Question about Briggs & Stratton Prosumer 20324 Gas Pressure Washer
Wont start has fuel, water pressure, spark but will not start
  • 630 Answers
Would first remove fuel from tank by pouring it through a paper towel into a container. If it has water in it (which will be caught in the towel) You will need to clean tank completely and remove and clean carb.
Posted on Mar 15, 2009
  • 211 Answers
Hi
First check compression.Priming the engine for few times.Check the air and fuel filters.Check the flyweel keey not to be shatered off(timing).Start the engine.If the engine only runs the gas from the cilinder you puted inside you have a fuel delivery problem to find and fix.The spark at the plug has to be blue!
best regards savumihai71
Posted on Feb 12, 2009
After changing fuel pump and crank sensors, car won't start. 1999 Lincoln contintal
wouldnt start before all that or just after, (hummmmmmm)
wont crank or cranks robustly but wont start.
check fuses yet?
May 12, 2015 | 1999 Lincoln Continental
2001 Honda ex coupe delay to start when I turn the key it takes 3 or 4 seconds then It will start.... starting today it wont start at all
you mech looks outside, and sees Nunavut Tavern,
and he's running summer fuel, or it so cold the battery is weak.
or there is water in the fuel, or or or, dang.
or he's in Dallas, and he forgot to do the 60k mile service.
oops. (aka, a tuneup)
today , it wont start, he look and finds spark gone , he fixes that
or he finds the engine is flooding, due to bad sparkplugs.(12year old plugs) or fuel pressure is at 60 and the regulator is bad.
or the sparks are dry and finds the fuel pressure a 5psi, and
a corroded connector 3 feet behind the fuel tank.
(can go on for 2 days stop)
Oct 01, 2013 | 1995 Lexus Sc 400
I got a 2000 ford focus that cranks but don't starts, fuel pressure is good, good spark but spark plugs are pretty worn out can that cause it to do that?
You only need three things to start an engine.
1) Clean Fuel / Air
2) Compression
3) Spark
One of these is not working correctly. The fuel pressure is good, but the fuel line, fuel filter, injectors, or carb may be dirty or clogged. If the gas has been sitting for a long time, or could have water in it, there is potential for the gas to be gummed up, and it wont ignite. Start with clean, new gas, line, filter, and if it still wont start, move on to the #2, #3 items from the list above.
Move through the troubleshooting systematically.
Remember, you only need 3 things to get it to run!
Good luck
Mar 19, 2013 | Ford Focus Cars & Trucks
01 grand am
needs air, fuel and spark. You have spark, make sure air filter is not clogged and the fuel pressure is up there; could also be water in fuel... dump fuel from filter in a glass bowl and take a look... replace filter and flush fuel system if water found. Injectors might need cleaning...
Dec 05, 2011 | Cars & Trucks
Wont start has firering spark
hi
You said spark plug is firing that is fine have you check fuel system check your fuel pressure regulator,also check your spark plugs conditions.
It can be fuel pump but first check the pressure fuel.
Feb 21, 2010 | 1996 Dodge Caravan
Wont start\good fuel pressure\good spark
Then the fuel injectors are not pulsing,replace the crankshaft sensor,it controls the spark,but also the pulse for the injectors.
Jan 30, 2010 | 2000 Buick LeSabre
Cranks but wont start 2000 mustng v 6
You need to check fuel pressure. If fuel pressure is ok, check to see if you have spark at the spark plugs. If you have both spark and fuel pressure it may be a timing problem with the injectors.
Oct 01, 2009 | 2000 Ford Mustang
My almost new Honda GCV 160 engine will not start.
Hi , I think you need someone to remind you these engins are not made by god and they work by obeying three simple rules ,
1.Spark , Can you see a very good blue spark
2.compression,,can you feel strong compression ,
3.fuel , is the right amount of fuel getting in , is the air mixture good ,
Now try these things
Find the manual and PROPPER set the gap in the spark plug ,
clean and check the air filter ,
remove all fuel and replace with brand new,
check the fuel filter,even in the tank tap?
undo the screw at the carb bowl , can you see petrol leaking ,
If everything checks out then try this to get it started,,
spray "easystart" in the carb , bypassing the air filter ,
if it wants to start but cant for long then its a carb problem
check float hight , float needle,jets and pins ,too much air getting in
find someone thats good on motorbikes , They like me know all the tricks to get things to start ,
Aug 16, 2009 | Karcher 2500 PSI Pressure Washer
1992 Nissan 300ZX wont start
may wanna check the distributor could be outta whack (timing).
Sep 15, 2008 | 1992 Nissan 300ZX
Briggs & Stratton Prosumer 20324 Gas Pressure Washer Logo
372 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
