I need a file off my laptop and I can;t get it to boot.
  • 1 more comment
  • inspector533 Jan 16, 2009
    Thanks, I tried that. I think it's the hard drive. I gotta get a file off, but I can't get the hard drive read by another computer. It knows it's there but it can't find any files.
    I bought a device to allow me to hook my drive to another computer. I used My Computer and saw that the D: drive was showing up. I clicked on the D Drive icon and it came up with an error message saying that the D Drive didn't exist, The device I bought had a power light and looked like it was activating and trying to read the drive when I clicked on the the icon.
  • Nikola Malesevic
    Nikola Malesevic May 11, 2010
    Please describe why you cannot boot to your computer? Where does it halts? Do you get any error messages?
    Genius:
  • 1,102 Answers
Continuosly press f8 while in start up
may need to try a couple times
this will bring up options then go to safemode
Posted on Jan 16, 2009
  • DEKR
    DEKR Jan 16, 2009
    are the jumpers set correct for the other pc your trying to use
Boot up xp get the.... File:\Boot\BCD Status:0x0000098 Info:The windows Boot Configuration Data file does not contain a valid OS entry.
try putting your XP disk in the drive and shut down then restart system many times it will find what it needs and go to working again
Apr 17, 2015 | Computers & Internet
Os can't boot from hdd
you must use livecd to boot your hdd,then back up all your files to an external hdd,then you are going to reformat your drive to boot it normally.use a working pc to get files..in iso format...save it then burn with your iso burner..you can get the files here>http://www.ubuntu.com/getubuntu/download
After you've burning,turn on your not booting machine ,place it to cd drive of your machine and it boots,insert your usb or an external hdd then copy all files needed
Feb 10, 2011 | LG Computers & Internet
What would make an hp laptop w/windows vista not turn on ,even tho its fully charged
So many things. Does it turn on at all or it just won't boot into Windows? If it doesn't turn on at all, remove the battery and run straight from the power cord. Make sure you are getting power to the computer.If you are getting power and the system turns on, but won't boot into Windows, trying booting into safe mode or using a recovery disk to start at a command shell. Remove the hiberfil.sys file and try to restart. The hiberfil.sys is a hidden system file so you'll need to use the following commands;
attrib -r -s -a -h hiberfil.sys
del hiberfil.sys
Try that. I just fixed a laptop last week and I had to delete the hibernation file in order to get the laptop to boot.
Nov 21, 2010 | HP Computers & Internet
Windows vista
Yes you can get download recovery discs, Hiren's Boot Disc, BartPE, & Live distributions, such as Linux, or indeed the operating system install DVD. These all can be used to do so.
Jan 28, 2010 | Samsung MOBILE NOTEBOOK Q310-34G SYST2.0G...
Hi,i have problem with my laptop when i installed any o.s. in my laptop then it was not boot from cd it will show message ntldr file is missing what should i do pls tell me
ntldr file is needed to boot a system
it will installed when you reinstall your operating system
but be aware don't delete that file it will in the OS drive
Dec 31, 2009 | Acer Computers & Internet
I have a lifebook a6110 no boot up, scroll lock blinking. Fans working constantly. hard drive seems to work but it stops.
Hi
well if u r saying that after working for a while, the process competely stops, then there's a boot file that is missing. I dont know the name of that file but i've solved such probem previously.
U need to repair ur system using the Installation disk.
Just enter the installation disk, and start ur computer/Laptop.
Now select Boot From CD/DVD rom
let windows load its few files, and select repair
This will restore all the files that r required for booting up ur system
Hope this helps u out, and if it doesn't let me know it, i'll surely sove it out.
If u like my post, please rate me up, i really need some good ratings.
Thanks..
Jul 16, 2009 | Computers & Internet
File header checksum does not match computed one. ???
You have one or more critical corrupted file/s which prevents the laptop from booting up.
To get the laptop operating again, you need to insert the Windows Vista CD and do a Repair and if this fails you need to install Vista again.
May 05, 2009 | HP Pavilion dv6000z PC Notebook
Install Windows xp off USB
If you are only trying to boot to windows then you'll need files NTLDR, Boot.ini, NTDETECT.COM, and NTOSKRNL.EXE on the USB drive. This will boot you to the windows screen. Trick is to get those files off of your windows CD onto your USB...then copy those over to the c:\ and that should also take care of boot problems if it was because of corrupted files.
Apr 04, 2009 | Dell XPS M1530 Laptop
Laptop will not boot up.
Try Restore.
try restore from disk. (if you have them)
Try factory settings, and you do not need a swap file.
Feb 10, 2009 | Medion md40298 Notebook
My laptop wont boot
How long does the screen display that quote? Sometimes Linux will lock up completely at boot, but usually it will give a message such as "kernal panic" if it does; in your case, if the GRUB boot-loader is failing to find a kernal to boot, you may not have a valid boot-loader configuration file or installed operating system. Or, you may just need patience.
I suggest you try booting from a Live distro disc, such as Ubuntu (DVD), SuSE (DVD), or Damn Small Linux (this is probably the fastest, at only 50 MB) or DSL's Not Damn Small Linux (CD) which still has pretty minimal hardware requirements but includes more tools. Even DSL should let you view the files on your laptop's hard-disk drive and edit configuration files if there are issues.
Jul 30, 2008 | Compaq Armada E500 Notebook
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
