an edge where you can judge where to match the old pattern, "stomp" the mop into the wet mud, just like you were stomping your foot. Immediately pull the mop back, and you should have the same pattern as your ceiling.
Continue stomping until you've covered the ceiling. Afterward, you can wash the mop, and keep it for later if you think you will need it.
Tips:
After stomping, let it dry for at least two days before painting.
When you buy your drywall joint compound, look at the prices. You can often get a five gallon bucked for only a couple of dollars more than a gallon. (I always buy pre-mixed, it works great). To preserve the mud you didn't use, after you're done with it, mix a teaspoon of bleach into a cup of water. Level the surface of the mud in the bucket, then pour a layer of the bleach/water mix on top. This will keep the mud from drying or molding.
on Dec 30, 2009 | Hand Tools
How do i attach the drill bits
Not easy to explain. suggest next door neighbour may help. Don't guess, the result could be nasty.
Jul 21, 2014 | Black & Decker Black and Decker Mm575 18"...
Drill sqeaks when mixing drywall mud
If your drill squeaks, it's most likely one or both of the armature bearings are failing. If you run it too long after they fail, you'll also melt the case arount the bearing and have to replace the housing along with the bearings. You didn't specify which model you are using to mix mud but If you are using the Makita drill pictured with this query, you are over powering it. You should be using a spade handle drill for mixing mud. It has a gear reduction and more powerful motor to handle the torque needed to mix mud.
May 24, 2014 | Makita & 1/2 Inch Drill
6.0 hp 12 Gallon Shop-Vac 'exploding'
Those type of vacuums are designed for light duty work around homes anyways. For commercial industrial work as you are doing you need a sump pump. We used to drop one in a 5 gallon (20 liter) pail, drill holes in the pail and suspend from a rope. (you can put screen around the pail covering the holes if needed too). Use a stiff hose to expell the water. You can change to a flat hose like a pool waste water hose or fire hose after the water is out of the trench.
Nov 20, 2013 | Shop Vac Vacuums
I bought a Black & Decker 7.2v cordless drill with
Just charge battery put bit in and your ready to go.
Jul 04, 2011 | Black & Decker Drills
Black & Decker 1/2" drill
I had to replace the variable trigger on my 3/8 Black and Decker as the trigger failed and would not start the drill.Maybe you have the sme problem as many B&D drills have the same variable trigger.
Jan 10, 2011 | Drills
Trying to mount blinds in kitchen, walls plaster over carstone. as soon as we hit carstone masonry drill stopped in its tracks!! less than half inch into wall!! really need to be at least quarter inch...
Is there a space between the back of the drywall and the stone? Or is the drywall tight to the stone? Either way, you need a masonry bit, I hope you have one, a hammer drill would be real nice, but you can muscle through it without one. You can try a smaller bit as your first cut , then go to the next size. Makes it a lot easier to drill. If there was a space behind the drywall, they make all kinds of fasteners for drywall only, they will hold quite a bit, but might not be enough for blinds that are going to be yanked on.
Feb 13, 2010 | Black & Decker Drills
How do I change my black & decker electric drill to go in reverse or forward? As you can see I'm tool challenged. Kathleen
The switch near the trigger that toggles left or right controls that.
Good luck with your project, Kathleen.
Oct 02, 2009 | Black & Decker 3/8" Variable Speed...
How is a driver different from a drill? What
Hello, W/D here.
A very good question......A drill holds a bit and rotates it at a given speed. This speed can be variable, allowing the speed of the drill bit to be better matched to the material being drilled. The output from the drill motor goes directly to the chuck, and the power is directly applied to the drill bit. Some drills can generate a tremendous amount of direct torque, due to the nature of their gearing. Most of the better drills have planetary gears in them.
A driver rotates like a drill, but is designed to apply torque to a driving bit, and cause a fastener to be placed by the driver. The main difference between a drill and a driver is that a driver has an adjustable clutch, allowing the amount of torque being applied to a fitting to be preset. A good example of this would be for driving wood screws. You would dial in the torque setting that you want the driver to quit driving the screw. You don't want to drive the screw to China, you want to drive it flush. A maximum torque setting "locks" the clutch, and the fitting will be driven as far as it can go (This is about as close to being called a drill as a driver will ever get). A clutch setting midway might be just right for driving the same fitting into oak, and a setting at less than that might be just right for pine. The torque clutch effectively sets a kick out torque for the driver. When the torque applied matches the torque set on the driver, the clutch "slips", and no further driving action can occur.
Most modern battery powered drills incorporate a torque clutch between the motor and the chuck so that the tool can be operated as a drill (with the torque setting at "max") or as a driver (with the torque setting at less than max) some electric tools are configured as both, but usually they are different. For the money, a good battery powered drill/driver with a clutch offers more versatility, in my opinion.
Best regards, --W/D--
Aug 19, 2009 | Dewalt Home Fencing
Black & Decker VPX Drill/Driver  Logo
160 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
